CPVC Pipes - Hanger Spacing
Maximum support spacing for CPVC - Chlorinated Poly Vinyl Chloride - pipes depends on the operating temperature. Maximum spacing between supports at different temperatures can be found in the tables below:
CPVC Pipes - Schedule 40
NPS (inches) | Spacing (feet) | ||
Operating Temperature (oF) | |||
60 | 100 | 140 | |
1/2 | 5 | 4.5 | 4 |
3/4 | 5.5 | 5 | 4 |
1 | 6 | 5.5 | 4.5 |
1 1/4 | 6 | 5.5 | 5 |
1 1/2 | 6.5 | 6 | 5 |
2 | 6.5 | 6 | 5 |
3 | 8 | 7 | 6 |
4 | 8.5 | 7.5 | 6.5 |
6 | 9.5 | 8.5 | 7.5 |
CPVC Pipes - Schedule 80
60 | 100 | 140 | |
1/2 | 5.5 | 5 | 4.5 |
3/4 | 6 | 5.5 | 4.5 |
1 | 6.5 | 6 | 5 |
1 1/2 | 7 | 6.5 | 5.5 |
2 | 7.5 | 7 | 6 |
3 | 9 | 8 | 7 |
4 | 10 | 9 | 7.5 |
6 | 11 | 10 | 9 |
- 1 ft (foot) = 0.3048 m
- T (oC) = 5/9 (T (oF) - 32)
Chlorinated Poly Vinyl Chloride - CPVC - is a thermoplastic pipe and fitting material made with CPVC compounds meeting the requirements of ASTM Class 23447 as defined in ASTM Specification D1784.
CPVC applications are for potable water distribution, corrosive fluid handling in industry, and fire suppression systems.
Dimensions of CTS - Copper Tube Sized CPVC (Chlorinated Poly Vinyl Chloride) tubes.
CPVC - Chemical Resistance
Chemical resistance of CPVC - Chlorinated Poly (Vinyl Chloride) - to common chemicals and products.
CPVC Pipes - Operating and Collapsing Pressures vs. Schedule and Size
Maximum operating and bursting pressures of CPVC - Chlorinated Poly (Vinyl Chloride) - piping systems.
CTS (Copper Tube Sized) and CPVC Tubes - Friction Loss vs. Water Flow
Volume flow and pressure loss in CTS - Copper Tube Sized CPVC (Chlorinated Poly Vinyl Chloride) tubes.
PP - PolyPropylene Pipes - Support Spacing
Maximum distance between PolyPropylene pipes supports.
Pressfit Pipes - Supports
Maximum distance between pressfit pipe supports.
PVC Pipes - Equivalent Length and Pressure Loss in Fittings
Minor loss in PVC and CPVC fittings expressed as equivalent length of straight pipe.
PVC Pipes Schedule 80 - Friction Loss vs. Water Flow
Water flow in thermoplastic PVC and CPVC pipes Schedule 80 - friction loss (ft/100 ft, psi/100 ft) and flow velocities at dimensions ranging 1/2 to 16 inches.
Thermoplastic Pipes - Support Distance vs. Temperature
Maximum space between supports for PVC, CPVC, PVDF and PP pipes vs. temperature.
