Water Pressure vs. Head
Download and print Pressure vs. Head Units chart
Convert from Pressure - Pounds per Square Inch (psi) to Head of Water in Feet (fth2o)
Convert from Head - Water Feet to Pressure in Pounds per Square Inch
- 1 ftH2O = 0.4335 psi = 62.43 lbs/ft2
- 1 psi (lb/in2) = 144 psf (lbf/ft2) = 6894.8 Pa (N/m2) = 6.895×10-3 N/mm2 = 6.895×10-2 bar = 27.71 in H2O at 61 oF (16.7 oC) = 703.1 mm H2O at 61 oF (16.7 oC) = 2.0416 in mercury at 61 oF (16.7 oC) = 51.8 mm mercury at 61 oF (16.7 oC) = 703.6 kg/m2 = 0.06895 atm = 2.307 Ft. H2O = 16 ounces
Example - Convert from Head to Pressure
A head of 64 ft can be converted to pressure by using the second table:
64 ftH2O = 27.7 psi (lb/in2)
• Basics
Pressure to Head Unit Converter
Pressure vs. head units - like lb/in2, atm, inches mercury, bars, Pa and more.
Pump Head and Pressure: Conversion, Calculations, and Charts
Converting head (ft or m) to pressure (psi or bar, kg/cm2) and vice versa.
Static Pressure vs. Head
Pressure in pounds per square inch (psi) vs. head in feet of water (ft h2o).
