Compressed Air Pipe Lines - Pressure Loss vs. Capacity and Operating Pressure
Pressure drop in a compressed air pipe line depends on line pressure, air flow and size of pipe.
Pressure Loss in Schedule 40 Steel Pipes
NPS
(in)
Air Flow1)
(SCFM)
Pressure Loss per 100 ft pipe (psi)
Line Pressure (psig)
5075100125
1/2 10 0.7 0.5 0.4 0.3
20 2.7 2.0 1.6 1.3
30 5.9 4.3 3.4 2.8
40 7.5 5.8 4.8
50 9.0 7.4
60 12.9 10.6
3/4 10 0.2 0.15
20 0.9 0.5 0.4 0.3
50 3.8 2.7 2.1 1.8
80 6.8 5.2 4.4
100 10.6 8.3 7.0
125 12.9 10.7
150 13.9
1 20 0.2 0.1 0.1
50 1.1 0.8 0.6 0.5
75 2.6 1.7 1.3 1.1
100 4.1 3.0 2.3 1.9
125 6.3 4.5 3.5 2.9
150 6.5 5.1 4.2
200 8.9 7.3
250 11.3
1 1/2 50 0.1
75 0.3 0.2 0.15 0.1
100 0.5 0.3 0.3 0.2
125 0.7 0.5 0.4 0.3
150 1.0 0.8 0.6 0.5
200 1.8 1.3 1.0 0.8
250 2.8 2.0 1.6 1.3
300 4.0 2.9 2.3 1.9
400 7.0 5.0 4.0 3.2
500 7.8 6.2 5.1
600 8.8 7.2
700 11.9 9.8
800 12.8
2 100 0.1
150 0.3 0.2 0.2 0.1
200 0.5 0.4 0.3 0.2
250 0.8 0.6 0.4 0.4
300 1.1 0.8 0.6 0.5
400 1.9 1.4 1.1 0.9
500 2.9 2.1 1.7 1.4
600 4.2 3.0 2.4 2.0
800 5.4 4.2 3.4
1000 8.3 6.5 5.3
1250 10.0 8.3
1500 11.9
2 1/2 150 0.1
200 0.2 0.15 0.1
250 0.3 0.2 0.2 0.1
300 0.5 0.3 0.3 0.2
400 0.8 0.6 0.5 0.4
500 1.2 0.9 0.4 0.6
600 1.7 1.3 1.0 0.8
800 3.0 2.2 1.7 1.4
1000 4.7 3.4 2.7 1.9
1250 7.5 5.4 4.2 3.5
1500 7.5 5.9 4.8
2000 10.3 8.5
2500 13.3
3 300 0.1 0.1
500 0.4 0.3 0.2 0.2
750 0.8 0.6 0.5 0.4
1000 1.5 1.1 0.8 0.7
1500 3.3 2.4 1.9 1.5
2000 5.9 4.2 3.3 2.7
2500 5.6 5.1 4.2
3000 9.4 7.4 5.1
3500 10.1 8.3
4000 13.1 10.8
4500 13.6
4 750 0.2 0.15 0.1
1000 0.4 0.3 0.2 0.2
1500 0.8 0.6 0.5 0.4
2000 1.5 1.1 0.8 0.7
2500 2.2 1.6 1.3 1.1
3000 3.2 2.3 1.8 1.5
4000 5.7 3.4 3.2 2.6
5000 6.3 5.0 4.1
6000 9.0 7.1 6.8
7000 9.7 7.9
8000 12.7 10.3
1) Free Air Inflow Volume Flow at Standard Conditions
Gases and Compressed Air
Compressed Air - Air Flow and Recommended Pipe Size
Pipe line sizing compressed air
Compressed Air - Friction Loss in Hoses
Friction loss in air hoses vs. operating pressure.
Compressed Air - Laboratory Consumption
Compressed air supply to laboratories.
Compressed Air - Pipe Line Pressure Drop Diagram
Calculate pressure drop in compressed air pipe lines with a nomograph diagram.
Compressed Air - Pipe Line Pressure Loss - Online Calculator with Metric and Imperial Units
Calculate pressure drop in compressed air pipe lines - metric and imperial units.
Pressure loss in compressed air pipe lines.
Compressed Air - Size of Pipe vs. Capacity
Air pipe lines capacities at pressure 100 psi (6.9 bar).
Compressed Air Pipe Line Capacity
Capacities of compressed air pipelines - pressure ranging 5 - 250 psi (0.5 - 17 bar).
Compressed Air Piping - Pressure Loss Diagrams, Imperial Units
Pressure drop in compressed air pipelines with applied pressure 50, 100 and 150 psi.
Compressed Air vs. Free Air - Compression Ratio
The ratio of compressed air pressure to free air pressure.
Horsepower required to Compress Air
Calculate horsepower required by air compressors.
