Compressed Air - Friction Loss in Hoses
Compressed air friction loss in hoses are indicated below. Gauge pressure
  • 50 psi - black line
  • 70 psi - red line
  • 90 psi - yellow line
  • 110 psi - blue line
  • 1 psig = 6.9 kPa = 0.069 bar
  • 1 inch = 25.4 mm
  • 1 ft (foot) = 0.3048 m
  • 1 scfm = 0.472 nl/s
Example - Pressure Loss in Compressed Air Hose
The air flow in a 3/4" pipeline with 90 psi pressure is 30 cfm.
From the second diagram above we can estimate the friction loss to be approximately  0.4 psi/50 ft.
The friction loss in a 10 ft hose can be calculated as
(0.4 psi/50 ft) (10 ft) / (50 ft) = 0.08 psi
Gases and Compressed Air
Compressed Air - Air Flow Discharge through Hoses
Discharged air flow volume through hoses with pressure ranging 30 - 90 psi.
Compressed Air - Pipe Line Pressure Loss - Online Calculator with Metric and Imperial Units
Calculate pressure drop in compressed air pipe lines - metric and imperial units.
Pressure loss in compressed air pipe lines.
Compressed Air - Size of Pipe vs. Capacity
Air pipe lines capacities at pressure 100 psi (6.9 bar).
Compressed Air Pipe Line Capacity
Capacities of compressed air pipelines - pressure ranging 5 - 250 psi (0.5 - 17 bar).
Compressed Air Pipe Lines - Pressure Loss vs. Capacity and Operating Pressure
Pressure drop in compressed air pipe lines.
Compressed Air Pipes - Fittings and Pressure Loss
Fittings in compressed air pipe lines and equivalent length pressure drop.
Compressed Air Piping - Pressure Loss Diagrams, Imperial Units
Pressure drop in compressed air pipelines with applied pressure 50, 100 and 150 psi.
