Schedule 80
Note! Velocities should in general not exceed 5 feet per second to avoid noise and damaging wear and tear of pipes and fittings.
The values can be used to calculate minor pressure loss with the Equivalent Pipe Length Method.
Volume Flow (gal/min) | Volume Flow (gal/hr) | Velocity (ft/sec) | Friction Head (ftH2O/100 ft) | Friction Loss (psi/100 ft) |
1 | 60 | 1.5 | 4.0 | 1.7 |
2 | 120 | 3.0 | 8.0 | 3.5 |
5 | 300 | 7.4 | 45.2 | 19.6 |
7 | 420 | 10.3 | 83.1 | 36.0 |
Volume Flow (gal/min) | Volume Flow (gal/hr) | Velocity (ft/sec) | Friction Head (ft/100ft) | Friction Loss (psi/100 ft) |
1 | 60 | 0.7 | 0.9 | 0.4 |
2 | 120 | 1.6 | 1.7 | 0.7 |
5 | 300 | 3.9 | 9.7 | 4.2 |
7 | 420 | 5.5 | 11.8 | 7.7 |
10 | 600 | 7.8 | 33.8 | 14.7 |
15 | 900 | 11.8 | 71.7 | 31.1 |
2 | 120 | 0.9 | 0.9 | 0.4 |
5 | 300 | 2.3 | 2.6 | 1.2 |
7 | 420 | 3.3 | 5.0 | 2.2 |
10 | 600 | 4.7 | 9.6 | 4.2 |
15 | 900 | 7.0 | 20.4 | 8.8 |
20 | 1200 | 9.4 | 34.7 | 15.0 |
25 | 1500 | 11.7 | 52.4 | 22.7 |
30 | 1800 | 14.0 | 73.5 | 31.8 |
2 | 120 | 0.5 | 0.2 | 0.1 |
5 | 300 | 1.3 | 0.7 | 0.3 |
7 | 420 | 1.8 | 1.2 | 0.5 |
10 | 600 | 2.6 | 2.3 | 1.0 |
15 | 900 | 3.9 | 4.9 | 2.1 |
20 | 1200 | 5.2 | 8.3 | 3.6 |
25 | 1500 | 6.5 | 12.6 | 5.4 |
30 | 1800 | 7.8 | 17.6 | 7.6 |
35 | 2100 | 9.1 | 23.4 | 10.1 |
40 | 2400 | 10.4 | 30.0 | 13.0 |
45 | 2700 | 11.7 | 37.3 | 16.1 |
50 | 3000 | 13.0 | 45.3 | 19.6 |
2 | 120 | 0.4 | 0.1 | 0.04 |
5 | 300 | 0.9 | 0.3 | 0.1 |
7 | 420 | 1.3 | 0.6 | 0.2 |
10 | 600 | 1.9 | 1.0 | 0.5 |
15 | 900 | 2.8 | 2.2 | 1.0 |
20 | 1200 | 3.8 | 3.8 | 1.6 |
25 | 1500 | 4.7 | 5.7 | 2.5 |
30 | 1800 | 5.6 | 8.0 | 3.4 |
35 | 2100 | 6.6 | 10.6 | 4.6 |
40 | 2400 | 7.5 | 13.6 | 5.9 |
45 | 2700 | 8.4 | 16.9 | 7.3 |
50 | 3000 | 9.4 | 20.5 | 8.9 |
60 | 3600 | 11.3 | 28.7 | 12.4 |
5 | 300 | 0.6 | 0.1 | 0.04 |
7 | 420 | 0.8 | 0.2 | 0.07 |
10 | 600 | 1.1 | 0.3 | 0.1 |
15 | 900 | 1.7 | 0.6 | 0.3 |
20 | 1200 | 2.2 | 1.1 | 0.5 |
25 | 1500 | 2.8 | 1.6 | 0.7 |
30 | 1800 | 3.4 | 2.3 | 1.0 |
35 | 2100 | 3.9 | 3.0 | 1.3 |
40 | 2400 | 4.5 | 3.8 | 1.7 |
45 | 2700 | 5.0 | 4.8 | 2.1 |
50 | 3000 | 5.6 | 5.8 | 2.5 |
60 | 3600 | 6.7 | 8.1 | 3.5 |
70 | 4200 | 7.8 | 10.8 | 4.7 |
75 | 4500 | 8.4 | 12.3 | 5.3 |
80 | 4800 | 8.9 | 13.8 | 6.0 |
90 | 5400 | 10.1 | 17.2 | 7.5 |
