Compressed Air - Laboratory Consumption
The typical total demand for compressed air in laboratories due to diversity and simultaneous use are indicated in the diagrams below. All outlets for compressed air are newer used at the same time.
Compressed Air - cfm
  • 1 scfm per outlet used
Compressed Air - l/s
  • 0.5 nl/s per outlet used
Example - Compressed Air Supply to a Laboratory
For a laboratory with 10 outlets the compressed air supply should be sized for a capacity of 3 nl/s.
Gases and Compressed Air
Animals - Laboratory Environments
Temperature and humidity environments for laboratory animals.
Compressed Air - Pipe Line Pressure Drop Diagram
Calculate pressure drop in compressed air pipe lines with a nomograph diagram.
Pressure loss in compressed air pipe lines.
Compressed Air Pipe Line Capacity
Capacities of compressed air pipelines - pressure ranging 5 - 250 psi (0.5 - 17 bar).
Compressed Air Pipe Lines - Pressure Loss vs. Capacity and Operating Pressure
Pressure drop in compressed air pipe lines.
Compressed Air Piping - Pressure Loss Diagrams, Imperial Units
Pressure drop in compressed air pipelines with applied pressure 50, 100 and 150 psi.
Compressed Air Quality
Compressed air is used for power tools, instrumentation, processing, breathing and medical purposes.
