ρ = m / V (1)
γ = m g / V
= ρ g (2)
Tabulated values of oxygen density at given temperature and pressure (SI and Imperial units) as well as density units conversion are given below the figures.
Online Oxygen Density Calculator
The calculator below can be used to estimate the density and specific weight of gaseous oxygen at given temperature and pressure.
Choose the actual pressure: 1 bara / 14.5 psia; 10 bara / 145 psia; 50 bara / 725 psia;
See also other properties of Oxygen at varying temperature and pressure: Dynamic and Kinematic Viscosity and Specific Heat (Heat Capacity), and Thermophysical properties at standard conditions,
as well as density and specific weight of acetone, air, ammonia, argon, benzene, butane, carbon dioxide, carbon monoxide, ethane, ethanol, ethylene, helium, hydrogen, methane, methanol, nitrogen, pentane, propane, toluene and water . Density of crude oil , Density of fuel oils , Density of lubricating oil and Density of jet fuel as function of temperature.
Density and specific weight of oxygen gas at varying temperature and atmospheric pressure, SI and Imperial units:
Density of oxygen at varying temperature and pressure, SI and Imperial units:
Density of oxygen at varying temperature and equilibrium pressure, SI and Imperial units:
Density and specific weight of oxygen at given temperatures and pressures:
| State | Temperature | Pressure | Density | Specific weight | |||||||
| (K) | (°C) | (°F) | (bara) | (psia) | (mol/dm3) | (g/l), (kg/m3) | (lbm/ft3) | (sl/ft3) | (N/m3) | (lbf/ft3) | |
| Liquid at equilibrium | 54.361 | -218.79 | -361.82 | 0.0015 | 0.0212 | 40.82 | 1306 | 81.54 | 2.534 | 12809 | 81.54 |
| 70 | -203 | -334 | 0.0626 | 0.908 | 38.66 | 1237 | 77.22 | 2.400 | 12131 | 77.22 | |
| 75 | -198 | -325 | 0.145 | 2.11 | 37.94 | 1214 | 75.78 | 2.355 | 11905 | 75.78 | |
| 80 | -193 | -316 | 0.301 | 4.37 | 37.20 | 1190 | 74.32 | 2.310 | 11675 | 74.32 | |
| 90 | -183 | -298 | 0.994 | 14.4 | 35.69 | 1142 | 71.30 | 2.216 | 11201 | 71.30 | |
| 100 | -173 | -280 | 2.54 | 36.8 | 34.09 | 1091 | 68.11 | 2.117 | 10699 | 68.11 | |
| 110 | -163 | -262 | 5.43 | 78.8 | 32.36 | 1036 | 64.65 | 2.009 | 10155 | 64.65 | |
| 120 | -153 | -244 | 10.2 | 148.3 | 30.43 | 973.9 | 60.80 | 1.890 | 9551 | 60.80 | |
| 130 | -143 | -226 | 17.5 | 253.7 | 28.20 | 902.5 | 56.34 | 1.751 | 8850 | 56.34 | |
| 140 | -133 | -208 | 27.9 | 404.3 | 25.42 | 813.3 | 50.77 | 1.578 | 7976 | 50.77 | |
| 145 | -128 | -199 | 34.5 | 500.0 | 23.60 | 755.2 | 47.14 | 1.465 | 7406 | 47.14 | |
| 150 | -123 | -190 | 42.2 | 611.9 | 21.11 | 675.5 | 42.17 | 1.311 | 6625 | 42.17 | |
| 154.58 | -118.57 | -181.43 | 50.4 | 731.4 | 13.63 | 436.2 | 27.23 | 0.846 | 4277 | 27.23 | |