100 | 6000 | 11.2 | 20.9 | 9.1 |
5 | 300 | 0.4 | 0.05 | 0.02 |
7 | 420 | 0.5 | 0.07 | 0.03 |
10 | 600 | 0.8 | 0.1 | 0.05 |
15 | 900 | 1.2 | 0.3 | 0.1 |
20 | 1200 | 1.6 | 0.4 | 0.2 |
25 | 1500 | 2.0 | 0.7 | 0.3 |
30 | 1800 | 2.3 | 0.9 | 0.4 |
35 | 2100 | 2.7 | 1.3 | 0.5 |
40 | 2400 | 3.1 | 1.6 | 0.7 |
45 | 2700 | 3.5 | 2.0 | 0.9 |
50 | 3000 | 3.9 | 2.4 | 1.1 |
60 | 3600 | 4.7 | 3.4 | 1.5 |
70 | 4200 | 5.5 | 4.5 | 2.0 |
75 | 4500 | 5.9 | 5.1 | 2.2 |
80 | 4800 | 6.2 | 5.8 | 2.5 |
90 | 5400 | 7.0 | 7.2 | 3.1 |
100 | 6000 | 7.8 | 8.7 | 3.8 |
125 | 7500 | 9.8 | 13.2 | 5.7 |
150 | 9000 | 11.7 | 18.5 | 8.0 |
5 | 300 | 0.3 | 0.02 | 0.01 |
7 | 420 | 0.4 | 0.03 | 0.01 |
10 | 600 | 0.5 | 0.04 | 0.02 |
15 | 900 | 0.8 | 0.09 | 0.04 |
20 | 1200 | 1.0 | 0.2 | 0.07 |
25 | 1500 | 1.3 | 0.2 | 0.1 |
30 | 1800 | 1.5 | 0.3 | 0.1 |
35 | 2100 | 1.7 | 0.4 | 0.2 |
40 | 2400 | 2.0 | 0.5 | 0.2 |
45 | 2700 | 2.2 | 0.7 | 0.3 |
50 | 3000 | 2.5 | 0.8 | 0.4 |
60 | 3600 | 3.0 | 1.1 | 0.5 |
70 | 4200 | 3.5 | 1.5 | 0.7 |
75 | 4500 | 3.7 | 1.7 | 0.7 |
80 | 4800 | 4.0 | 1.9 | 0.8 |
90 | 5400 | 4.5 | 2.4 | 1.0 |
100 | 6000 | 5.0 | 2.9 | 1.3 |
125 | 7500 | 6.2 | 4.4 | 1.9 |
150 | 9000 | 7.5 | 6.2 | 2.7 |
175 | 10500 | 8.7 | 8.3 | 3.6 |
200 | 12000 | 10.0 | 10.6 | 4.6 |
250 | 15000 | 12.5 | 16.0 | 6.9 |
20 | 1200 | 0.6 | 0.04 | 0.02 |
25 | 1500 | 0.7 | 0.06 | 0.03 |
30 | 1800 | 0.9 | 0.08 | 0.04 |
35 | 2100 | 1.0 | 0.1 | 0.05 |
40 | 2400 | 1.2 | 0.1 | 0.06 |
45 | 2700 | 1.3 | 0.2 | 0.07 |
50 | 3000 | 1.4 | 0.2 | 0.09 |
60 | 3600 | 1.7 | 0.3 | 0.1 |
70 | 4200 | 2.0 | 0.4 | 0.2 |
75 | 4500 | 2.2 | 0.5 | 0.2 |
80 | 4800 | 2.3 | 0.5 | 0.2 |
90 | 5400 | 2.6 | 0.6 | 0.3 |
100 | 6000 | 2.9 | 0.8 | 0.3 |
125 | 7500 | 3.6 | 1.2 | 0.5 |
150 | 9000 | 4.3 | 1.6 | 0.7 |
175 | 10500 | 5.0 | 2.2 | 0.9 |
200 | 12000 | 5.7 | 2.8 | 1.2 |
250 | 15000 | 7.2 | 4.2 | 1.8 |
300 | 18000 | 8.6 | 5.8 | 2.5 |
350 | 21000 | 10.0 | 7.8 | 3.4 |
400 | 24000 | 11.5 | 9.9 | 4.3 |
30 | 1800 | 0.5 | 0.03 | 0.01 |
35 | 2100 | 0.6 | 0.04 | 0.02 |
40 | 2400 | 0.7 | 0.04 | 0.02 |
45 | 2700 | 0.8 | 0.06 | 0.03 |
50 | 3000 | 0.9 | 0.07 | 0.03 |
60 | 3600 | 1.1 | 0.1 | 0.04 |
70 | 4200 | 1.3 | 0.1 | 0.06 |
75 | 4500 | 1.3 | 0.1 | 0.06 |
80 | 4800 | 1.4 | 0.2 | 0.07 |
90 | 5400 | 1.6 | 0.2 | 0.09 |
100 | 6000 | 1.8 | 0.2 | 0.1 |
