CPVC Pipes - Operating and Collapsing Pressures vs. Schedule and Size
Maximum operating and collapsing pressures at 70 oF (21 oC) for CPVC piping systems according
- ASTM F441 / F441M - 02 Standard Specification for Chlorinated Poly(Vinyl Chloride) (CPVC) Plastic Pipe, Schedules 40 and 80
- ASTM D2846 / D2846M - 06 Standard Specification for Chlorinated Poly(Vinyl Chloride) (CPVC) Plastic Hot- and Cold-Water Distribution Systems
are indicated in the diagram and table below:
Nominal Pipe Size (inches) | Collapse Pressure (psi) | Maximum Operating Pressure (psi) | ||
Schedule 40 | Schedule 80 | Schedule 40 | Schedule 80 | |
1/2 | 1605 | 2006 | 590 | 850 |
3/4 | 1219 | 1740 | 480 | 690 |
1 | 948 | 1628 | 450 | 630 |
1 1/4 | 511 | 1399 | 365 | 520 |
1 1/2 | 366 | 1034 | 330 | 470 |
2 | 213 | 653 | 275 | 400 |
2 1/2 | 276 | 758 | 300 | 420 |
3 | 179 | 521 | 260 | 370 |
4 | 108 | 334 | 220 | 320 |
6 | 54 | 214 | 180 | 280 |
8 | 37 | 146 | 160 | 250 |
10 | 27 | 125 | 140 | 230 |
12 | 22 | 116 | 130 | 230 |
- 1 psi (lb/in2) = 6,894.8 Pa (N/m2)
Note! The maximum operating pressures derates with temperature. At the maximum operating temperature for CPVC - 200 oF (93 oC) - the strength is derated to approximately 20% of the strength at 73 oF (23 oC).
Be aware that maximum operating pressures varies with the fittings design. Consult manufacturing data.
• Pressure Ratings of Pipes and Fittings
Dimensions of CTS - Copper Tube Sized CPVC (Chlorinated Poly Vinyl Chloride) tubes.
CPVC - Chemical Resistance
Chemical resistance of CPVC - Chlorinated Poly (Vinyl Chloride) - to common chemicals and products.
CPVC Pipes - Hanger Spacing
Maximum distance between CPVC pipe supports.
CPVC Tubes - Pressure and Temperature Ratings
CTS (Copper Tube Sized) CPVC (Chlorinated Poly Vinyl Chloride) tubes temperature and pressure ratings.
CTS (Copper Tube Sized) and CPVC Tubes - Friction Loss vs. Water Flow
Volume flow and pressure loss in CTS - Copper Tube Sized CPVC (Chlorinated Poly Vinyl Chloride) tubes.
Plastic Pipes - Friction Head Loss vs. Water Flow
Thermoplastic Pipes - Support Distance vs. Temperature
Maximum space between supports for PVC, CPVC, PVDF and PP pipes vs. temperature.
Water Hammer
Rapidly closing or openingĀ valves - or starting stopping pumps - may cause pressure transients in pipelines known as surge or water hammer.
