Steel Pipes - De-Rating vs. Temperature
Temperature derating factors of steel pipes due to stress are indicated below:
Steel Pipes - De-Rating Factor vs. Temperature
TemperatureDerating Factor
(oF)(oC)
< 250 < 121 1.00
250 - 300 121 - 149 0.97
300 - 350 149 - 177 0.93
350 - 400 177 - 204 0.90
400 - 450 204 - 233 0.87
Pressure Ratings
Carbon and Stainless Steel Flanges - ASME/ANSI Class 300
ASME/ANSI B16.5-1996 Pipe Flanges and Flanged Fittings - Class 300 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts.
Carbon Steel Flanges - Group 1.1 Pressure and Temperature Ratings
Maximum temperature and pressure ratings of flanges conforming dimensions ASME B16.5 and materials specification ASTM A-105.
Carbon Steel Pipes - Pressure and Temperature Ratings, Imperial Units
Pressure (psig) and temperature (deg F) ratings for A-53 B and A-106 B, A333, A334 and API 5L carbon steel pipes - temperatures ranging 100 degF - 700 degF.
Carbon Steel Pipes - Pressure and Temperature Ratings, Metric Units
Pressure (kPa)> and temperature (degC) ratings of ASTM A-106, API 5L and ASTM A-53 Seamless Carbon Steel Pipes - temperatures ranging -29 degC - 450 degC.
CPVC Tubes - Pressure and Temperature Ratings
CTS (Copper Tube Sized) CPVC (Chlorinated Poly Vinyl Chloride) tubes temperature and pressure ratings.
Process Pipes - Allowable Stress vs. Temperature
Allowable wall stress in pipes according ASME M31.3.
Stainless Steel Pipes - Allowable Pressure vs. Schedule and Size
Allowable pressure for standard seamless A312-TP316/316L stainless steel pipes - temperatures 100oF to 750oF.
Thermoplastic Pipes - Strength Derating vs. Temperature
Increased temperatures derates the strength of thermoplastic piping materials.