125 | 7500 | 2.3 | 0.4 | 0.2 |
150 | 9000 | 2.7 | 0.5 | 0.2 |
175 | 10500 | 3.2 | 0.7 | 0.3 |
200 | 12000 | 3.6 | 0.9 | 0.4 |
250 | 15000 | 4.5 | 1.3 | 0.6 |
300 | 18000 | 5.4 | 1.9 | 0.8 |
350 | 21000 | 6.3 | 2.5 | 1.1 |
400 | 24000 | 7.2 | 3.2 | 1.4 |
450 | 27000 | 8.1 | 4.0 | 1.7 |
500 | 30000 | 9.0 | 4.8 | 2.1 |
50 | 3000 | 0.6 | 0.03 | 0.01 |
60 | 3600 | 0.8 | 0.04 | 0.02 |
70 | 4200 | 0.9 | 0.05 | 0.02 |
75 | 4500 | 0.9 | 0.06 | 0.03 |
80 | 4800 | 1.0 | 0.07 | 0.03 |
90 | 5400 | 1.1 | 0.08 | 0.04 |
100 | 6000 | 1.3 | 0.1 | 0.04 |
125 | 7500 | 1.6 | 0.2 | 0.07 |
150 | 9000 | 1.9 | 0.2 | 0.1 |
175 | 10500 | 2.2 | 0.3 | 0.1 |
200 | 12000 | 2.5 | 0.4 | 0.2 |
250 | 15000 | 3.1 | 0.6 | 0.2 |
300 | 18000 | 3.8 | 0.8 | 0.3 |
350 | 21000 | 4.4 | 1.0 | 0.5 |
400 | 24000 | 5.0 | 1.3 | 0.6 |
450 | 27000 | 5.6 | 1.7 | 0.7 |
500 | 30000 | 6.3 | 2.0 | 0.9 |
750 | 45000 | 9.4 | 4.3 | 1.8 |
1000 | 60000 | 12.5 | 7.2 | 3.1 |
125 | 7500 | 0.9 | 0.05 | 0.02 |
150 | 9000 | 1.1 | 0.05 | 0.02 |
175 | 10500 | 1.3 | 0.08 | 0.03 |
200 | 12000 | 1.4 | 0.09 | 0.04 |
250 | 15000 | 1.8 | 0.1 | 0.06 |
300 | 18000 | 2.1 | 0.2 | 0.09 |
350 | 21000 | 2.5 | 0.3 | 0.1 |
400 | 24000 | 2.9 | 0.3 | 0.2 |
450 | 27000 | 3.2 | 0.4 | 0.2 |
500 | 30000 | 3.6 | 0.5 | 0.2 |
750 | 45000 | 5.4 | 1.1 | 0.5 |
1000 | 60000 | 7.1 | 1.8 | 0.8 |
1250 | 75000 | 8.9 | 2.8 | 1.2 |
1500 | 90000 | 10.7 | 4.0 | 1.7 |
200 | 12000 | 0.9 | 0.04 | 0.02 |
250 | 15000 | 1.1 | 0.05 | 0.02 |
300 | 18000 | 1.4 | 0.07 | 0.03 |
350 | 21000 | 1.6 | 0.09 | 0.04 |
400 | 24000 | 1.8 | 0.1 | 0.05 |
450 | 27000 | 2.0 | 0.1 | 0.06 |
500 | 30000 | 2.3 | 0.2 | 0.07 |
750 | 45000 | 3.4 | 0.4 | 0.2 |
1000 | 60000 | 4.5 | 0.6 | 0.3 |
1250 | 75000 | 5.7 | 0.9 | 0.4 |
1500 | 90000 | 6.8 | 1.3 | 0.6 |
2000 | 120000 | 9.1 | 2.2 | 1.0 |
2500 | 150000 | 11.3 | 3.3 | 1.4 |
350 | 21000 | 1.1 | 0.04 | 0.02 |
400 | 24000 | 1.3 | 0.05 | 0.02 |
450 | 27000 | 1.4 | 0.06 | 0.03 |
500 | 30000 | 1.6 | 0.07 | 0.03 |
750 | 45000 | 2.4 | 0.2 | 0.07 |
1000 | 60000 | 3.2 | 0.3 | 0.1 |
1250 | 75000 | 4.0 | 0.4 | 0.2 |
1500 | 90000 | 4.8 | 0.6 | 0.2 |
2000 | 120000 | 6.4 | 0.9 | 0.4 |
2500 | 150000 | 8.0 | 1.4 | 0.6 |
3000 | 180000 | 9.6 | 2.0 | 0.9 |
3500 | 210000 | 11.2 | 2.7 | 1.2 |
4000 | 240000 | 12.8 | 3.4 | 1.5 |
