Compressed Air Pipe Line Capacity
Applied Pressure - psi
The diagram below can be used to estimate the flow capacity in a compressed air pipeline with pressure ranging 5 - 250 psi.
  • schedule 40 pipe
  • for pipes ranging size 1/8" to 1/2" - pressure drop 10% of applied pressure per 100 feet of pipe
  • for pipes ranging size 3/4" to 3" - pressure drop 5% of applied pressure per 100 feet of pipe
  • SCFM
Applied Pressure - bar
The diagram below can be used to estimate the flow capacity (normal standard air) in a compressed air pipeline with pressure ranging 0.5 - 17 bar.
Example - Capacity in Compressed Air Pipe Line
From the diagram above the capacity of a 1" pipe line at pressure 7 bar is approximately 60-70 liter/s.
Gases and Compressed Air
Compressed Air - Air Flow Discharge through Hoses
Discharged air flow volume through hoses with pressure ranging 30 - 90 psi.
Compressed Air - Friction Loss in Hoses
Friction loss in air hoses vs. operating pressure.
Compressed Air - Laboratory Consumption
Compressed air supply to laboratories.
Compressed Air - Pipe Line Pressure Drop Diagram
Calculate pressure drop in compressed air pipe lines with a nomograph diagram.
Compressed Air - Pipe Line Pressure Loss - Online Calculator with Metric and Imperial Units
Calculate pressure drop in compressed air pipe lines - metric and imperial units.
Compressed Air - Size of Pipe vs. Capacity
Air pipe lines capacities at pressure 100 psi (6.9 bar).
Compressed Air Pipe Lines - Pressure Loss vs. Capacity and Operating Pressure
Pressure drop in compressed air pipe lines.
Compressed Air Pipes - Fittings and Pressure Loss
Fittings in compressed air pipe lines and equivalent length pressure drop.
Compressed Air Piping - Pressure Loss Diagrams, Imperial Units
Pressure drop in compressed air pipelines with applied pressure 50, 100 and 150 psi.
Compressed Air vs. Free Air - Compression Ratio
The ratio of compressed air pressure to free air pressure.
Pipes - Relative Capacity
Relative capacity between larger and smaller pipes.
Pneumatic Piping - Pressure Loss vs. Air Flow
Pressure loss in pneumatic tubes - sizes ranging 5 - 36 mm.
