Specific Heat is the amount of heat required to change one mass unit of a substance by one degree in temperature.
Specific Heat Converter
The calculator below can be used to convert between some common specific heat units
Use the links to see tabulated values of specific heat of gases , common liquids and fluids , food and foodstuff , metals and semimetals , common solids and other common substances .
Specific Heat Converting Chart
Download and print Specific Heat Converting Chart
Use of the chart is illustrated below.
1000 J/kg o C equals to 1 kJ/kg o C or 0.239 Btu/lb o F .
Basics
The SI-system, unit converters, physical constants, drawing scales and more.
Material Properties
Thermodynamics
Air - Specific Heat Ratio
Specific Heat Ratio of air at temperatures ranging -40 - 1000 degC (-40 - 1500 degF) at standard atmospheric pressure - Imperial and SI Units.
Air - Specific Heat vs. Temperature at Constant Pressure
Online calculator with figures and tables showing specific heat (Cp and Cv) of dry air vs. temperature and pressure. SI and imperial units.
Carbon Dioxide - Specific Heat of Gas vs. Temperature
Specific heat of Carbon Dioxide gas - CO2 - temperatures ranging 175 - 6000 K.
Food and Foodstuff - Specific Heat
Specific heat of common food and foodstuff like apples, bass, beef, pork and many more.
Gases - Molar Specific Heats
Molar specific heats for some common gases at constant volume.
Gases - Specific Heats and Individual Gas Constants
Heat, Work and Energy
Heat vs. work vs. energy.
Human Body - Specific Heat
Specific heat of the human body - compared to substances like protein and wood.
Liquids and Fluids - Specific Heats
Metals - Specific Heats
Mixing Fluids
Final mass and temperature when mixing fluids.
Polymers - Specific Heats
Specific heat of polymers like epoxy, PET, polycarbonate and more.
Solids - Specific Heats
Specific Heat of common Substances
Storing Thermal Heat in Materials
Energy stored as sensible heat in materials.
Unit Factor Method
Water - Specific Heat vs. Temperature
Water - Thermophysical Properties
Water Vapor - Specific Heat vs. Temperature
Specific heat of Water Vapor - H2O - at temperatures ranging 175 - 6000 K.
