Pressure to Head Unit Converter
Convert between commonly used units for pressure and head:
from | Multiply by | |||||
to | ||||||
lb/in2 | lb/ft2 | Atm | kg/cm2 | kg/m2 | in. water (68 oF) | |
lb/in2 | 1 | 144 | 0.068046 | 0.070307 | 703.070 | 27.7276 |
lb/ft2 | 0.0069444 | 1 | 0.000473 | 0.000488 | 4.88241 | 0.1926 |
Atm. | 14.696 | 2116.22 | 1 | 1.0332 | 10332.27 | 407.484 |
kg/cm2 | 14.2233 | 2048.155 | 0.96784 | 1 | 10000 | 394.38 |
kg/m2 | 0.001422 | 0.204768 | 0.0000968 | 0.0001 | 1 | 0.03944 |
in. water (68 oF) |
0.036092 | 5.1972 | 0.002454 | 0.00253 | 25.375 | 1 |
ft. water (68 oF) |
0.432781 | 62.3205 | 0.029449 | 0.03043 | 304.275 | 12 |
in. mercury, inHg (31 oF) | 0.491154 | 70.7262 | 0.033421 | 0.03453 | 345.316 | 13.6185 |
mm mercury, inHg (31 oF) | 0.0193368 | 2.78450 | 0.0013158 | 0.0013595 | 13.59509 | 0.53616 |
Bars | 14.5038 | 2088.55 | 0.98692 | 1.01972 | 10197.2 | 402.156 |
MPa | 145.038 | 20885.5 | 9.8692 | 10.1972 | 101972.0 | 4021.56 |
to | |||||
ft. water (68 oF) | in. mercury (31 oF) | mm mercury (31 oF) | Bars | MPa | |
lb/in2 | 2.3106 | 2.03602 | 51.7150 | 0.06895 | 0.006895 |
lb/ft2 | 0.01605 | 0.014139 | 0.35913 | 0.000479 | 0.0000479 |
Atm | 33.9570 | 29.921 | 760 | 1.01325 | 0.101325 |
kg/cm2 | 32.8650 | 28.959 | 735.559 | 0.98067 | 0.098067 |
kg/m2 | 0.003287 | 0.002896 | 0.073556 | 0.000098 | 0.0000098 |
in. water (68 oF) |
0.08333 | 0.073430 | 1.8651 | 0.00249 | 0.000249 |
ft. water (68 oF) |
1 | 0.88155 | 22.3813 | 0.029839 | 0.0029839 |
1.1349 | 1 | 25.40005 | 0.033864 | 0.0033864 |
0.044680 | 0.03937 | 1 | 0.001333 | 0.0001333 |
Bars | 33.5130 | 29.5300 | 750.062 | 1 | 0.10 |
MPa | 335.130 | 295.300 | 7500.62 | 10.0 | 1 |
Example - Convert Head in inHg to Pressure MPa
Atmospheric pressure is measured to 29.92 inHg. According the table above - to convert this value to MPa it must be multiplied with 0.0033864.
(29.92 inHg) 0.0033864 = 0.1013 MPa (1.013×105 Pa)
• Basics
• Pumps
Barometric Pressure - Pressure in psi, psf and kPa
Convert between barometric pressure inches Hg, psi and psf.
Centrifugal Pumps
Hot Water Systems - Equivalent Length vs. Fittings Resistance
Equivalent length of fittings like bends, returns, tees and valves in hot water heating systems - equivalent length in feet and meter.
Pipe and Duct Systems - Total Head Loss
Major and minor loss in pipes, tubes and duct systems.
Pressure
Convert between pressure units like Pa, bar, atmosphere, pound square feet, psi and more.
Pump Head and Pressure: Conversion, Calculations, and Charts
Converting head (ft or m) to pressure (psi or bar, kg/cm2) and vice versa.
Pumps - NPSH (Net Positive Suction Head)
An introduction to pumps and the Net Positive Suction Head (NPSH).
Pumps - Suction Head vs. Altitude
The suction head of a water pump is affected by its operating altitude.
Pumps and Fans - Energy Equation and Head Rise
The energy equation can be used to calculate the head rise in pumps and fans.
Static Pressure vs. Head
Unit Factor Method
Water Pressure vs. Head
Pressure in pounds per square inch (psi) vs. head in feet of water (ft h2o).
