Fitting
A 90o bend equals to a 0.6 m50 mm pipe line.
Fitting | Equivalent Pipe Length (ft) | |||||||||
Nominal Pipe Size (inches) | ||||||||||
1/2" | 3/4" | 1" | 1 1/4" | 1 1/2" | 2" | 2 1/2" | 3" | 4" | 5" | |
90o bend | 0.5 | 0.7 | 0.8 | 1.2 | 1.7 | 2 | 2.6 | 3.3 | 4 | 5 |
90o elbow | 0.8 | 1.3 | 1.7 | 2.1 | 2.6 | 3.3 | 4.6 | 5.9 | 7.9 | 10.6 |
Tee - run | 0.7 | 1 | 1.3 | 1.7 | 2.3 | 2.8 | 4.4 | 4.3 | 5.3 | 6.6 |
Tee - side outlet | 1.7 | 2.3 | 4.6 | 5.9 | 7.9 | 8.9 | 11.9 | 15.1 | 18.8 | 23.1 |
Friction loss in air hoses vs. operating pressure.
Calculate pressure drop in compressed air pipe lines with a nomograph diagram.
Air pipe lines capacities at pressure 100 psi (6.9 bar).
Capacities of compressed air pipelines - pressure ranging 5 - 250 psi (0.5 - 17 bar).