| Gas at equilibrium | 54.361 | -218.79 | -361.82 | 0.0015 | 0.0212 | 0.000324 | 0.01036 | 0.000647 | 0.000020 | 0.1016 | 0.000647 |
| 70 | -203 | -334 | 0.0626 | 0.908 | 0.01080 | 0.3457 | 0.02158 | 0.00067 | 3.390 | 0.02158 | |
| 75 | -198 | -325 | 0.145 | 2.11 | 0.02351 | 0.7523 | 0.04696 | 0.00146 | 7.377 | 0.04696 | |
| 80 | -193 | -316 | 0.301 | 4.37 | 0.04589 | 1.469 | 0.09168 | 0.00285 | 14.40 | 0.09168 | |
| 90 | -183 | -298 | 0.994 | 14.4 | 0.1371 | 4.387 | 0.2739 | 0.00851 | 43.02 | 0.2739 | |
| 100 | -173 | -280 | 2.54 | 36.8 | 0.3258 | 10.43 | 0.6508 | 0.02023 | 102.2 | 0.6508 | |
| 110 | -163 | -262 | 5.43 | 78.8 | 0.6651 | 21.28 | 1.329 | 0.04129 | 208.7 | 1.329 | |
| 120 | -153 | -244 | 10.2 | 148.3 | 1.228 | 39.31 | 2.454 | 0.07627 | 385.5 | 2.454 | |
| 130 | -143 | -226 | 17.5 | 253.7 | 2.137 | 68.37 | 4.268 | 0.1327 | 670.5 | 4.268 | |
| 140 | -133 | -208 | 27.9 | 404.3 | 3.649 | 116.8 | 7.289 | 0.2265 | 1145 | 7.289 | |
| 145 | -128 | -199 | 34.5 | 500.0 | 4.841 | 154.9 | 9.671 | 0.3006 | 1519 | 9.671 | |
| 150 | -123 | -190 | 42.2 | 611.9 | 6.717 | 214.9 | 13.42 | 0.4171 | 2108 | 13.42 | |
| 154.58 | -118.57 | -181.43 | 50.4 | 731.4 | 13.63 | 436.2 | 27.23 | 0.8463 | 4277 | 27.23 | |
| Liquid | 54.37 | -218.8 | -361.8 | 1 | 14.5 | 40.81 | 1306 | 81.53 | 2.534 | 12807 | 81.53 |
| 60 | -213 | -352 | 1 | 14.5 | 40.06 | 1282 | 80.03 | 2.487 | 12572 | 80.03 | |
| 80 | -193 | -316 | 1 | 14.5 | 37.22 | 1191 | 74.35 | 2.311 | 11680 | 74.35 | |
| 90.06 | -183.09 | -297.56 | 1 | 14.5 | 35.69 | 1142 | 71.29 | 2.216 | 11199 | 71.29 | |
| Gas | 90.06 | -183.09 | -297.56 | 1 | 14.5 | 0.1379 | 4.413 | 0.2755 | 0.00856 | 43.28 | 0.2755 |
| 100 | -173 | -280 | 1 | 14.5 | 0.1232 | 3.941 | 0.2460 | 0.00765 | 38.65 | 0.2460 | |
| 120 | -153 | -244 | 1 | 14.5 | 0.1016 | 3.252 | 0.2030 | 0.00631 | 31.89 | 0.2030 | |
| 140 | -133 | -208 | 1 | 14.5 | 0.08669 | 2.774 | 0.1732 | 0.00538 | 27.20 | 0.1732 | |
| 160 | -113 | -172 | 1 | 14.5 | 0.07563 | 2.420 | 0.1511 | 0.00470 | 23.73 | 0.1511 | |
| 180 | -93.2 | -136 | 1 | 14.5 | 0.06710 | 2.147 | 0.1340 | 0.00417 | 21.05 | 0.1340 | |
| 200 | -73.2 | -99.7 | 1 | 14.5 | 0.06031 | 1.930 | 0.1205 | 0.00374 | 18.93 | 0.1205 | |
| 220 | -53.2 | -63.7 | 1 | 14.5 | 0.05478 | 1.753 | 0.1094 | 0.00340 | 17.19 | 0.1094 | |
| 240 | -33.2 | -27.7 | 1 | 14.5 | 0.05019 | 1.606 | 0.1003 | 0.00312 | 15.75 | 0.1003 | |
| 260 | -13.2 | 8.3 | 1 | 14.5 | 0.04631 | 1.482 | 0.09252 | 0.00288 | 14.53 | 0.09252 | |
| 280 | 6.9 | 44.3 | 1 | 14.5 | 0.04300 | 1.376 | 0.08590 | 0.00267 | 13.49 | 0.08590 | |
| 300 | 26.9 | 80.3 | 1 | 14.5 | 0.04013 | 1.284 | 0.08016 | 0.00249 | 12.59 | 0.08016 | |
