The output dynamic viscosity is given as Pa*s, N*s/m 2 , cP, mPa*s, lb f *s/ft 2 and lb m /(ft*h),
while the kinematic viscosity is given as cSt, m 2 /s, and ft 2 /s
See also other properties of Nitrogen at varying temperature and pressure : Density and specific weight , Prandtl number , Specific heat (Heat capacity) , Thermal conductivity and thermal diffusivity , and thermophysical properties at standard conditions ,
as well as dynamic and kinematic viscosity of air , ammonia , benzene , butane , carbon dioxide , ethane , ethanol , ethylene , methane , methanol , oxygen , propane and water .
Nitrogen dynamic and kinematic viscosity at atmospheric pressure and varying temperature:
Dynamic viscosity of nitrogen at varying temperature and 1, 10 and 100 bara (14.5, 145 and 1450 psia):
Dynamic viscosity at gas-liquid equilibrium pressure:
Kinematic viscosity at gas-liquid equilibrium pressure:
Dynamic (absolute) and kinematic viscosity of nitrogen at given temperatures and pressures, SI and Imperial units:
State | Temperature | Pressure < | Dynamic (Absolute) Viscosity | Kinematic Viscosity | ||||||||
[K] | [°C] | [°F] | [MPa] | [bara] | [μPa s] | [cP] | [lb f s/ft 2 *10 -6 ] | [lb m /ft s*10 -6 ] | [lb m /ft h] | [cSt], [m 2 /s*10 -6 ] | [ft 2 /s*10 -6 ] | |
Liquid at equilibrium | 63.15 | -210.0 | -346.0 | 0.013 | 0.125 | 311.6 | 0.3116 | 6.508 | 209.4 | 0.7538 | 0.3593 | 3.867 |
69 | -204 | -335 | 0.033 | 0.332 | 230.9 | 0.2309 | 4.821 | 155.1 | 0.5584 | 0.2739 | 2.948 | |
75 | -198 | -325 | 0.076 | 0.760 | 176.8 | 0.1768 | 3.692 | 118.8 | 0.4276 | 0.2164 | 2.330 | |
79 | -194 | -317 | 0.122 | 1.22 | 150.7 | 0.1507 | 3.148 | 101.3 | 0.3646 | 0.1887 | 2.031 | |
85 | -188 | -307 | 0.229 | 2.29 | 121.3 | 0.1213 | 2.534 | 81.52 | 0.2935 | 0.1575 | 1.695 | |
89 | -184 | -299 | 0.331 | 3.31 | 106.2 | 0.1062 | 2.218 | 71.35 | 0.2569 | 0.1415 | 1.524 | |
95 | -178 | -289 | 0.541 | 5.41 | 88.00 | 0.08800 | 1.838 | 59.14 | 0.2129 | 0.1225 | 1.319 | |
99 | -174 | -281 | 0.726 | 7.26 | 78.42 | 0.07842 | 1.638 | 52.70 | 0.1897 | 0.1128 | 1.214 | |
105 | -168 | -271 | 1.08 | 10.8 | 65.29 | 0.06529 | 1.364 | 43.87 | 0.1579 | 0.0993 | 1.069 | |
109 | -164 | -263 | 1.38 | 13.8 | 57.79 | 0.05779 | 1.207 | 38.83 | 0.1398 | 0.09185 | 0.9887 | |
115 | -158 | -253 | 1.94 | 19.4 | 47.29 | 0.04729 | 0.9877 | 31.78 | 0.1144 | 0.08172 | 0.8796 | |
