Pressure Converter
The calculator below can be used to convert between some common pressure units
Pressure Converting Tables
The tables below can be used to convert between some common pressure units:
| Convert from | Multiply by | ||||||
| Convert to | |||||||
| Pa (N/m2) | bar | atmosphere | mm Hg | mm H2O | m H2O | kg/cm2 | |
| Pa (N/m2) | 1 | 10-5 | 9.87×10-6 | 0.0075 | 0.1 | 10-4 | 1.02×10-5 |
| bar | 105 | 1 | 0.987 | 750 | 1.0197×104 | 10.197 | 1.0197 |
| atmosphere | 1.01×105 | 1.013 | 1 | 759.9 | 10332 | 10.332 | 1.03 |
| mm Hg | 133.3 | 1.33×10-3 | 1.32×10-3 | 1 | 13.3 | 0.013 | 1.36×10-3 |
| mm H2O | 10 | 0.000097 | 9.87×10-5 | 0.075 | 1 | 0.001 | 1.02×10-4 |
| m H2O | 104 | 0.097 | 9.87×10-2 | 75 | 1000 | 1 | 0.102 |
| kg/cm2 | 9.8×104 | 0.98 | 0.97 | 735 | 10000 | 10 | 1 |
| pound square feet | 47.8 | 4.78×10-4 | 4.72×10-4 | 0.36 | 4.78 | 4.78×10-3 | 4.88×10-4 |
| pound square inches (psi) | 6894.76 | 0.069 | 0.068 | 51.7 | 689.7 | 0.690 | 0.07 |
| inches Hg | 3377 | 0.0338 | 0.033 | 25.4 | 337.7 | 0.337 | 0.034 |
| inches H2O | 248.8 | 2.49×10-3 | 2.46×10-3 | 1.87 | 25.4 | 0.0254 | 0.0025 |
| Convert to | ||||
| pound square feet | pound square inches (psi) | inches Hg | inches H2O | |
| Pa (N/m2) | 0.021 | 1.450326×10-4 | 2.96×10-4 | 4.02×10-3 |
| bar | 2090 | 14.50 | 29.61 | 402 |
| atmosphere | 2117.5 | 14.69 | 29.92 | 407 |
| mm Hg | 2.79 | 0.019 | 0.039 | 0.54 |
| mm H2O | 0.209 | 1.45×10-3 | 2.96×10-3 | 0.04 |
| m H2O | 209 | 1.45 | 2.96 | 40.2 |
| kg/cm2 | 2049 | 14.21 | 29.03 | 394 |
| pound square feet (psf) | 1 | 0.0069 | 0.014 | 0.19 |
| pound square inches (psi) | 144 | 1 | 2.04 | 27.7 |
| inches Hg | 70.8 | 0.49 | 1 | 13.57 |
| inches H2O | 5.2 | 0.036 | 0.074 | 1 |
- 1 Torr = 1 mm Hg
Note! - pressure is "force per unit area" and commonly used pressure units like kg/cm2 and similar are in principle not correct since kg is a mass unit. Mass must be multiplied with gravity g to be a force (weight).
Example - Convert from 10 psi to Pa
From the table above - to convert from psi, multiply psi with 6894.76:
10 (psi) = 6894.76 10 (Pa) = 68947.6 Pa = 68.95 kPa
Some other Pressure Units
1 Pa (N/m2) = 0.0000102 Atmosphere (metric)
1 Pa (N/m2) = 0.0000099 Atmosphere (standard)
1 Pa (N/m2) = 0.00001 Bar
1 Pa (N/m2) = 10 Barad
1 Pa (N/m2) = 10 Barye
1 Pa (N/m2) = 0.0007501 Centimeter of mercury (0 C)
1 Pa (N/m2) = 0.0101974 Centimeter of water (4 C)
1 Pa (N/m2) = 10 Dyne/square centimeter
1 Pa (N/m2) = 0.0003346 Foot of water (4 C)
1 Pa (N/m2) = 10-9 Gigapascal
1 Pa (N/m2) = 0.01 Hectopascal
1 Pa (N/m2) = 0.0002953 Inch of mercury (0 C)
1 Pa (N/m2) = 0.0002961 Inch of mercury (15.56 C)
1 Pa (N/m2) = 0.0040186 Inch of water (15.56 C)
1 Pa (N/m2) = 0.0040147 Inch of water (4 C)
1 Pa (N/m2) = 0.0000102 Kilogram force/centimetre2
1 Pa (N/m2) = 0.0010197 Kilogram force/decimetre2
1 Pa (N/m2) = 0.101972 Kilogram force/meter2
1 Pa (N/m2) = 10-7 Kilogram force/millimeter2
1 Pa (N/m2) = 10-3 Kilopascal
1 Pa (N/m2) = 10-7 Kilopound force/square inch
1 Pa (N/m2) = 10-6 Megapascal
1 Pa (N/m2) = 0.000102 Meter of water (4 C)
1 Pa (N/m2) = 10 Microbar (barye, barrie)
1 Pa (N/m2) = 7.50062 Micron of mercury (millitorr)
1 Pa (N/m2) = 0.01 Millibar
1 Pa (N/m2) = 0.0075006 Millimeter of mercury (0 C)
1 Pa (N/m2) = 0.10207 Millimeter of water (15.56 C)
1 Pa (N/m2) = 0.10197 Millimeter of water (4 C)
1 Pa (N/m2) =7.5006 Millitorr
1 Pa (N/m2) = 1 Newton/square meter
1 Pa (N/m2) = 32.1507 Ounce force (avdp)/square inch
1 Pa (N/m2) = 0.0208854 Pound force/square foot
1 Pa (N/m2) = 0.000145 Pound force/square inch
1 Pa (N/m2) = 0.671969 Poundal/square foot
1 Pa (N/m2) = 0.0046665 Poundal/square inch
1 Pa (N/m2) = 0.0000099 Standard atmosphere
1 Pa (N/m2) = 0.0000093 Ton (long)/foot2
1 Pa (N/m2) = 10-7 Ton (long)/inch2
1 Pa (N/m2) = 0.0000104 Ton (short)/foot2
1 Pa (N/m2) = 0.64×10-7 Ton/inch2
1 Pa (N/m2) = 0.0075006 Torr
psi to bar Nomogram
Download and print psi to bar Converter!
psi to kPa Nomogram
• Basics
• Pumps
Barometric Pressure - Pressure in psi, psf and kPa
Convert between barometric pressure inches Hg, psi and psf.
Hazen-Williams Pressure Loss Equation
The Hazen-Williams equation can be used to calculate the pressure drop (psi) or friction loss in pipes or tubes.
Pressure
Pressure Energy
Calculate the potential of pressure energy in a incompressible fluid.
Pressure to Head Unit Converter
Pressure vs. head units - like lb/in2, atm, inches mercury, bars, Pa and more.
Pump Head and Pressure: Conversion, Calculations, and Charts
Converting head (ft or m) to pressure (psi or bar, kg/cm2) and vice versa.
Steel Pipes Schedule 40 - Pressure Loss
Water flow and pressure loss in schedule 40 steel pipes - Imperial and SI units - gallons per minute, liters per second and cubic meters per hour.
Common converting units for Acceleration, Area, Density, Energy, Energy per unit mass, Force, Heat flow rate, Heat flux, Heat generation per unit volume and many more.
Unit Factor Method
