CTS (Copper Tube Sized) and CPVC Tubes - Friction Loss vs. Water Flow
Chlorinated Poly Vinyl Chloride (CPVC) is a thermoplastic pipe and fitting material made with CPVC compounds meeting the requirements of ASTM Class 23447 as defined in ASTM Specification D1784. CPVC applications are for potable water distribution, corrosive fluid handling in industry, and fire suppression systems.
Head Loss (ft H2O/100 ft)
Head loss in CTS - Copper Tube Sized CPVC(Chlorinated Poly Vinyl Chloride) tubes:
  • 1 ft H2O = 0.4335 psi = 62.43 Lbs./Sq.Ft.
  • 1 gal (US)/min =6.30888x10-5 m3/s = 0.227 m3/h = 0.06309 dm3(litre)/s = 2.228x10-3 ft3/s = 0.1337 ft3/min = 0.8327 Imperial gal (UK)/min
  • 1 ft/s = 0.3048 m/s
Pressure Loss (kPa/m)
Pressure loss in CTS - Copper Tube Sized CPVC(Chlorinated Poly Vinyl Chloride) tubes:
  • 1 Pa = 10-6 N/mm2 = 10-5 bar = 0.1020 kp/m2 = 1.02x10-4 m H2O = 9.869x10-6 atm = 1.45x10-4 psi (lbf/in2)
  • 1 dm3(litre)/s = 10-3 m3/s = 3.6 m3/h = 0.03532 ft3/s = 2.1189 ft3/min (cfm) = 13.200 Imp.gal (UK)/min = 15.852 gal (US)/min = 792 Imp. gal (UK)/h
Example - Water Flow in Copper Tube
1 l/s of water flows through a 1" copper tube. From the figure below we estimates the velocity to be approximately 1.8 m/s and the pressure loss to be approximately 1.7 kPa/m.
Fluid Flow and Pressure Loss
Dimensions of CTS - Copper Tube Sized CPVC (Chlorinated Poly Vinyl Chloride) tubes.
CPVC - Chemical Resistance
Chemical resistance of CPVC - Chlorinated Poly (Vinyl Chloride) - to common chemicals and products.
CPVC Pipes - Hanger Spacing
Maximum distance between CPVC pipe supports.
CPVC Pipes - Operating and Collapsing Pressures vs. Schedule and Size
Maximum operating and bursting pressures of CPVC - Chlorinated Poly (Vinyl Chloride) - piping systems.
CPVC Tubes - Pressure and Temperature Ratings
CTS (Copper Tube Sized) CPVC (Chlorinated Poly Vinyl Chloride) tubes temperature and pressure ratings.
CTS - Copper Tube Sizes - Dimensions used in Plumbing
Copper tube sizes used in plumbing.
