Compressed Air Piping - Pressure Loss Diagrams, Imperial Units
Pressure drop in psi per 100 ft compressed air pipeline can be estimated for some typical entering pressures in the diagrams below. The diagrams are calculated for schedule 40 pipes.
Other dimensions or pressures can be calculated with the
Applied Pressure 50 psig
Download and print Compressed Air - Pipe Line Pressure Drop (gauge Pressure 50 psig)
  • 1 ft (foot) = 0.3048 m
  • 1 cfm = 1.7 m3/h = 0.028 m3/min
  • 1 psi = 0.069 bar = 0.070 kg/cm2
Applied Pressure 100 psig
Applied Pressure 150 psig
The SCFM - Standard Cubic Feet per Minute - determines the weight of air to fixed or "Standard" conditions. There are several definitions of SCFM. The most commonly used in the United States is based on the properties
  • 14.696 Pounds per Square Inch (psia)
  • 60 Degrees Fahrenheit (oF)
  • 0% Relative Humidity (RH)
Europeans normally use one ATA and 0oC as SCFM.
Compressed Air Pipe Line Pressure Loss other Dimensions
Compressed air pressure drop in pipes with other dimensions than schedule 40 can be calculated from
dp = dp40 (d40 / d)5                                          (1)
dp = actual pressure drop (psi per 100 ft pipe)
dp40 = pressure drop in schedule 40 pipe from the table or diagram above (psig per 100 ft pipe)
d40 = inside diameter schedule 40 pipe (inches)
d = actual inside diameter (inches)
Gases and Compressed Air
Air Compressor - Power Cost per Year
Yearly power cost for operating an air compressor.
Compressed Air - Air Flow and Recommended Pipe Size
Pipe line sizing compressed air
Compressed Air - Friction Loss in Hoses
Friction loss in air hoses vs. operating pressure.
Compressed Air - Laboratory Consumption
Compressed air supply to laboratories.
Compressed Air - Pipe Line Pressure Drop Diagram
Calculate pressure drop in compressed air pipe lines with a nomograph diagram.
Pressure loss in compressed air pipe lines.
Compressed Air - Size of Pipe vs. Capacity
Air pipe lines capacities at pressure 100 psi (6.9 bar).
Compressed Air Pipe Line Capacity
Capacities of compressed air pipelines - pressure ranging 5 - 250 psi (0.5 - 17 bar).
Compressed Air Pipe Lines - Pressure Loss vs. Capacity and Operating Pressure
Pressure drop in compressed air pipe lines.
Compressed Air Receivers
Calculating air receivers capacity.
Horsepower required to Compress Air
Calculate horsepower required by air compressors.
Pneumatic Piping - Pressure Loss vs. Air Flow
Pressure loss in pneumatic tubes - sizes ranging 5 - 36 mm.
