Compressed Air - Pipe Line Pressure Drop Diagram
The nomograph diagram below can be used to estimate pressure drop in compressed air pipe lines:
Download and print Compressed Air - Pipe Line Pressure Drop Diagram
Example - Pressure Drop in Compressed Air Pipeline
The pressure drop in a compressed air pipe line
  • length 100 m
  • air flow 500 l/s
  • inside diameter 100 mm
  • working pressure 9 bar gauge
can be estimated in the diagram by drawing a line from the length line through the air flow volume line to the reference line. From the point on the reference line draw a line through the pipe diameter line to the reference line. From the working pressure line draw a line through the point on the reference line to the pressure drop line.
As indicated below the pressure drop can be estimated to 0.07 bar.
Gases and Compressed Air
Compressed Air - Laboratory Consumption
Compressed air supply to laboratories.
Compressed Air - Pipe Line Pressure Loss - Online Calculator with Metric and Imperial Units
Calculate pressure drop in compressed air pipe lines - metric and imperial units.
Compressed Air Pipe Line Capacity
Capacities of compressed air pipelines - pressure ranging 5 - 250 psi (0.5 - 17 bar).
Compressed Air Pipe Lines - Pressure Loss vs. Capacity and Operating Pressure
Pressure drop in compressed air pipe lines.
Compressed Air Pipes - Fittings and Pressure Loss
Fittings in compressed air pipe lines and equivalent length pressure drop.
Compressed Air Piping - Pressure Loss Diagrams, Imperial Units
Pressure drop in compressed air pipelines with applied pressure 50, 100 and 150 psi.
Compressed Air vs. Free Air - Compression Ratio
The ratio of compressed air pressure to free air pressure.
