ASME - International Boiler and Pressure Vessel Code
The ASME - American Society of Mechanical Engineers - International Boiler and Pressure Vessel Code (BPVC) is made of 11 sections and contains over 15 divisions and subsections.
Code Sections
I. Power Boilers
II. Materials
III. Rules for Construction of Nuclear Facility Components
IV. Heating Boilers
V. Nondestructive Examination
VI. Recommended Rules for the Care and Operation of Heating Boilers
VII. Recommended Guidelines for the Care of Power Boilers
VIII. Pressure Vessels
IX. Welding and Brazing Qualifications
X. Fiber-Reinforced Plastic Pressure Vessels
XI. Rules for In-service Inspection of Nuclear Power Plant Components
XII. Rules for Construction and Continued Service of Transport Tanks
I. Power Boilers
This Section provides requirements for all methods of construction of power, electric, and miniature boilers; high temperature water boilers used in stationary service; and power boilers used in locomotive, portable, and traction service. Requirements for: Boilers Fabricated by Welding; Boilers Fabricated by Riveting (by reference only); Watertube Boilers; Firetube Boilers; Feedwater Heaters; Miniature Boilers; Electric Boilers; Organic Fluid Vaporizer Generators.
This section provides requirements for all methods of construction of power, electric, and miniature boilers; high temperature water boilers used in stationary service; and power boilers used in locomotive, portable, and traction service. The rules are applicable to boilers in which
  •  steam or other vapor is generated at a pressures exceeding 15 psig,
  • and high temperature water boilers intended for operation at pressures exceeding 160 psig and or temperatures exceeding 250 degree F.
 Superheaters, economizers, and other pressure parts connected directly to the boiler without intervening valves are considered as part of the scope of Section 1.
II. Materials
  • Part A-Ferrous Material Specifications
  • Part B-Nonferrous Material Specifications
  • Part C-Specifications for Welding Rods, Electrodes, and Filler Metals
  • Part D-Properties
  • Subsection NCA - General Requirements for Divisions 1 and 2
DIVISION 1
  • Subsection NB- Class 1 Components
  • Subsection NC- Class 2 Components
  • Subsection ND- Class 3 Components
  • Subsection NE- Class MC Components
  • Subsection NF - Supports
  • Subsection NG - Core Support Structures
  • Subsection NH - Class 1 Components in Elevated Temperature Service
DIVISION 2
  • Code for Concrete Containments
DIVISION 3
  • Containments for Transportation and Storage
IV. Heating Boilers
This Subsection provides requirements for design, fabrication, installation and inspection of steam generating boilers, and hot water boilers intended for low pressure service that are directly fired by oil, gas, electricity, or coal. It contains appendices which cover approval of new material, methods of checking safety valve and safety relief valve capacity, examples of methods of checking safety valve and safety relief valve capacity, examples of methods of calculation and computation, definitions relating to boiler design and welding, and quality control systems.
Requirements and methods for nondestructive examination which are referenced and required by other code Sections. It also includes manufacturer's examination responsibilities, duties of authorized inspectors and requirements for qualification of personnel, inspection and examination. Examination methods are intended to detect surface and internal discontinuities in materials, welds, and fabricated parts and components. A glossary of related terms is included.
General descriptions, terminology and operation guidelines applicable to steel and cast iron boilers limited to the operating ranges of Section IV Heating Boilers. It includes guidelines for associated controls and automatic fuel burning equipment. Illustrations show typical examples of available equipment. Also included is a glossary of terms commonly associated with boilers, controls, and fuel burning equipment.
Guidelines to promote safety in the use of stationary, portable, and traction type heating boilers. The section provides guidelines to assist operators of power boilers in maintaining their plants as safely as possible. Emphasis has been placed on industrial-type boilers because of their extensive use. Contains Fuels for Routine Operation; Operating and Maintaining Boiler Appliances; Inspection; Prevention of Direct Causes of Boiler Failure; Design of Installation; Operation of Boiler Auxiliaries; Control of Internal Chemical Conditions
Division 1 - Provides requirements applicable to the design, fabrication, inspection, testing, and certification of pressure vessels operating at either internal or external pressures exceeding 15 psig.
Division 2 - Alternative Rules, provides requirements applicable to the design, fabrication, inspection, testing, and certification of pressure vessels operating at either internal or external pressures exceeding 15 psig.
Division 3 - Alternative Rules for Construction of High Pressure Vessels, provides requirements applicable to the design, fabrication, inspection, testing, and certification of pressure vessels operating at either internal or external pressures generally above 10,000 psi.
Rules relating to the qualification of welding and brazing procedures as required by other Code Sections for component manufacture. Covers rules relating to the qualification and re-qualification of welders, brazers, and welding and brazing operators in order that they may perform welding or brazing as required by other Code Sections in the manufacture of components. General Welding Requirements; Welding Procedure Qualifications; Welding Performance Qualifications; Welding Data; Welding Forms; General Brazing Requirements; Brazing Procedure Qualifications; Brazing Performance Qualifications; Brazing Data; Brazing Forms.
Requirements for construction of an FRP pressure vessel in conformance with a manufacturer's design report. It includes production, processing, fabrication, inspection and testing methods required for the vessel.
Rules for the examination, in-service testing and inspection, and repair and replacement of components and systems in light-water cooled and liquid-metal cooled nuclear power plants.
Requirements for construction and continued service of pressure vessels for the transportation of dangerous goods via highway, rail, air or water at pressures from full vacuum to 3,000 psig and volumes greater than 120 gallons.
Codes and Standards
Heating
Heating systems - capacity and design of boilers, pipelines, heat exchangers, expansion systems and more.
Steam and Condensate
ASME is one of the leading organizations in the world developing codes and standards.
ASME - Performance Test Codes
The ASME Performance Test Codes provide standard directions and rules for conducting and reporting tests.
ASTM International - Volume 01.01 Steel - Piping, Tubing, Fittings
An overview of the ASTM Volume 01.01 standard.
Boiler - Efficiency
Combustion gross and net calorific value.
Boiler Blowdown
Boiler Blowdown Rate
Calculate boiler blowdown rate.
Boiler Capacities
Steam boilers output can be expressed in Boiler Horsepower, MBTU or in Pounds of Steam delivered per hour.
Boiler Feed Water - Chemistry and Impurity Limits
ABMA recommended feed water chemistry limits for steam boilers.
Boiler Horsepower
Boiler horsepower vs. heat transfer area.
Boilers - Classification
Classification of boilers according the ASME Boiler and Pressure Vessel Code.
Factors of Safety - FOS
Factors of Safety - FOS - are important in engineering designs.
Feed Pumps in Steam Systems - Suction Lift Head vs. Temperature
Cavitation of impellers increases with water temperatures.
High Pressure Steam Systems - Safety Valve Capacities
Sizing safety valves according boiler output power in high pressure systems (kW and Btu/hr)
Intermittent Combustion and Boiler Efficiency
Efficiency reduction due to intermittent boiler operation.
Safety Valve Standards
The most common used safety valve standards in Germany, UK, USA, France, Japan, Australia and Europe.
Steam Boiler Rating vs. Feed Water Temperature
Boiler output vs. feed water temperature.
Stress in Thick-Walled Cylinders or Tubes
Radial and tangential stress in thick-walled cylinders or tubes with closed ends - with internal and external pressure.
