ASTM F876 - PEX Tube - Dimensions
Dimensions of PEX SDR 9 (CTS) tube according ASTM F876 Standard Specification for Crosslinked Polyethylene (PEX) Tubing:
Nominal Pipe Size CTS (inches) | Average Outside Diameter (inches) | Min. Wall Thickness (inches) | Average Inside Diameter (inches) |
1/2 | 0.625 | 0.070 | 0.510 |
3/4 | 0.875 | 0.097 | 0.681 |
1 | 1.125 | 0.125 | 0.875 |
1 1/4 | 1.375 | 0.153 | 1.069 |
1 1/2 | 1.625 | 0.181 | 1.263 |
2 | 2.125 | 0.236 | 1.653 |
2 2 1/2 | 2.625 | 0.292 | 2.041 |
3 | 3.125 | 0.347 | 2.431 |
BS 7291 - Thermoplastics Pipes for Hot and Cold Water - Dimensions
Dimensions of thermoplastic pipes - PEX and PB according BS 7291.
Chemical Resistance of Thermoplastics
Chemical resistance of thermoplastics like ABS, CPVC, PP, PVC, PE, PB, PVDF and PEX piping materials to chemicals and products ranging beer, acryl acid, diesel oil and many more.
Friction Loss in Steel, Copper and Plastic Pipes
Friction head loss (ft/100 ft) vs. water flow in steel, copper and PVC plastic pipes.
Hot Water Heating System Online Design Application
Hot Water Systems - Equivalent Length vs. Fittings Resistance
Equivalent length of fittings like bends, returns, tees and valves in hot water heating systems - equivalent length in feet and meter.
Plastic Pipes - Friction Head Loss vs. Water Flow
Thermoplastic Pipes - Strength Derating vs. Temperature
Increased temperatures derates the strength of thermoplastic piping materials.
Water Distribution Pipes - Materials
Materials used in water distribution pipes.
Water Supply Lines - Sizing
Sizing water supply service and distribution lines based on Water Supply Fixture Units (WSFU).
