Rotating Bodies - Stress
Stress in a Rotating Disc
Stress in a rotating disc can be calculated as
σz = ω2 r2 ρ / 3
= v2 ρ / 3
= ( 2 π n / 60)2r2ρ / 3                               (1)
σz = stress (Pa, N/m2)
ω = angular velocity (rad/s)
r = radius of disc (m)
ρ = density (kg/m3)
π = 3.14...
n= revolutions per minute (rpm)
Stress in a Rotating Ring
Stress in a rotating ring can be calculated as
σz = ω2ρ (r12+ r1 r2+ r2 2) / 3                              (2)
r1 = outer radius of ring (m)
r2= inner radius of ring (m)
For a thin ring the equation can be simplified to
σz = ω2 ρ r                              (3)
r  = mean radius of ring (m)
Design Stress for materials used in Flywheels
Design Stress Flywheel Materials
MaterialDensity
(kg/m3)
Typical Design Stress
(MPa)
Aluminum alloy 2700
Birch plywood 700 30
Composite carbon fiber - 40% epoxy 1550 750
E-glass fiber - 40% epoxy 1900 250
Kevlar fiber - 40% epoxy 1400 1000
Maraging steel 8000 900
Titanium Alloy 4500 650
"Super paper" 1100
S-glass fiber/epoxy 1900 350
Dynamics
Centripetal and Centrifugal Acceleration Force
Forces due to circular motion and centripetal / centrifugal acceleration.
Flywheels - Kinetic Energy
The kinetic energy stored in flywheels - the moment of inertia.
Stress
Stress in Thick-Walled Cylinders or Tubes
Radial and tangential stress in thick-walled cylinders or tubes with closed ends - with internal and external pressure.
Stress in Thin-Walled Cylinders or Tubes
Hoop and longitudinal stress thin-walled tubes or cylinders.