121 | -152 | -242 | 2.64 | 26.4 | 36.51 | 0.03651 | 0.7625 | 24.53 | 0.08832 | 0.07166 | 0.7713 | |
Gas at equilibrium | 63.15 | -210.0 | -346.0 | 0.013 | 0.125 | 4.376 | 0.00438 | 0.0914 | 2.941 | 0.01059 | 6.490 | 69.86 |
69 | -204 | -335 | 0.033 | 0.332 | 4.809 | 0.00481 | 0.1004 | 3.231 | 0.01163 | 2.908 | 31.30 | |
75 | -198 | -325 | 0.076 | 0.760 | 5.262 | 0.00526 | 0.1099 | 3.536 | 0.01273 | 1.486 | 16.00 | |
79 | -194 | -317 | 0.122 | 1.22 | 5.573 | 0.00557 | 0.1164 | 3.745 | 0.01348 | 1.014 | 10.92 | |
85 | -188 | -307 | 0.229 | 2.29 | 6.057 | 0.00606 | 0.1265 | 4.070 | 0.01465 | 0.6165 | 6.636 | |
89 | -184 | -299 | 0.331 | 3.31 | 6.395 | 0.00639 | 0.1336 | 4.297 | 0.01547 | 0.4604 | 4.956 | |
95 | -178 | -289 | 0.541 | 5.41 | 6.935 | 0.00694 | 0.1448 | 4.660 | 0.01678 | 0.3114 | 3.352 | |
99 | -174 | -281 | 0.726 | 7.26 | 7.326 | 0.00733 | 0.1530 | 4.923 | 0.01772 | 0.2459 | 2.647 | |
105 | -168 | -271 | 1.08 | 10.8 | 7.980 | 0.00798 | 0.1667 | 5.363 | 0.01931 | 0.1775 | 1.911 | |
109 | -164 | -263 | 1.38 | 13.8 | 8.487 | 0.00849 | 0.1772 | 5.703 | 0.02053 | 0.1448 | 1.559 | |
115 | -158 | -253 | 1.94 | 19.4 | 9.440 | 0.00944 | 0.1971 | 6.343 | 0.02283 | 0.1081 | 1.164 | |
121 | -152 | -242 | 2.64 | 26.4 | 10.95 | 0.01095 | 0.2288 | 7.360 | 0.02650 | 0.08082 | 0.8699 | |
Liquid | 63.17 | -210.0 | -346.0 | 0.1 | 1 | 311.6 | 0.3116 | 6.508 | 209.4 | 0.7538 | 0.3593 | 3.867 |
77.24 | -195.9 | -320.6 | 0.1 | 1 | 161.4 | 0.1614 | 3.371 | 108.5 | 0.3904 | 0.2001 | 2.154 | |
77.24 | -195.9 | -320.6 | 0.1 | 1 | 5.435 | 0.00544 | 0.1135 | 3.652 | 0.01315 | 1.193 | 12.84 | |
Gas | 80 | -193.2 | -315.7 | 0.1 | 1 | 5.623 | 0.00562 | 0.1174 | 3.778 | 0.01360 | 1.284 | 13.82 |
100 | -173.2 | -279.7 | 0.1 | 1 | 6.958 | 0.00696 | 0.1453 | 4.676 | 0.01683 | 2.024 | 21.79 | |
120 | -153.2 | -243.7 | 0.1 | 1 | 8.244 | 0.00824 | 0.1722 | 5.540 | 0.01994 | 2.903 | 31.25 | |
140 | -133.2 | -207.7 | 0.1 | 1 | 9.480 | 0.00948 | 0.1980 | 6.370 | 0.02293 | 3.911 | 42.10 | |
160 | -113.2 | -171.7 | 0.1 | 1 | 10.67 | 0.01067 | 0.2228 | 7.170 | 0.02581 | 5.043 | 54.28 | |
180 | -93.2 | -135.7 | 0.1 | 1 | 11.81 | 0.01181 | 0.2467 | 7.936 | 0.02857 | 6.289 | 67.69 | |
200 | -73.2 | -99.7 | 0.1 | 1 | 12.91 | 0.01291 | 0.2696 | 8.675 | 0.03123 | 7.648 | 82.32 | |
220 | -53.2 | -63.7 | 0.1 | 1 | 13.97 | 0.01397 | 0.2918 | 9.387 | 0.03379 | 9.107 | 98.03 | |
240 | -33.2 | -27.7 | 0.1 | 1 | 15.00 | 0.01500 | 0.3133 | 10.08 | 0.03629 | 10.68 | 114.9 | |
