The atmospheric boiling point of ethylene is -104 °C (-155 °F), which gives a shift in viscosity at that temperature.
The output dynamic viscosity is given as Pa*s, N*s/m 2 , cP, mPa*s, lb f *s/ft 2 and lb m /(ft*h),
while the kinematic viscosity is given as cSt, m 2 /s, and ft 2 /s
See also other properties of Ethylene at varying temperature and pressure: Density and Specific Weight , Specific heat (heat capacity) and Thermal conductivity , and Thermophysical properties at standard conditions ,
as well as dynamic and kinematic viscosity of air , ammonia , benzene , butane , carbon dioxide , ethanol , methane , methanol , nitrogen , oxygen , propane and water .
Dynamic viscosity of ethylene at varying temperature and 1, 10 and 50 bara (14.5, 145 and 725 psia):
Kinematic viscosity of ethylene at varying temperature and 1, 10 and 50 bara (14.5, 145 and 725 psia):
Dynamic viscosity of ethylene at gas-liquid equilibrium pressure:
Kinematic viscosity of ethylene at gas-liquid equilibrium pressure:
Dynamic (absolute) and kinematic viscosity of ethylene at given temperatures and pressures, SI and Imperial units:
For full table with Imperial Units and Kinematic Viscosity - rotate the screen!
State | Temperature | Pressure | Dynamic (Absolute) Viscosity | Kinematic viscosity | ||||||||
[K] | [°C] | [°F] | [bara] | [psia] | [μPa s] | [cP], [mPa s] | [x10 -6 lb f s/ft 2 ] | [x10 -6 lb m /ft s] | [lb m /ft h] | [cSt], [x10 -6 m 2 /s] | [x10 -6 ft 2 /s] | |
Liquid at equilibrium | 103.99 | -169.16 | -272.49 | 1.22E-03 | 0.0177 | 685.7 | 0.6857 | 14.32 | 460.8 | 1.659 | 1.048 | 11.28 |
105 | -168 | -271 | 1.46E-03 | 0.0211 | 662.5 | 0.6625 | 13.84 | 445.2 | 1.603 | 1.014 | 10.92 | |
115 | -158 | -253 | 6.97E-03 | 0.101 | 488.1 | 0.4881 | 10.19 | 328.0 | 1.181 | 0.7620 | 8.202 | |
125 | -148 | -235 | 0.0253 | 0.366 | 378.7 | 0.3787 | 7.909 | 254.5 | 0.9161 | 0.6033 | 6.494 | |
135 | -138 | -217 | 0.0739 | 1.07 | 305.5 | 0.3055 | 6.381 | 205.3 | 0.7390 | 0.4971 | 5.350 | |
145 | -128 | -199 | 0.183 | 2.66 | 253.8 | 0.2538 | 5.301 | 170.5 | 0.6140 | 0.4221 | 4.543 | |
155 | -118 | -181 | 0.398 | 5.77 | 215.7 | 0.2157 | 4.505 | 144.9 | 0.5218 | 0.3670 | 3.950 | |
165 | -108 | -163 | 0.777 | 11.3 | 186.4 | 0.1864 | 3.893 | 125.3 | 0.4509 | 0.3248 | 3.496 | |
175 | -98.2 | -145 | 1.39 | 20.2 | 163.0 | 0.1630 | 3.404 | 109.5 | 0.3943 | 0.2913 | 3.136 | |
185 | -88.2 | -127 | 2.33 | 33.9 | 143.9 | 0.1439 | 3.005 | 96.70 | 0.3481 | 0.2642 | 2.844 | |
195 | -78.2 | -109 | 3.69 | 53.5 | 127.7 | 0.1277 | 2.667 | 85.81 | 0.3089 | 0.2413 | 2.597 | |
205 | -68.2 | -90.7 | 5.56 | 80.7 | 113.8 | 0.1138 | 2.377 | 76.47 | 0.2753 | 0.2218 | 2.388 | |
215 | -58.2 | -72.7 | 8.05 | 117 | 101.4 | 0.1014 | 2.118 | 68.14 | 0.2453 | 0.2045 | 2.202 | |
225 | -48.2 | -54.7 | 11.3 | 164 | 90.22 | 0.09022 | 1.884 | 60.63 | 0.2183 | 0.1891 | 2.035 | |
235 | -38.2 | -36.7 | 15.3 | 223 | 79.89 | 0.07989 | 1.669 | 53.68 | 0.1933 | 0.1748 | 1.882 | |
