Moist Air - Mole Fraction of Water Vapor
The mole fraction of water vapor is the ratio of the number of mole of water vapor in the moist air - to the total number of mole of dry air and water vapor.
The mole fraction of water vapor in moist air can be expressed as
xw = nw / (na + nw)                                            (1)
xw = mole fraction of water vapor
nw = mole of water
na = mole of air
Air Psychrometrics
Gases - Molar Specific Heats
Molar specific heats for some common gases at constant volume.
Moist Air - Water Vapor and Saturation Pressure
Saturation pressure of water vapor in moist air vs. temperature.
Mole and the Avagadro's Number
The mole is the SI base unit for an amount of a substance.
Saturated Salt Solutions - Controlling Air Humidity
A salt solutions can be used maintain a particular value of relative humidity.
The Ideal Gas Law
Universal and Individual Gas Constants