| 320 | 46.9 | 116 | 1 | 14.5 | 0.03760 | 1.203 | 0.07510 | 0.00233 | 11.80 | 0.07510 | |
| 340 | 66.9 | 152 | 1 | 14.5 | 0.03538 | 1.132 | 0.07067 | 0.00220 | 11.10 | 0.07067 | |
| 360 | 86.9 | 188 | 1 | 14.5 | 0.03341 | 1.069 | 0.06674 | 0.00207 | 10.48 | 0.06674 | |
| 400 | 127 | 260 | 1 | 14.5 | 0.03007 | 0.9622 | 0.06007 | 0.00187 | 9.436 | 0.06007 | |
| 500 | 227 | 440 | 1 | 14.5 | 0.02405 | 0.7696 | 0.04804 | 0.00149 | 7.547 | 0.04804 | |
| 600 | 327 | 620 | 1 | 14.5 | 0.02004 | 0.6413 | 0.04004 | 0.00124 | 6.289 | 0.04004 | |
| 700 | 427 | 800 | 1 | 14.5 | 0.01718 | 0.5497 | 0.03432 | 0.00107 | 5.391 | 0.03432 | |
| 800 | 527 | 980 | 1 | 14.5 | 0.01503 | 0.4809 | 0.03002 | 0.000933 | 4.716 | 0.03002 | |
| 900 | 627 | 1160 | 1 | 14.5 | 0.01336 | 0.4275 | 0.02669 | 0.000829 | 4.192 | 0.02669 | |
| 1000 | 727 | 1340 | 1 | 14.5 | 0.01203 | 0.3848 | 0.02402 | 0.000747 | 3.774 | 0.02402 | |
| Liquid | 54.47 | -218.68 | -361.62 | 10 | 145 | 40.85 | 1307 | 81.59 | 2.536 | 12817 | 81.59 |
| 60 | -213 | -352 | 10 | 145 | 40.10 | 1283 | 80.10 | 2.489 | 12582 | 80.10 | |
| 80 | -193 | -316 | 10 | 145 | 37.25 | 1192 | 74.41 | 2.313 | 11690 | 74.41 | |
| 100 | -173 | -280 | 10 | 145 | 34.16 | 1093 | 68.23 | 2.121 | 10719 | 68.23 | |
| 119.62 | -153.53 | -244.35 | 10 | 145 | 30.51 | 976.3 | 60.95 | 1.894 | 9574 | 60.95 | |
| Gas | 119.62 | -153.53 | -244.35 | 10 | 145 | 1.202 | 38.46 | 2.401 | 0.07462 | 377.2 | 2.401 |
| 120 | -153 | -244 | 10 | 145 | 1.195 | 38.25 | 2.388 | 0.07422 | 375.1 | 2.388 | |
| 140 | -133 | -208 | 10 | 145 | 0.9497 | 30.39 | 1.897 | 0.05897 | 298.0 | 1.897 | |
| 160 | -113 | -172 | 10 | 145 | 0.8016 | 25.65 | 1.601 | 0.04977 | 251.5 | 1.601 | |
| 180 | -93.2 | -136 | 10 | 145 | 0.6978 | 22.33 | 1.394 | 0.04333 | 219.0 | 1.394 | |
| 200 | -73.2 | -99.7 | 10 | 145 | 0.6200 | 19.84 | 1.239 | 0.03850 | 194.6 | 1.239 | |
| 220 | -53.2 | -63.7 | 10 | 145 | 0.5588 | 17.88 | 1.116 | 0.03469 | 175.3 | 1.116 | |
| 240 | -33.2 | -27.7 | 10 | 145 | 0.5094 | 16.30 | 1.018 | 0.03163 | 159.8 | 1.018 | |
| 260 | -13.2 | 8.3 | 10 | 145 | 0.4681 | 14.98 | 0.9352 | 0.02907 | 146.9 | 0.9352 | |
| 280 | 6.9 | 44.3 | 10 | 145 | 0.4331 | 13.86 | 0.8653 | 0.02689 | 135.9 | 0.8653 | |
| 300 | 26.9 | 80.3 | 10 | 145 | 0.4035 | 12.91 | 0.8059 | 0.02505 | 126.6 | 0.8059 | |
| 320 | 46.9 | 116 | 10 | 145 | 0.3775 | 12.08 | 0.7541 | 0.02344 | 118.5 | 0.7541 | |
| 340 | 66.9 | 152 | 10 | 145 | 0.3547 | 11.35 | 0.7086 | 0.02202 | 111.3 | 0.7086 | |
| 360 | 86.9 | 188 | 10 | 145 | 0.3347 | 10.71 | 0.6686 | 0.02078 | 105.0 | 0.6686 | |
| 400 | 127 | 260 | 10 | 145 | 0.3007 | 9.623 | 0.6007 | 0.01867 | 94.37 | 0.6007 | |
| 500 | 227 | 440 | 10 | 145 | 0.2401 | 7.683 | 0.4796 | 0.01491 | 75.34 | 0.4796 | |
