Compressed Air - Air Flow and Recommended Pipe Size
Recommended sizes for compressed air pipe lines:
Based on line presssure 90 psig (620 kPa, 6.2 bar).
  • 1 psig = 6.9 kPa = 0.069 bar
  • 1 inch = 25.4 mm
  • 1 ft (foot) = 0.3048 m
  • 1 scfm = 0.472 nl/s
Gases and Compressed Air
Air Tools - Air Consumption
Air consumption of air tools.
Pressure loss in compressed air pipe lines.
Compressed Air Pipe Lines - Pressure Loss vs. Capacity and Operating Pressure
Pressure drop in compressed air pipe lines.
Compressed Air Piping - Pressure Loss Diagrams, Imperial Units
Pressure drop in compressed air pipelines with applied pressure 50, 100 and 150 psi.
Compressed Air Receivers
Calculating air receivers capacity.
Horsepower required to Compress Air
Calculate horsepower required by air compressors.