260 | -13.2 | 8.3 | 0.1 | 1 | 15.99 | 0.01599 | 0.3340 | 10.74 | 0.03868 | 12.33 | 132.7 | |
280 | 6.9 | 44.3 | 0.1 | 1 | 16.96 | 0.01696 | 0.3542 | 11.40 | 0.04103 | 14.09 | 151.6 | |
300 | 26.9 | 80.3 | 0.1 | 1 | 17.89 | 0.01789 | 0.3736 | 12.02 | 0.04328 | 15.93 | 171.5 | |
320 | 46.9 | 116.3 | 0.1 | 1 | 18.80 | 0.01880 | 0.3926 | 12.63 | 0.04548 | 17.85 | 192.2 | |
340 | 66.9 | 152.3 | 0.1 | 1 | 19.68 | 0.01968 | 0.4110 | 13.22 | 0.04761 | 19.86 | 213.8 | |
360 | 86.9 | 188.3 | 0.1 | 1 | 20.55 | 0.02055 | 0.4292 | 13.81 | 0.04971 | 21.96 | 236.4 | |
400 | 126.9 | 260.3 | 0.1 | 1 | 22.21 | 0.02221 | 0.4639 | 14.92 | 0.05373 | 26.37 | 283.9 | |
500 | 226.9 | 440.3 | 0.1 | 1 | 26.06 | 0.02606 | 0.5443 | 17.51 | 0.06304 | 38.69 | 416.4 | |
600 | 326.9 | 620.3 | 0.1 | 1 | 29.58 | 0.02958 | 0.6178 | 19.88 | 0.07156 | 52.70 | 567.2 | |
700 | 426.9 | 800.3 | 0.1 | 1 | 32.83 | 0.03283 | 0.6857 | 22.06 | 0.07942 | 68.24 | 734.5 | |
800 | 526.9 | 980.3 | 0.1 | 1 | 35.89 | 0.03589 | 0.7496 | 24.12 | 0.08682 | 85.25 | 917.6 | |
900 | 626.9 | 1160.3 | 0.1 | 1 | 38.78 | 0.03878 | 0.8099 | 26.06 | 0.09381 | 103.63 | 1115.5 | |
1000 | 726.9 | 1340.3 | 0.1 | 1 | 41.54 | 0.04154 | 0.8676 | 27.91 | 0.1005 | 123.34 | 1327.6 | |
Liquid | 63.37 | -210 | -346 | 1 | 10 | 311.8 | 0.3118 | 6.512 | 209.5 | 0.7543 | 0.3592 | 3.867 |
80 | -193 | -316 | 1 | 10 | 147.3 | 0.1473 | 3.076 | 98.98 | 0.3563 | 0.1850 | 1.991 | |
100 | -173 | -280 | 1 | 10 | 76.26 | 0.07626 | 1.593 | 51.24 | 0.1845 | 0.1104 | 1.188 | |
103.8 | -169.4 | -272.9 | 1 | 10 | 67.78 | 0.06778 | 1.416 | 45.55 | 0.1640 | 0.1018 | 1.096 | |
Gas | 103.8 | -169.4 | -272.9 | 1 | 10 | 7.835 | 0.00784 | 0.1636 | 5.265 | 0.01895 | 0.1896 | 2.040 |
140.0 | -133.2 | -207.7 | 1 | 10 | 9.844 | 0.00984 | 0.2056 | 6.615 | 0.02381 | 0.3785 | 4.074 | |
160 | -113 | -172 | 1 | 10 | 10.96 | 0.01096 | 0.2289 | 7.365 | 0.02651 | 0.4957 | 5.336 | |
180 | -93 | -136 | 1 | 10 | 12.06 | 0.01206 | 0.2519 | 8.104 | 0.02917 | 0.6239 | 6.716 | |
200 | -73.2 | -99.7 | 1 | 10 | 13.13 | 0.01313 | 0.2742 | 8.823 | 0.03176 | 0.7629 | 8.212 | |
240 | -33.2 | -27.7 | 1 | 10 | 15.17 | 0.01517 | 0.3168 | 10.19 | 0.03670 | 1.071 | 11.52 | |
300 | 26.9 | 80.3 | 1 | 10 | 18.01 | 0.01801 | 0.3761 | 12.10 | 0.04357 | 1.604 | 17.27 | |
400 | 127 | 260 | 1 | 10 | 22.29 | 0.02229 | 0.4655 | 14.98 | 0.05392 | 2.647 | 28.49 | |