245 | -28.2 | -18.7 | 20.4 | 296 | 70.14 | 0.07014 | 1.465 | 47.13 | 0.1697 | 0.1614 | 1.738 | |
255 | -18.2 | -0.7 | 26.5 | 384 | 60.69 | 0.06069 | 1.268 | 40.78 | 0.1468 | 0.1486 | 1.599 | |
265 | -8.1 | 17.3 | 33.9 | 492 | 51.11 | 0.05111 | 1.067 | 34.34 | 0.1236 | 0.1358 | 1.461 | |
275 | 1.9 | 35.3 | 42.8 | 620 | 40.40 | 0.04040 | 0.8438 | 27.15 | 0.09773 | 0.1221 | 1.314 | |
Gas at equilibrium | 103.99 | -169.16 | -272.49 | 1.22E-03 | 0.0177 | 0.773 | 7.73E-04 | 0.01614 | 0.5192 | 1.87E-03 | 195.2 | 2101 |
105 | -168.2 | -271 | 1.46E-03 | 0.0211 | 1.001 | 1.00E-03 | 0.02091 | 0.6726 | 2.42E-03 | 213.8 | 2301 | |
115 | -158.2 | -252.7 | 6.97E-03 | 0.101 | 2.734 | 2.73E-03 | 0.05710 | 1.837 | 6.61E-03 | 133.5 | 1437 | |
125 | -148.2 | -234.7 | 0.0253 | 0.366 | 3.826 | 3.83E-03 | 0.07991 | 2.571 | 9.26E-03 | 55.98 | 602.6 | |
135 | -138.2 | -216.7 | 0.0739 | 1.07 | 4.558 | 4.56E-03 | 0.09520 | 3.063 | 0.01103 | 24.55 | 264.3 | |
145 | -128.2 | -198.7 | 0.183 | 2.66 | 5.089 | 5.09E-03 | 0.1063 | 3.420 | 0.01231 | 11.83 | 127.3 | |
155 | -118.2 | -180.7 | 0.398 | 5.77 | 5.511 | 5.51E-03 | 0.1151 | 3.703 | 0.01333 | 6.261 | 67.39 | |
165 | -108.2 | -162.7 | 0.777 | 11.3 | 5.880 | 5.88E-03 | 0.1228 | 3.951 | 0.01422 | 3.599 | 38.74 | |
175 | -98.2 | -145 | 1.39 | 20.2 | 6.228 | 6.23E-03 | 0.1301 | 4.185 | 0.01507 | 2.220 | 23.90 | |
185 | -88.2 | -127 | 2.33 | 33.9 | 6.577 | 6.58E-03 | 0.1374 | 4.420 | 0.01591 | 1.452 | 15.63 | |
195 | -78.2 | -109 | 3.69 | 53.5 | 6.941 | 6.94E-03 | 0.1450 | 4.664 | 0.01679 | 0.9976 | 10.74 | |
205 | -68.2 | -90.7 | 5.56 | 80.7 | 7.334 | 7.33E-03 | 0.1532 | 4.928 | 0.01774 | 0.7136 | 7.681 | |
215 | -58.2 | -72.7 | 8.05 | 117 | 7.769 | 7.77E-03 | 0.1623 | 5.221 | 0.01879 | 0.5278 | 5.681 | |
225 | -48.2 | -54.7 | 11.3 | 164 | 8.261 | 8.26E-03 | 0.1725 | 5.551 | 0.01998 | 0.4013 | 4.319 | |
235 | -38.2 | -36.7 | 15.3 | 223 | 8.834 | 8.83E-03 | 0.1845 | 5.936 | 0.02137 | 0.3120 | 3.359 | |
245 | -28.2 | -18.7 | 20.4 | 296 | 9.525 | 9.53E-03 | 0.1989 | 6.401 | 0.02304 | 0.2470 | 2.659 | |
255 | -18.2 | -0.7 | 26.5 | 384 | 10.4 | 0.01040 | 0.2172 | 6.988 | 0.02516 | 0.1980 | 2.132 | |
265 | -8.1 | 17.3 | 33.9 | 492 | 11.63 | 0.01163 | 0.2429 | 7.815 | 0.02813 | 0.1602 | 1.724 | |
275 | 1.9 | 35.3 | 42.8 | 620 | 13.77 | 0.01377 | 0.2876 | 9.253 | 0.03331 | 0.1294 | 1.392 | |
Liquid | 150 | -123 | -190 | 1 | 14.5 | 233.4 | 0.2334 | 4.875 | 156.8 | 0.5646 | 0.3925 | 4.225 |
169.16 | -103.99 | -155.18 | 1 | 14.5 | 176.1 | 0.1761 | 3.678 | 118.3 | 0.4260 | 0.3055 | 3.289 | |
Gas | 169.16 | -103.99 | -155.18 | 1 | 14.5 | 6.026 | 6.03E-03 | 0.1259 | 4.049 | 0.01458 | 2.922 | 31.45 |
225 | -48.2 | -54.7 | 1 | 14.5 | 7.838 | 7.84E-03 | 0.1637 | 5.267 | 0.01896 | 5.157 | 55.51 | |
300 | 26.9 | 80.3 | 1 | 14.5 | 10.38 | 0.01038 | 0.2168 | 6.975 | 0.02511 | 9.179 | 98.80 | |
375 | 102 | 215 | 1 | 14.5 | 12.83 | 0.01283 | 0.2680 | 8.621 | 0.03104 | 14.22 | 153.1 | |
