BS 7291 - Thermoplastics Pipes for Hot and Cold Water - Dimensions
BS 7291 Thermoplastics pipe and fitting systems for hot and cold water for domestic purposes and heating installations in buildings. General requirements  - is divided in four parts
  • Part 1 Thermoplastics pipes and associated fittings for hot and cold water for domestic purposes and heating installations in buildings. General requirements
  • Part 2 Thermoplastics pipes and associated fittings for hot and cold water for domestic purposes and heating installations in buildings. Specification for polybutylene (PB) pipes and associated fittings
  • Part 3 Thermoplastics pipes and associated fittings for hot and cold water for domestic purposes and heating installations in buildings. Specification for crosslinked polyethylene (PE-X) pipes and associated fittings
  • Part 4 Thermoplastics pipes and associated fittings for hot and cold water for domestic purposes and heating installations in buildings. Specification for chlorinated polyvinyl chloride (PVC-C) pipes and associated fittings and solvent cement
Dimensions Part 2 - PB pipes
PB pipes consistent with EN 1057
BS 7291 - Thermoplastics Pipes for Hot and Cold Water - Dimensions - PB pipes consistent with EN 1057
Nominal Size
(mm)
Mean Outside Diameter (mm)
Wall Thickness (mm)
Min.Max.Min.Max.
10 9.9 10.1 1.5 1.8
12 11.9 12.1 1.5 1.8
15 14.9 15.1 1.5 2.0
18 17.9 18.1 1.8 2.0
22 21.9 22.1 2.0 2.3
28 27.9 28.1 2.6 2.9
35 34.9 35.1 3.2 3.5
PB pipes consistent with ISO 4065
BS 7291 - Thermoplastics Pipes for Hot and Cold Water - Dimensions - PB pipes consistent with ISO 4065
Nominal Size
(mm)
Wall Thickness (mm)
Min.Max.Min.Max.
10 10.0 10.2 1.5 1.8
12 12.0 12.3 1.5 1.8
16 16.0 16.3 1.5 2.1
20 20.0 20.3 1.9 2.2
25 25.0 25.3 2.3 2.7
32 32.0 32.3 2.9 3.3
40 40.0 40.4 3.7 4.2
50 50.0 50.5 4.6 5.2
63 63.0 63.6 5.8 6.5
75 75.0 75.7 6.8 7.6
90 90.0 90.9 8.2 9.2
110 110. 111.0 10.0 11.2
Dimensions
ASTM F876 - PEX Tube - Dimensions
Dimensions of PEX tubes.
Chemical Resistance of Thermoplastics
Chemical resistance of thermoplastics like ABS, CPVC, PP, PVC, PE, PB, PVDF and PEX piping materials to chemicals and products ranging beer, acryl acid, diesel oil and many more.
EN 1451 - Polypropylene (PP) Plastics Piping Systems for Soil and Waste Discharge - Dimensions
Plastic piping systems for soil and waste discharge (low and high temperature) within the building structure.
Friction Loss in Steel, Copper and Plastic Pipes
Friction head loss (ft/100 ft) vs. water flow in steel, copper and PVC plastic pipes.
Plastic Pipes - Friction Head Loss vs. Water Flow
Thermoplastic Pipes - Strength Derating vs. Temperature
Increased temperatures derates the strength of thermoplastic piping materials.
Water Supply Lines - Sizing
Sizing water supply service and distribution lines based on Water Supply Fixture Units (WSFU).
