Air Ducts - Minor Loss Coefficient Diagrams
Minor loss in air ducts based on a summarized minor loss coefficients and air flow velocity:
Download and print Air Ducts - Minor Loss Diagram
  • 1 Pa = 1 N/m2 = 1.4504x10-4 lb/in2 = 1x10-5 bar = 4.03x10-3 in water = 0.336x10-3 ft water = 0.1024 mm water = 0.295x10-3 in mercury = 7.55x10-3 mm mercury = 0.1024 kg/m2 = 0.993x10-5 atm
Minor loss for some common duct-work components like bends, expansions, inlets and outlets can be estimated from the diagrams below.
Minor Loss Coefficients - Bends
The minor loss coefficients in 90o bends can be estimated with the diagram below.
The minor loss in bends 0 - 180o can be estimated with the equation
ξ0-180 = ξ90 α / 90                                            (1)
ξ0-180 = minor loss coefficient for the bend with the actual angle
ξ90 = minor loss coefficient for the 90o bend according the diagram above
α = angle of the actual bend
The minor loss coefficient in a 90o bend like the one below is 1.0.
Minor Loss Coefficients - Expansions
Minor Loss Coefficients - Inlets
Minor Loss Coefficients - Outlets
Ventilation
Air Duct Components - Minor Dynamic Loss Coefficients
Minor loss (pressure or head loss) coefficients for air duct components.
Air Duct Velocities
Typical air duct velocities in applications like ventilation systems or compressed air systems.
A major friction loss diagram for air ducts - SI units.
Equivalent Length vs. Minor Pressure Head Loss in Pipe and Duct Components
Minor pressure and head loss in pipes vs. equivalent length in tubes and duct systems.
Pipe and Tube System Components - Minor (Dynamic) Loss Coefficients
Minor loss coefficients for components used in pipe and tube systems.
Rectangular Air Ducts - Velocity Diagram
Velocity diagram for rectangular air ducts - metric units.
Ventilation Ducts - Minor Loss Resistance
Minor pressure or head loss in ventilation ducts vs. air velocity - minor loss coefficient diagram.