500 | 30000 | 1.3 | 0.04 | 0.02 |
750 | 45000 | 2.0 | 0.09 | 0.04 |
1000 | 60000 | 2.6 | 0.2 | 0.07 |
1250 | 75000 | 3.3 | 0.3 | 0.1 |
1500 | 90000 | 3.9 | 0.3 | 0.2 |
2000 | 120000 | 5.2 | 0.6 | 0.3 |
2500 | 150000 | 6.5 | 0.9 | 0.4 |
3000 | 180000 | 7.9 | 1.2 | 0.5 |
3500 | 210000 | 9.2 | 1.7 | 0.7 |
4000 | 240000 | 10.5 | 2.1 | 0.9 |
4500 | 270000 | 11.8 | 2.6 | 1.1 |
5000 | 300000 | 13.1 | 3.2 | 1.4 |
5500 | 330000 | 14.4 | 3.8 | 1.7 |
6000 | 360000 | 15.7 | 4.5 | 2.0 |
6500 | 490000 | 17.0 | 5.2 | 2.3 |
7000 | 420000 | 18.3 | 6.0 | 2.6 |
500 | 30000 | 1.0 | 0.02 | 0.01 |
750 | 45000 | 1.5 | 0.05 | 0.02 |
1000 | 60000 | 2.0 | 0.08 | 0.04 |
1250 | 75000 | 2.5 | 0.1 | 0.05 |
1500 | 90000 | 3.0 | 0.2 | 0.08 |
2000 | 120000 | 4.0 | 0.3 | 0.1 |
2500 | 150000 | 5.0 | 0.5 | 0.2 |
3000 | 180000 | 6.0 | 0.6 | 0.3 |
3500 | 210000 | 7.0 | 0.9 | 0.4 |
4000 | 240000 | 8.0 | 1.1 | 0.5 |
4500 | 270000 | 9.0 | 1.4 | 0.6 |
5000 | 300000 | 10.0 | 1.7 | 0.7 |
5500 | 330000 | 11.0 | 2.0 | 0.9 |
6000 | 360000 | 12.0 | 2.3 | 1.0 |
6500 | 490000 | 13.0 | 2.7 | 1.2 |
7000 | 420000 | 14.0 | 3.1 | 1.3 |
7500 | 450000 | 15.0 | 3.5 | 1.5 |
8000 | 480000 | 16.0 | 4.0 | 1.7 |
8500 | 510000 | 17.0 | 4.4 | 1.9 |
9000 | 540000 | 18.0 | 4.9 | 2.1 |
Pressure loss values can be calculated with the Hazen-Williams Equation or the Darcy-Weisbach Formula.
Dimensions of PVC pipe SDR series.
Dimensions of CTS - Copper Tube Sized CPVC (Chlorinated Poly Vinyl Chloride) tubes.
Maximum distance between CPVC pipe supports.
Dimensions of PVC-U pipe according EN 1452.
Calculate minor pressure loss in piping systems with the Equivalent Pipe Length Method.
Equivalent length of fittings like bends, returns, tees and valves in hot water heating systems - equivalent length in feet and meter.
Dimensions of thermoplastic pipes according ISO 161.
Distance between PVC pipe supports.
Minor loss in PVC and CPVC fittings expressed as equivalent length of straight pipe.
Water flow in thermoplastic PVC and CPVC pipes Schedule 40 - friction loss (ft/100 ft, psi/100 ft) and flow velocities at dimensions ranging 1/2 to 16 inches.
Friction loss (psi/100 ft) and velocity for water flow in plastic PVC pipe schedule 40.
Recommended maximum flow velocities in water systems on the delivery side of the pump.