| 600 | 327 | 620 | 10 | 145 | 0.1999 | 6.398 | 0.3994 | 0.01241 | 62.74 | 0.3994 | |
| 700 | 427 | 800 | 10 | 145 | 0.1714 | 5.483 | 0.3423 | 0.01064 | 53.77 | 0.3423 | |
| 800 | 527 | 980 | 10 | 145 | 0.1499 | 4.798 | 0.2995 | 0.00931 | 47.05 | 0.2995 | |
| 900 | 627 | 1160 | 10 | 145 | 0.1333 | 4.265 | 0.2663 | 0.00828 | 41.83 | 0.2663 | |
| 1000 | 727 | 1340 | 10 | 145 | 0.1200 | 3.839 | 0.2397 | 0.00745 | 37.65 | 0.2397 | |
| Liquid | 100 | -173 | -280 | 50 | 725 | 34.50 | 1104 | 68.91 | 2.142 | 10826 | 68.91 |
| 154.36 | -118.79 | -181.82 | 50 | 725 | 16.01 | 512.4 | 31.99 | 0.994 | 5024 | 31.99 | |
| Gas | 154.36 | -118.79 | -181.82 | 50 | 725 | 11.16 | 357.1 | 22.29 | 0.693 | 3502 | 22.29 |
| 300 | 26.9 | 80.3 | 50 | 725 | 2.062 | 65.97 | 4.12 | 0.128 | 647.0 | 4.118 | |
| 500 | 227 | 440 | 50 | 725 | 1.191 | 38.11 | 2.379 | 0.07394 | 373.7 | 2.379 | |
| 700 | 427 | 800 | 50 | 725 | 0.8473 | 27.11 | 1.693 | 0.05261 | 265.9 | 1.693 | |
| 900 | 627 | 1160 | 50 | 725 | 0.6593 | 21.10 | 1.317 | 0.04094 | 206.9 | 1.317 | |
| Liquid | 55.5 | -217.65 | -359.77 | 100 | 1450 | 41.00 | 1312 | 81.91 | 2.546 | 12866 | 81.91 |
| 60 | -213 | -352 | 100 | 1450 | 40.44 | 1294 | 80.78 | 2.511 | 12690 | 80.78 | |
| 80 | -193 | -316 | 100 | 1450 | 37.72 | 1207 | 75.35 | 2.342 | 11837 | 75.35 | |
| 100 | -173 | -280 | 100 | 1450 | 34.88 | 1116 | 69.67 | 2.165 | 10944 | 69.67 | |
| 120 | -153 | -244 | 100 | 1450 | 31.72 | 1015 | 63.36 | 1.969 | 9954 | 63.36 | |
| 140 | -133 | -208 | 100 | 1450 | 27.89 | 892.5 | 55.72 | 1.732 | 8752 | 55.72 | |
| 160 | -113 | -172 | 100 | 1450 | 22.38 | 716.0 | 44.70 | 1.389 | 7022 | 44.70 | |
| Supercritical phase | 180 | -93.2 | -136 | 100 | 1450 | 13.23 | 423.3 | 26.43 | 0.8213 | 4151 | 26.43 |
| 200 | -73.2 | -99.7 | 100 | 1450 | 8.675 | 277.6 | 17.33 | 0.5386 | 2722 | 17.33 | |
| 220 | -53.2 | -63.7 | 100 | 1450 | 6.872 | 219.9 | 13.73 | 0.4267 | 2156 | 13.73 | |
| 240 | -33.2 | -27.7 | 100 | 1450 | 5.835 | 186.7 | 11.66 | 0.3623 | 1831 | 11.66 | |
| 260 | -13.2 | 8.3 | 100 | 1450 | 5.131 | 164.2 | 10.25 | 0.3186 | 1610 | 10.25 | |
| 280 | 6.9 | 44.3 | 100 | 1450 | 4.613 | 147.6 | 9.214 | 0.2864 | 1447 | 9.214 | |
| 300 | 26.9 | 80.3 | 100 | 1450 | 4.206 | 134.6 | 8.403 | 0.2612 | 1320 | 8.403 | |
| 320 | 46.9 | 116 | 100 | 1450 | 3.875 | 124.0 | 7.741 | 0.2406 | 1216 | 7.741 | |
| 340 | 66.9 | 152 | 100 | 1450 | 3.600 | 115.2 | 7.192 | 0.2235 | 1130 | 7.192 | |
| 360 | 86.9 | 188 | 100 | 1450 | 3.369 | 107.8 | 6.730 | 0.2092 | 1057 | 6.730 | |
| 400 | 127 | 260 | 100 | 1450 | 2.990 | 95.67 | 5.972 | 0.1856 | 938.2 | 5.972 | |
| 500 | 227 | 440 | 100 | 1450 | 2.354 | 75.32 | 4.702 | 0.1461 | 738.6 | 4.702 | |
