Stress in Thick-Walled Cylinders or Tubes
When a thick-walled tube or cylinder is subjected to internal and external pressure a hoop and longitudinal stress are produced in the wall.
Stress in Axial Direction
The stress in axial direction at a point in the tube or cylinder wall can be expressed as:
σa = (pi ri2 - po ro2 )/(ro2 - ri2) (1)
σa = stress in axial direction (MPa, psi)
pi = internal pressure in the tube or cylinder (MPa, psi)
po = external pressure in the tube or cylinder (MPa, psi)
ri = internal radius of tube or cylinder (mm, in)
ro = external radius of tube or cylinder (mm, in)
Stress in Circumferential Direction - Hoop Stress
The stress in circumferential direction - hoop stress - at a point in the tube or cylinder wall can be expressed as:
σc = [(pi ri2 - po ro2) / (ro2 - ri2)] + [ri2 ro2 (po - pi) / (r2 (ro2 - ri2))] (2)
σc = stress in circumferential direction (MPa, psi)
r = radius to point in tube or cylinder wall (mm, in) (ri < r < ro)
maximum stress when r = ri (inside pipe or cylinder)
Resultant Stress
Combined stress in a single point in the cylinder wall cannot be described by a single vector using vector addition. Instead stress tensors (matrixes) describing the linear connection between two physical vectors quantities can be used.
Stress in Radial Direction
The stress in radial direction at a point in the tube or cylinder wall can be expressed as:
σr= [(pi ri2 - po ro2) / (ro2 - ri2)] - [ri2 ro2 (po - pi) / (r2 (ro2 - ri2))] (3)
maximum stress when r = ro (outside pipe or cylinder)
Example - Stress in Thick walled Cylinder
In a cylinder with inside diameter 200 mm (radius 100 mm) and outside diameter 400 mm (radius 200 mm) there is a pressure 100 MPa relative to the outside pressure.
Stress in axial direction can be calculated as
σa = (((100 MPa) (100 mm)2 - (0 MPa) (200 mm)2) / ((200 mm)2 - (100 mm)2)
= 33.3 MPa
Stress in circumferential direction - hoop stress - at the inside wall (100 mm) can be calculated as
σc = [((100 MPa) (100 mm)2 - (0 MPa) (200 mm)2) / ((200 mm)2 - (100 mm)2)] - [(200 mm)2 (100 mm)2 ((0 MPa)- (100 MPa)) / ((100 mm)2 ((200 mm)2 - (100 mm)2))]
= 167 MPa
Stress in radial direction at the inside wall (100 mm) can be calculated as
σr = [((100 MPa) (100 mm)2 - (0 MPa) (200 mm)2) / ((200 mm)2 - (100 mm)2)] + [(200 mm)2 (100 mm)2 ((0 MPa)- (100 MPa)) / ((100 mm)2 ((200 mm)2 - (100 mm)2))]
= -100 MPa
Note! - that in addition stress caused by pressure - stress can be induced in the pipe or cylinder wall by restricted temperature expansion.
Online Thick Walled Pipe & Cylinder Calculator
The calculator below can be used to calculate the stress in thick walled pipes or cylinders with closed ends.
• Mechanics
• Statics
ASME - International Boiler and Pressure Vessel Code
The International Boiler and Pressure Vessel Code safety rules governing design, fabrication, and inspection of boilers and pressure vessels, and nuclear power plant components during construction.
Barlow's Formula - Calculate Internal, Allowable and Bursting Pressure
Calculate pipes internal, allowable and bursting pressure.
Hooke's Law
Hooke's law - force, elongation and spring constant.
Process Pipes - Allowable Stress vs. Temperature
Allowable wall stress in pipes according ASME M31.3.
Rotating Bodies - Stress
Stress in rotating disc and ring bodies.
Shafts Torsion
The torsion of solid or hollow shafts - Polar Moment of Inertia of Area.
Calculate the stress in steam boiler shells caused by steam pressure.
Stress
Stress in Thin-Walled Cylinders or Tubes
Hoop and longitudinal stress thin-walled tubes or cylinders.
Threaded Rods - Proof Loads - Metric Units
Proof load capacities of metric threaded steel rods.
Young's Modulus, Tensile Strength and Yield Strength Values for some Materials
Young's Modulus (or Tensile Modulus alt. Modulus of Elasticity) and Ultimate Tensile Strength and Yield Strength for materials like steel, glass, wood and many more.
