Lined Pipes - Pressure Loss vs. Water Flow
The diagrams below indicates the pressure loss for water flow in PTFE-lined steel pipes schedule 40.
The pressure drop calculations are made with the D'Arcy-Weisbach Equation.
Pressure Drop - Imperial Units
  • 1 gal (US)/min =6.30888×10-5 m3/s = 0.227 m3/h = 0.06309 dm3(litre)/s = 2.228×10-3 ft3/s = 0.1337 ft3/min
  • 1 ft/s = 0.3048 m/s
  • 1 psi (lb/in2) = 6,894.8 Pa (N/m2) = 6.895×10-3 N/mm2 = 6.895×10-2 bar = 27.71 in H2O at 61 oF (16.7 oC) = 703.1 mm H2O at 61 oF (16.7 oC) = 2.0416 in mercury at 61 oF (16.7 oC) = 51.8 mm mercury at 61 oF (16.7 oC) = 703.6 kg/m2 = 2.307 Ft. H2O
Pressure Drop - SI units
  • 1 Pa = 10-6 N/mm2 = 10-5 bar = 0.1020 kp/m2 = 1.02×10-4 m H2O = 9.869×10-6 atm = 1.45×10-4 psi (lbf/in2)
  • 1 liter/s = 10-3 m3/s = 3.6 m3/h = 0.03532 ft3/s = 2.1189 ft3/min (cfm) = 13.200 Imp.gal (UK)/min = 15.852 gal (US)/min = 792 Imp. gal (UK)/h
The diagram above is based on the inside thickness of schedule 40 steel pipes with PTFE as the lining material. Common thickness of other lining materials:
Lined Pipes - Lining Materials
Lining MaterialCommon Thickness of Lining Material (inches)
Pipe Diameter (inches)
11 1/223468
PTFE*) 0.130 0.150 0.160 0.160 0.160 0.275 0.310
PP 0.135 0.160 0.175 0.175 0.210 0.220 0.220
PFA 0.113 0.114 0.114 0.130 0.150 0.145 0.140
PVDF 0.125 0.125 0.125 0.125 0.145 0.160 0.185
  • PTFE - PolyTetraFluoroEthylene
  • PP - PolyPropylene
  • PFA - Perfluoroalkoxy Fluorocarbon
  • PVDF - Polyvinylidene Fluoride
*) used in the diagrams above
Cement Lined Carbon Steel Pipes
Dimensions of cement lined carbon steel pipes.
Friction Loss in Steel, Copper and Plastic Pipes
Friction head loss (ft/100 ft) vs. water flow in steel, copper and PVC plastic pipes.
Hazen-Williams Water Flow Formula: Head Loss, Data, Charts & Calculator
Plastic Pipes - Friction Head Loss vs. Water Flow
PVC Pipes - Equivalent Length and Pressure Loss in Fittings
Minor loss in PVC and CPVC fittings expressed as equivalent length of straight pipe.
PVC Pipes Schedule 40 - Friction Loss vs. Water Flow
Water flow in thermoplastic PVC and CPVC pipes Schedule 40 - friction loss (ft/100 ft, psi/100 ft) and flow velocities at dimensions ranging 1/2 to 16 inches.
PVC Pipes Schedule 40 - Friction Loss vs. Water Flow Diagrams
Friction loss (psi/100 ft) and velocity for water flow in plastic PVC pipe schedule 40.
