Steel Tubes - Working Pressures vs. Size
The working pressures below are conservative estimates. Be aware that domestic rules may give lower limits.
For full table with Steam/Air Welded Connections - rotate the screen!
Steel Tubes - Working Pressure vs. Size
Nominal boreWaterSteam / Air, screwed connectionsSteam / Air, welded connections
LightMediumHeavyMediumHeavyMediumHeavy
inchesmmpsikPapsikPapsikPapsikPapsikPapsikPapsikPa
1/4 8 150 1000 300 2000 350 2400 150 1000 175 1200 250 1750 300 2000
3/8 10 150 1000 300 2000 350 2400 150 1000 175 1200 250 1750 300 2000
1/2 15 150 1000 300 2000 350 2400 150 1000 175 1200 250 1750 300 2000
3/4 20 150 1000 300 2000 350 2400 150 1000 175 1200 250 1750 300 2000
1 25 150 1000 300 2000 350 2400 150 1000 175 1200 250 1750 300 2000
1 1/4 32 125 850 250 1750 300 2000 125 850 150 1000 200 1400 300 2000
1 1/2 40 125 850 250 1750 300 2000 125 850 150 1000 200 1400 300 2000
2 50 100 700 200 1400 250 1750 100 700 125 850 200 1400 300 2000
2 1/2 65 100 700 200 1400 250 1750 100 700 125 850 200 1400 300 2000
3 80 100 700 200 1400 250 1750 100 700 125 850 150 1000 200 1400
4 100 80 550 150 1000 200 1400 80 550 100 700 150 1000 200 1400
5 125 150 1000 200 1400 80 550 100 700 150 1000 200 1400
6 150 125 850 150 1400 60 400 80 550 125 850 75 1200
  • 1 psi = 1 lb/in2
  • 1 kPa = 1 kN/m2
Pressure Ratings
ASME 31.3 Piping Materials - Allowable Pressure Calculator
Calculate ASME 31.3 allowable pressure
ASTM A312 Stainless Steel Pipes - Bursting and Collapsing Pressures
Theoretic bursting and collapsing pressures for stainless steel pipes ASTM A312.
ASTM A53 B Carbon Steel Pipes - Allowable Pressure vs. Schedule and Size
Maximum working pressure of carbon steel pipe at temperature 400oF.
Barlow's Formula - Calculate Internal, Allowable and Bursting Pressure
Calculate pipes internal, allowable and bursting pressure.
Carbon Steel Flanges - Pressure and Temperature Ratings
Maximum ratings for flanges conforming to ISO Standard 2229 dimensions and material specification AST-A-105.
Carbon Steel Pipes - Pressure and Temperature Ratings, Imperial Units
Pressure (psig) and temperature (deg F) ratings for A-53 B and A-106 B, A333, A334 and API 5L carbon steel pipes - temperatures ranging 100 degF - 700 degF.
Copper Tubes Type K, L and M - Working Pressures vs. Size
Stainless Steel Pipes - Allowable Pressure vs. Schedule and Size
Allowable pressure for standard seamless A312-TP316/316L stainless steel pipes - temperatures 100oF to 750oF.
Wrought Steel Pipes - Bursting Pressures vs. Size
Theoretical bursting and working pressure of wrought steel standard, extra strong and double extra strong pipes.
