Barlow's Formula - Calculate Internal, Allowable and Bursting Pressure
Barlow's formula is used to determine
  • internal pressure at minimum yield
  • ultimate burst pressure
  • maximum allowable pressure
Internal Pressure At Minimum Yield
Barlow's formula can be used to calculate the "Internal Pressure" at minimum yield
Py = 2 Sy t / do                                     (1)
Py = internal pressure at minimum yield (psig, MPa)
Sy = yield strength (psi, MPa)
t = wall thickness (in, mm)
do = outside diameter (in, mm)
Note! - in codes like ASME B31.3 modified versions of the Barlow's formula - like the Boardman formula and the Lame formula - are used to calculate burst and allowable pressures and minimum wall thickness.
Example - Internal Pressure at Minimum Yield
The internal pressure for a 8 inch liquid pipe line with outside diameter 8.625 in and wall thickness 0.5 in with yield strength 30000 psi can be calculated as
Py = 2 (30000 psi) (0.5 in) / (8.625 in)
   = 3478 psi
Example - Polyethylene PE pipe
The yield strength of a 110 mm polyethylene pipe is 22.1 MPa. The minimum wall thickness for pressure 20 bar (2 MPa) can be calculated by rearranging eq. 1 to
  t = Py do / (2 Sy)
   = (2 MPa) (110 mm) / (2 (22.1 MPa))
   = 5 mm
Ultimate Burst Pressure
Barlow's formula can be used to calculate the "Ultimate Burst Pressure" at ultimate (tensile) strength as
Pt = 2 St t / do                                 (2)
Pt = ultimate burst pressure (psig)
St = ultimate (tensile) strength (psi)
Example - Ultimate Burst Pressure
The ultimate pressure for the pipe used in the example above with ultimate (tensile) strength 48000 psi can be calculated as
Pt = 2 (48000 psi) (0.5 in) / (8.625 in)
   = 5565 psi
Working Pressure or Maximum Allowable Pressure
Working pressure is a term used to describe the maximum allowable pressure a pipe may be subjected to while in-service. Barlow's formula can be used to calculate the maximum allowable pressure by using design factors as
Pa = 2 Sy Fd Fe Ft t / do                                   (3)
Pa = maximum allowable design pressure (psig)
Sy = yield strength (psi)
Fd = design factor
Fe = longitudinal joint factor
Ft = temperature derating factor
Typical Design Factors - Fd
  • liquid pipelines: 0.72
  • gas pipe lines - class 1: 0.72
  • gas pipe lines - class 2: 0.60
  • gas pipe lines - class 3: 0.50
  • gas pipe lines - class 4: 0.40
Example - Maximum Allowable Pressure
The "Maximum Allowable Pressure" for the liquid pipe line used in the examples above with Fd = 0.72, Fe = 1 and Ft = 1 - can be calculated as
Pa = 2 (30000 psi) 0.72 1 1 (0.5 in) / (8.625 in)
   = 2504 psi
Barlow's formula is based on ideal conditions and room temperatures.
Mill Test Pressure
The "Mill Test Pressure" refers to the hydrostatic (water) pressure applied to the pipe at the mill to assure the integrity of the pipe body and weld.
Pt = 2 St t / do                                      (4)
Pt = test pressure (psig)
St = specified yield strength of material - often 60% of yield strength (psi)
Wall Thickness
Barlow's formula can be useful to calculate required pipe wall thickness if working pressure, yield strength and outside diameter of pipe is known. Barlow's formula rearranged:
tmin = Pi do / (2 Sy)                                    (5)
tmin = minimum wall thickness (in)
Pi = Internal pressure in pipe (psi)
Example - Minimum Wall Thickness
The minimum wall thickness for a pipe with the same outside diameter - in the same material with the same yield strength as in the examples above - and with an internal pressure of 6000 psi - can be calculated as
t = (6000 psi) (8.625 in) / (2 (30000 psi))
  = 0.863 in
From table8 inch pipe Sch 160 with wall thickness 0.906 inches can be used.
Material Strength
The strength of a material is determined by the tension test which measure the tension force and the deformation of the test specimen.
  • the stress which gives a permanent deformation of 0.2% is called the yield strength
  • the stress which gives rupture is called the ultimate strength or the tensile strength
Typical strength of some common materials:
Ultimate and Yield Strength
MaterialYield Strength
(psi)
Ultimate (Tensile) Strength
(psi)
Stainless Steel, 304 30000 75000
6 Moly, S31254 45000 98000
Duplex, S31803 65000 90000
Nickel, N02200 15000 55000
A53 Seamless and Welded Standard Pipe, Grade A 30000 48000
A53 Seamless and Welded Standard Pipe, Grade B 35000 60000
  • 1 psi (lb/in2) = 6,894.8 Pa (N/m2) = 6.895×10-2 bar
  • 1 MPa = 106 Pa
Barlow's Pressure Calculator
The Barlow's formula calculator can be used to estimate
Barlow's Wall Thickness Calculator
The Barlow's formula calculator can be used to estimate minimum wall thickness of pipe.
