Pipe and Tube System Components - Minor (Dynamic) Loss Coefficients
Minor or dynamic pressure loss in pipe or tube system components can be expressed as
Δpminor_loss = ξ ρf v2 / 2 (1)
Δpminor_loss = minor pressure loss (Pa (N/m2), psf (lb/ft2))
ρf = density of fluid (kg/m3, slugs /ft3)
v = flow velocity (m/s, ft/s)
Minor loss coefficients for commonly used pipe and tube system components:
| Type of Component or Fitting | Minor Loss Coefficient - ξ - |
| Tee, Flanged, Dividing Line Flow | 0.2 |
| Tee, Threaded, Dividing Line Flow | 0.9 |
| Tee, Flanged, Dividing Branched Flow | 1.0 |
| Tee, Threaded, Dividing Branch Flow | 2.0 |
| Union, Threaded | 0.08 |
| Elbow, Flanged Regular 90o | 0.3 |
| Elbow, Threaded Regular 90o | 1.5 |
| Elbow, Threaded Regular 45o | 0.4 |
| Elbow, Flanged Long Radius 90o | 0.2 |
| Elbow, Threaded Long Radius 90o | 0.7 |
| Elbow, Flanged Long Radius 45o | 0.2 |
| Return Bend, Flanged 180o | 0.2 |
| Return Bend, Threaded 180o | 1.5 |
| Globe Valve, Fully Open | 10 |
| Angle Valve, Fully Open | 2 |
| Gate Valve, Fully Open | 0.15 |
| Gate Valve, 1/4 Closed | 0.26 |
| Gate Valve, 1/2 Closed | 2.1 |
| Gate Valve, 3/4 Closed | 17 |
| Swing Check Valve, Forward Flow | 2 |
| Ball Valve, Fully Open | 0.05 |
| Ball Valve, 1/3 Closed | 5.5 |
| Ball Valve, 2/3 Closed | 200 |
| Diaphragm Valve, Open | 2.3 |
| Diaphragm Valve, Half Open | 4.3 |
| Diaphragm Valve, 1/4 Open | 21 |
| Water meter | 7 |
Example - Minor Dynamic Pressure Loss in Waterflow a Ball Valve 1/3 Closed
The minor loss a ball valve with flow velocity 2 m/s with water with density 1000 kg/m3 can be calculated as
Δpminor_loss = (5.5) (1000 kg/m3) (2 m/s)2 / 2
= 11000 Pa
= 11 kPa
Air Duct Components - Minor Dynamic Loss Coefficients
Minor loss (pressure or head loss) coefficients for air duct components.
Air Ducts - Minor Loss Coefficient Diagrams
Minor loss coefficient diagrams for air ductwork, bends, expansions, inlets and outletsĀ - SI units.
Equivalent Length Method - Minor Pressure Loss in Piping Systems
Calculate minor pressure loss in piping systems with the Equivalent Pipe Length Method.
Equivalent Length vs. Minor Pressure Head Loss in Pipe and Duct Components
Minor pressure and head loss in pipes vs. equivalent length in tubes and duct systems.
Fittings and Minor Pressure Loss
Minor pressure loss with fittings in piping heating systems.
Hot Water Systems - Equivalent Length vs. Fittings Resistance
Equivalent length of fittings like bends, returns, tees and valves in hot water heating systems - equivalent length in feet and meter.
Pipe and Duct Systems - Total Head Loss
Major and minor loss in pipes, tubes and duct systems.
Pressure Gradient Diagrams
Static pressure graphical presentation throughout a fluid flow system.
PVC Pipes - Equivalent Length and Pressure Loss in Fittings
Minor loss in PVC and CPVC fittings expressed as equivalent length of straight pipe.
Ventilation Ducts - Minor Loss Resistance
Minor pressure or head loss in ventilation ducts vs. air velocity - minor loss coefficient diagram.
