Hot Water Systems - Equivalent Length vs. Fittings Resistance
The minor loss in a system component can be converted to the "equivalent length" of a pipe or tube that would give the same major head loss.
Equivalent lengths of fittings like
  • elbows - regular 90o, long radius 90o, regular 45o
  • tees - line flow and branch flow
  • return bends - regular and long radius
  • valves - globe, gate, angle and swing check
  • strainers
in hot water piping systems are indicated in the tables below.
Screw Fittings - equivalent length in feet
Equivalent length (in feet) of straight pipe for fittings like bends, returns, tees and valves. (Pipe size in inches)
Screw Fittings - equivalent length in metre
Equivalent length (in metre) of straight pipe for fittings like bends, returns, tees and valves.
Flanged Fittings - equivalent length in feet
Flanged Fittings - equivalent length in metre
Fluid Flow and Pressure Loss
Heating
Heating systems - capacity and design of boilers, pipelines, heat exchangers, expansion systems and more.
ASTM F876 - PEX Tube - Dimensions
Dimensions of PEX tubes.
Copper Tubes - Equivalent Length Pressure Loss in Fittings and Valves
Copper tube fittings and equivalent lengths - in feets of straight tube.
Equivalent Length Method - Minor Pressure Loss in Piping Systems
Calculate minor pressure loss in piping systems with the Equivalent Pipe Length Method.
Friction Loss in Steel, Copper and Plastic Pipes
Friction head loss (ft/100 ft) vs. water flow in steel, copper and PVC plastic pipes.
Hazen-Williams Friction Loss Equation - calculating Head Loss in Water Pipes
Hot Water Heating Systems - Online Design Application
Equivalent length of fittings like bends, returns, tees and valves in hot water heating systems - equivalent length in feet and meter.
Pipe and Tube System Components - Minor (Dynamic) Loss Coefficients
Minor loss coefficients for components used in pipe and tube systems.
Plastic Pipes - Friction Head Loss vs. Water Flow
Pressure to Head Unit Converter
Pressure vs. head units - like lb/in2, atm, inches mercury, bars, Pa and more.
PVC Pipes - Equivalent Length and Pressure Loss in Fittings
Minor loss in PVC and CPVC fittings expressed as equivalent length of straight pipe.
PVC Pipes Schedule 40 - Friction Loss vs. Water Flow
Water flow in thermoplastic PVC and CPVC pipes Schedule 40 - friction loss (ft/100 ft, psi/100 ft) and flow velocities at dimensions ranging 1/2 to 16 inches.
PVC Pipes Schedule 80 - Friction Loss vs. Water Flow
Water flow in thermoplastic PVC and CPVC pipes Schedule 80 - friction loss (ft/100 ft, psi/100 ft) and flow velocities at dimensions ranging 1/2 to 16 inches.
