Flow Rate (gal/min) | Friction Loss (ft/100 ft) | ||
Steel Pipe Schedule 40 | Copper Pipe Type L | PVC Pipe Schedule 40 | |
100 | 0.7 | 0.7 | 0.6 |
150 | 1.4 | 1.5 | 1.3 |
200 | 2.4 | 2.5 | 2.2 |
250 | 3.6 | 3.7 | 3.3 |
300 | 5.0 | 5.1 | 4.6 |
400 | 8.7 | 8.6 | 7.8 |
150 | 0.5 | 0.8 | 0.4 |
200 | 0.8 | 0.8 | 0.7 |
250 | 1.2 | 1.3 | 1.1 |
300 | 1.6 | 1.8 | 1.5 |
400 | 2.8 | 2.9 | 2.6 |
500 | 4.3 | 4.4 | 3.9 |
150 | 0.2 | 0.2 | 0.2 |
200 | 0.3 | 0.4 | 0.3 |
250 | 0.5 | 0.5 | 0.4 |
300 | 0.7 | 0.7 | 0.6 |
400 | 1.1 | 1.2 | 1.1 |
500 | 1.7 | 1.8 | 1.6 |
750 | 3.7 | 3.8 | 3.4 |
1000 | 6.3 | 6.5 | 5.8 |
Steel Pipe Schedule 40 | PVC Pipe Schedule 40 | |
150 | 0.05 | 0.05 |
200 | 0.08 | 0.08 |
250 | 0.12 | 0.12 |
300 | 0.17 | 0.16 |
400 | 0.3 | 0.28 |
500 | 0.4 | 0.4 |
750 | 0.9 | 0.9 |
1000 | 1.6 | 1.5 |
1250 | 2.4 | 2.3 |
1500 | 3.5 | 3.2 |
2000 | 6.0 | 5.5 |
200 | 0.03 | 0.03 |
250 | 0.04 | 0.04 |
300 | 0.06 | 0.05 |
400 | 0.1 | 0.09 |
500 | 0.15 | 0.14 |
750 | 0.3 | 0.3 |
1000 | 0.5 | 0.5 |
1250 | 0.8 | 0.8 |
1500 | 1.1 | 1.1 |
2000 | 1.9 | 1.8 |
400 | 0.04 | 0.04 |
500 | 0.06 | 0.06 |
750 | 0.13 | 0.13 |
1000 | 0.2 | 0.21 |
1250 | 0.3 | 0.32 |
1500 | 0.5 | 0.45 |
2000 | 0.8 | 0.8 |
3000 | 1.7 | 1.6 |
Standard sizes specification for seamless red brass pipes.
Dimensions of PEX tubes.
Dimensions of thermoplastic pipes - PEX and PB according BS 7291.
Equivalent length of fittings like bends, returns, tees and valves in hot water heating systems - equivalent length in feet and meter.
Pressure drop diagrams for PTFE, PP, PFA and PVDF lined pipes.
Symbol codes and labeling used for recycling plastic products like bottles, containers and packagin.
Friction loss (psi/100 ft) and velocity for water flow in plastic PVC pipe schedule 40.
Friction loss and velocity diagrams - in imperial (psi/100 ft, ft/s) and SI (Pa/100m, m/s) units.