500 | 227 | 440 | 1 | 10 | 26.13 | 0.02613 | 0.5457 | 17.56 | 0.06321 | 3.879 | 41.75 | |
600 | 327 | 620 | 1 | 10 | 29.63 | 0.02963 | 0.6188 | 19.91 | 0.07167 | 5.298 | 57.0 | |
800 | 527 | 980 | 1 | 10 | 35.92 | 0.03592 | 0.7502 | 24.14 | 0.08689 | 8.532 | 91.84 | |
1100 | 827 | 1520 | 1 | 10 | 44.22 | 0.04422 | 0.9236 | 29.72 | 0.1070 | 14.48 | 155.9 | |
1600 | 1327 | 2420 | 1 | 10 | 56.41 | 0.05641 | 1.178 | 37.91 | 0.1365 | 26.85 | 289.0 | |
Liquid | 100 | -173 | -280 | 5 | 50 | 84.51 | 0.08451 | 1.765 | 56.79 | 0.2044 | 0.1186 | 1.277 |
Supercritical phase | 600 | 327 | 620 | 5 | 50 | 29.88 | 0.02988 | 0.6241 | 20.08 | 0.07229 | 1.088 | 11.71 |
1100 | 827 | 1520 | 5 | 50 | 44.33 | 0.04433 | 0.9259 | 29.79 | 0.1072 | 2.941 | 31.66 | |
1600 | 1327 | 2420 | 5 | 50 | 56.48 | 0.05648 | 1.180 | 37.95 | 0.1366 | 5.427 | 58.42 | |
Liquid | 65.32 | -208 | -342 | 10 | 100 | 314.0 | 0.3140 | 6.558 | 211.0 | 0.7596 | 0.3589 | 3.863 |
80 | -193 | -316 | 10 | 100 | 169.0 | 0.1690 | 3.530 | 113.6 | 0.4088 | 0.2065 | 2.223 | |
100 | -173 | -280 | 10 | 100 | 93.65 | 0.09365 | 1.956 | 62.93 | 0.2265 | 0.1277 | 1.374 | |
Supercritical phase | 200 | -73.2 | -99.7 | 10 | 100 | 17.70 | 0.01770 | 0.3697 | 11.89 | 0.04282 | 0.09 | 0.9555 |
300 | 26.9 | 80.3 | 10 | 100 | 19.96 | 0.01996 | 0.4169 | 13.41 | 0.04829 | 0.1787 | 1.923 | |
400 | 127 | 260 | 10 | 100 | 23.51 | 0.02351 | 0.4910 | 15.80 | 0.05687 | 0.2896 | 3.117 | |
500 | 227 | 440 | 10 | 100 | 26.99 | 0.02699 | 0.5637 | 18.14 | 0.06529 | 0.4184 | 4.504 | |
600 | 327 | 620 | 10 | 100 | 30.28 | 0.03028 | 0.6325 | 20.35 | 0.07326 | 0.5635 | 6.066 | |
1100 | 827 | 1520 | 10 | 100 | 44.49 | 0.04449 | 0.9293 | 29.90 | 0.1076 | 1.500 | 16.14 | |
1600 | 1327 | 2420 | 10 | 100 | 56.48 | 0.05648 | 1.180 | 37.95 | 0.1366 | 2.745 | 29.55 |
Viscosity, Dynamic (Absolute)
centipoise [cP], gram/(centimeter second) [g/(cm s)] = poise [P], kilogram/meter second [kg/m s]=newton second/square meter [N s/m 2 ]= pascal second [Pa s], pound/(foot hour) [lb/(ft h)], pound/(foot second) [lb/(ft s)], reyn [reyn]
Viscosity, Kinematic
centistoke [cSt] = square millimeter/second [mm 2 /s], square foot/hour [ft 2 /h], square foot/second [ft 2 /s], square inch/second [in 2 /s], square meter/hour [m 2 /h], square meter/second [m 2 /s], stoke [St] = square centimeter/second [cm 2 /s]
Figures and tables showing thermal diffusivity of nitrogen at varying temperarure and pressure, SI and Imperial units.