450 | 177 | 350 | 1 | 14.5 | 15.09 | 0.01509 | 0.3152 | 10.14 | 0.03650 | 20.10 | 216.4 | |
Liquid | 150 | -123 | -190 | 10 | 145 | 233.0 | 0.2330 | 4.866 | 156.6 | 0.5636 | 0.3914 | 4.213 |
221.33 | -51.82 | -61.28 | 10 | 145 | 94.21 | 0.094 | 1.968 | 63.31 | 0.2279 | 0.1946 | 2.094 | |
Gas | 221.33 | -51.82 | -61.28 | 10 | 145 | 8.072 | 8.07E-03 | 0.1686 | 5.424 | 0.01953 | 0.4425 | 4.763 |
225 | -48.2 | -54.7 | 10 | 145 | 8.177 | 8.18E-03 | 0.1708 | 5.495 | 0.01978 | 0.4611 | 4.964 | |
300 | 26.9 | 80.3 | 10 | 145 | 10.59 | 0.01059 | 0.2212 | 7.116 | 0.02562 | 0.8874 | 9.552 | |
375 | 102 | 215 | 10 | 145 | 13.02 | 0.01302 | 0.2719 | 8.749 | 0.03150 | 1.408 | 15.16 | |
450 | 177 | 350 | 10 | 145 | 15.28 | 0.01528 | 0.3191 | 10.27 | 0.03696 | 2.010 | 21.63 | |
Liquid | 150 | -123 | -190 | 50 | 725 | 231.2 | 0.2312 | 4.829 | 155.4 | 0.5593 | 0.3864 | 4.159 |
225 | -48.2 | -54.7 | 50 | 725 | 93.29 | 0.09329 | 1.948 | 62.69 | 0.2257 | 0.1916 | 2.062 | |
281.98 | 8.83 | 47.89 | 50 | 725 | 27.67 | 0.02767 | 0.5779 | 18.59 | 0.06694 | 0.1090 | 1.173 | |
Gas | 281.98 | 8.83 | 47.89 | 50 | 725 | 19.00 | 0.01900 | 0.3968 | 12.77 | 0.04596 | 0.1085 | 1.168 |
300 | 26.9 | 80.3 | 50 | 725 | 13.34 | 0.01334 | 0.2786 | 8.964 | 0.03227 | 0.1520 | 1.636 | |
375 | 102 | 215 | 50 | 725 | 14.29 | 0.01429 | 0.2985 | 9.602 | 0.03457 | 0.2740 | 2.949 | |
450 | 177 | 350 | 50 | 725 | 16.28 | 0.01628 | 0.3400 | 10.94 | 0.03938 | 0.4058 | 4.368 | |
Liquid | 150 | -123 | -190 | 100 | 1450 | 229.0 | 0.2290 | 4.783 | 153.9 | 0.5540 | 0.3804 | 4.094 |
225 | -48.2 | -55 | 100 | 1450 | 96.61 | 0.09661 | 2.018 | 64.92 | 0.2337 | 0.1941 | 2.090 | |
Supercritical phase | 300 | 27 | 80 | 100 | 1450 | 37.62 | 0.03762 | 0.7857 | 25.28 | 0.09101 | 0.1165 | 1.254 |
375 | 102 | 215 | 100 | 1450 | 17.40 | 0.01740 | 0.3634 | 11.69 | 0.04209 | 0.1423 | 1.532 | |
450 | 177 | 350 | 100 | 1450 | 18.01 | 0.01801 | 0.3761 | 12.10 | 0.04357 | 0.2119 | 2.281 |
Viscosity Dynamic, Absolute
centipoise [cP], gram/(centimeter second) [g/(cm s)] = poise [P], kilogram/meter second [kg/m s]=newton second/square meter [N s/m 2 ]= pascal second [Pa s], pound/(foot hour) [lb/(ft h)], pound/(foot second) [lb/(ft s)], reyn [reyn]
Viscosity Kinematic
centistoke [cSt] = square millimeter/second [mm 2 /s], square foot/hour [ft 2 /h], square foot/second [ft 2 /s], square inch/second [in 2 /s], square meter/hour [m 2 /h], square meter/second [m 2 /s], stoke [St] = square centimeter/second [cm 2 /s]
Online calculator, figures and table showing dynamic and kinematic viscosity of carbon dioxide, CO2, at varying temperature and pressure - Imperial and SI Units.
Online calculator, figures and tables showing dynamic and kinematic viscosity of ethane, C2H6, at varying temperature and pressure - Imperial and SI Units
Online calculator, figures and tables showing dynamic and kinematic viscosity of nitrogen, N2, at varying temperature and pressure - Imperial and SI Units.