| 600 | 327 | 620 | 100 | 1450 | 1.951 | 62.44 | 3.898 | 0.1212 | 612.3 | 3.898 | |
| 700 | 427 | 800 | 100 | 1450 | 1.671 | 53.46 | 3.337 | 0.1037 | 524.3 | 3.337 | |
| 800 | 527 | 980 | 100 | 1450 | 1.462 | 46.79 | 2.921 | 0.09079 | 458.9 | 2.921 | |
| 900 | 627 | 1160 | 100 | 1450 | 1.301 | 41.63 | 2.599 | 0.08078 | 408.3 | 2.599 | |
| 1000 | 727 | 1340 | 100 | 1450 | 1.172 | 37.51 | 2.342 | 0.07278 | 367.8 | 2.342 | |
| Liquid | 100 | -173 | -280 | 250 | 3626 | 35.88 | 1148 | 71.69 | 2.228 | 11261 | 71.69 |
Supercritical |
300 | 26.9 | 80.3 | 250 | 3626 | 10.39 | 332.6 | 20.76 | 0.6453 | 3261 | 20.76 |
| 500 | 227 | 440 | 250 | 3626 | 5.624 | 180.0 | 11.24 | 0.3492 | 1765 | 11.24 | |
| 700 | 427 | 800 | 250 | 3626 | 3.992 | 127.8 | 7.975 | 0.2479 | 1253 | 7.975 | |
| 900 | 627 | 1160 | 250 | 3626 | 3.122 | 99.91 | 6.237 | 0.1939 | 979.8 | 6.237 | |
| Liquid | 100 | -173 | -280 | 750 | 10878 | 38.26 | 1224 | 76.44 | 2.376 | 12007 | 76.44 |
300 | 26.9 | 80.3 | 750 | 10878 | 21.60 | 691.3 | 43.16 | 1.341 | 6779 | 43.16 |
| 500 | 227 | 440 | 750 | 10878 | 13.76 | 440.3 | 27.49 | 0.8544 | 4318 | 27.49 | |
| 700 | 427 | 800 | 750 | 10878 | 10.20 | 326.4 | 20.38 | 0.6334 | 3201 | 20.38 | |
| 900 | 627 | 1160 | 750 | 10878 | 8.175 | 261.6 | 16.33 | 0.5076 | 2565 | 16.33 | |
• Densities
• Thermodynamics
Acetone - Density and Specific Weight
Online calculator, figures and tables showing density and specific weight of acetone at temperatures ranging from -95 to 275 °C (-138 to 530 °F) at atmospheric and higher pressure - Imperial and SI Units.
Online calculator, figures and table showing density and specific weight of benzene, C6H6, at temperatures ranging from 5 to 325 °C (42 to 620 °F) at atmospheric and higher pressure - Imperial and SI Units.
Density Converter
Mass vs. Weight
Online calculator, figures and tables showing density and specific weight of methanol,CH3OH, at varying temperature and pressure - Imperial and SI Units.
Nitrogen (N₂) Density & Specific Weight: Temperature & Pressure Data and Calculator
Online calculator, figures and tables showing density and specific weight of nitrogen, N2, at temperatures ranging from -175 to 1325 °C (-280 to 2400 °F) at atmospheric and higher pressure - Imperial and SI Units.
Solubility of oxygen in equilibration with air in fresh water and seawater (salt water) - pressures ranging 1 - 4 bar abs.
Specific heat of Oxygen Gas - O2 - at temperatures ranging 175 - 6000 K.
Solubility of Air in Water
The amount of air that can be dissolved in water decreases with temperature and increases with pressure.
Steel Pipes - Corrosion due to Oxygen
The influence of oxygen concentration and temperature on the corrosion of steel pipes.
