Plastics - Recycling Codes and Labeling
Recycling Code | Products |
PETE 1) Polyethylene Terephthalate Ethylene - used for soda, soft drink, water, juice, water, detergent, cleaner and peanut butter bottles and containers |
HDPE 1) High Density Polyethylene - used in opaque plastic milk and water jugs and bottles, bleach, detergent and shampoo bottles and some plastic bags. Oil and motor oil bottles and toys |
PVC or V 2) Vinyl or Polyvinyl Chloride - used for food or cling wrap, some plastic squeeze bottles, cooking oil and peanut butter jars, detergent and window cleaner bottles, vegetable oil bottles, blister packages, window cleaner bottles |
LDPE 1) Low Density Polyethylene - used in grocery store plastic bags, most plastic shrink wraps and some bottles, garment bags, fixible film packaging |
PP 1) Polypropylene - used in refrigerated containers, some bags, most bottle tops, some carpets, most Rubbermaid, deli soup, syrup and yogurt containers, straws and other clouded plastic containers, including baby bottles, yogurt tubs, straws |
PS 2) Polystyrene - used in Styrofoam food trays, carry-out containers, egg cartons, disposable cups and bowls, carry-out containers and opaque plastic cutlery, throwaway utensils, meat packaging |
Others Usually layered or mixed plastics - can not be recycled. Often polycarbonate - used in most plastic baby bottles, water bottles, metal food can liners, clear plastic sippy cups and some clear plastic cutlery. Bio-based plastics may be labeled #7. |
1)Preferred with food
2) Should be avoided in use with food
Fiberglass Pipes - common Standards
Commonly used standards for fiberglass pipes and their applications.
Friction Loss in Steel, Copper and Plastic Pipes
Friction head loss (ft/100 ft) vs. water flow in steel, copper and PVC plastic pipes.
Plastic Pipes - Friction Head Loss vs. Water Flow
Plastics - Abbreviations
Commonly used plastic abbreviations.
Thermal conductivity of plastics.
Polymers - Physical Properties
Densities, tensile strength, elongation, Youngs modulus and Brinell hardness.
Thermoplastic Pipes - Strength Derating vs. Temperature
Increased temperatures derates the strength of thermoplastic piping materials.
