- t -
(oF)
Specific Heat Ratio of Air at Standard Atmospheric Pressure in SI Units:
Temperature - t - (oC) | Specific Heat Ratio k = cp / cv |
-40 | 1.401 |
-20 | 1.401 |
0 | 1.401 |
5 | 1.401 |
10 | 1.401 |
15 | 1.401 |
20 | 1.401 |
25 | 1.401 |
30 | 1.400 |
40 | 1.400 |
50 | 1.400 |
60 | 1.399 |
70 | 1.399 |
80 | 1.399 |
90 | 1.398 |
100 | 1.397 |
200 | 1.390 |
300 | 1.379 |
400 | 1.368 |
500 | 1.357 |
1000 | 1.321 |
Online calculator with figures and tables showing specific heat (Cp and Cv) of dry air vs. temperature and pressure. SI and imperial units.
