CPVC Tubes - Pressure and Temperature Ratings
Pressure and temperature de-rating factors for CTS (Copper Tube Size) and CPVC1) (Chlorinated Poly Vinyl Chloride) tubes according ASTM D2846 - CPVC Plastic Hot and Cold Water Distribution Tubes - Dimensions:
Temperature (oF) | De-Rating Factor | Rating (psi) |
73 | 1.00 | 400 |
80 | 1.00 | 400 |
90 | 0.91 | 360 |
100 | 0.82 | 325 |
120 | 0.65 | 260 |
140 | 0.50 | 200 |
160 | 0.40 | 160 |
180 | 0.25 | 100 |
1)Chlorinated Poly Vinyl Chloride (CPVC) is a thermoplastic pipe and fitting material made with CPVC compounds meeting the requirements of ASTM Class 23447 as defined in ASTM Specification D1784. CPVC applications are for potable water distribution, corrosive fluid handling in industry, and fire suppression systems.
• Pressure Ratings of Pipes and Fittings
Dimensions of CTS - Copper Tube Sized CPVC (Chlorinated Poly Vinyl Chloride) tubes.
Barlow's Formula - Calculate Internal, Allowable and Bursting Pressure
Calculate pipes internal, allowable and bursting pressure.
Copper Tubes Type K, L and M - Working Pressures vs. Size
CPVC Pipes - Operating and Collapsing Pressures vs. Schedule and Size
Maximum operating and bursting pressures of CPVC - Chlorinated Poly (Vinyl Chloride) - piping systems.
CTS (Copper Tube Sized) and CPVC Tubes - Friction Loss vs. Water Flow
Volume flow and pressure loss in CTS - Copper Tube Sized CPVC (Chlorinated Poly Vinyl Chloride) tubes.
CTS - Copper Tube Sizes - Dimensions used in Plumbing
Copper tube sizes used in plumbing.
Fiberglass Pipes and Temperature Limits
Temperature ranges for fiberglass Epoxy, Furan, Phenolic, Polyester and Vinyl Ester pipes.
Steel Pipes - De-Rating vs. Temperature
Temperature derating factor for steel pipes.
Thermoplastic Pipes - Strength Derating vs. Temperature
Increased temperatures derates the strength of thermoplastic piping materials.