Example - A53 Seamless and Welded Standard Pipe - Bursting Pressure
Bursting pressure calculated with Barlow's formula (2) for A53 Seamless and Welded Standard Pipe Grade A with ultimate (tensile) strength 48000 psi. Pipe dimensions - outside diameter and wall thickness according ANSI B36.10.
NPSOutside DiameterBursting Pressure (psi)
Schedule
(in)(in)
102030STD4060XS80100120140160XXS
3/8 0.675 12942 12942 17920 17920
1/2 0.84 12457 12457 16800 16800 21371 33600
3/4 1.05 10331 10331 14080 14080 20023 28160
1 1.315 9710 9710 13068 13068 18251 26135
1 1/4 1.66 8096 8096 11046 11046 14458 22092
1 1/2 1.9 7326 7326 10105 10105 14198 20211
2 2.375 6225 6225 8812 8812 13905 17624
2 1/2 2.875 6778 6778 9216 9216 12522 18432
3 3.5 5925 5925 8229 8229 12014 16457
3 1/2 4 5424 5424 7632 7632
4 4.5 5056 5056 7189 7189 9344 11328 14379
5 5.563 4452 4452 6471 6471 8628 10786 12943
6 6.625 4057 4057 6260 6260 8144 10419 12520
8 8.625 2783 3083 3584 3584 4519 5565 5565 6611 8003 9038 10084 9739
10 10.75 2233 2742 3260 3260 4465 4465 5305 6421 7537 8930 10047 8930
12 12.75 1882 2485 2824 3057 4232 3765 5180 6355 7529 8471 9879 7529
14 14 1714 2139 2571 2571 3003 4073 3429 5143 6432 7502 8571 9641
16 16 1500 1872 2250 2250 3000 3936 3000 5064 6186 7314 8628 9564
18 18 1333 1664 2336 2000 2997 4000 2667 5003 6165 7333 8331 9499
20 20 1200 1800 2400 1800 2851 3898 2400 4949 6149 7200 8400 9451
22 22 1091 1636 2182 1636 3818 2182 4909 6000 7091 8182 9273
24 24 1000 1500 2248 1500 2752 3876 2000 4876 6124 7248 8248 9376
30 30 998 1600 2000 1200 1600
32 32 936 1500 1875 1125 2064
34 34 881 1412 1765 1059 1943
36 36 832 1333 1667 1000 2000
42 42 1143 1429 857 1714
  • 1 in (inch) = 25.4 mm
  • 1 MPa = 103 kPa = 106 Pa
Pressure Ratings of Pipes and Fittings
Aluminum Tubing - Allowable Pressures
Allowable pressure for aluminum tubes.
ASME 31.3 Piping Materials - Allowable Pressure Calculator
Calculate ASME 31.3 allowable pressure
ASTM A312 Stainless Steel Pipes - Bursting and Collapsing Pressures
Theoretic bursting and collapsing pressures for stainless steel pipes ASTM A312.
ASTM A53 B Carbon Steel Pipes - Allowable Pressure vs. Schedule and Size
Maximum working pressure of carbon steel pipe at temperature 400oF.
Carbon Steel Pipes - Pressure and Temperature Ratings, Imperial Units
Pressure (psig) and temperature (deg F) ratings for A-53 B and A-106 B, A333, A334 and API 5L carbon steel pipes - temperatures ranging 100 degF - 700 degF.
Carbon Steel Pipes - Pressure and Temperature Ratings, Metric Units
Pressure (kPa)> and temperature (degC) ratings of ASTM A-106, API 5L and ASTM A-53 Seamless Carbon Steel Pipes - temperatures ranging -29 degC - 450 degC.
Copper Tubes Type K, L and M - Working Pressures vs. Size
CPVC Tubes - Pressure and Temperature Ratings
CTS (Copper Tube Sized) CPVC (Chlorinated Poly Vinyl Chloride) tubes temperature and pressure ratings.
Metals Strength vs. Temperature
The influence of temperature on the strength of metals.
Steel Tubes - Working Pressures vs. Size
Normal maximum working pressures for steel tubes - in psi and kPa.
Stress in Thick-Walled Cylinders or Tubes
Radial and tangential stress in thick-walled cylinders or tubes with closed ends - with internal and external pressure.
Water Hammer
Rapidly closing or opening valves - or starting stopping pumps - may cause pressure transients in pipelines known as surge or water hammer.
Wrought Steel Pipes - Bursting Pressures vs. Size
Theoretical bursting and working pressure of wrought steel standard, extra strong and double extra strong pipes.
