The Prandtl Number - Pr - is a dimensionless number approximating the ratio of momentum diffusivity (kinematic viscosity) to thermal diffusivity - and is often used in heat transfer and free and forced convection calculations.
The Prandtl number can for calculations be expressed as
Pr = μ Cp / k                           (1)
μ = absolute or dynamic viscosity (kg/m s, lbm/(ft h))
Cp = specific heat (J/kg K, Btu/lbmoF)
k = thermal conductivity (W/m K, Btu/(h ft2oF/ft))
Below, Prandtl numbers for carbon dioxide at varying temperatures and pressures are given in figures and table.
See also other properties of Carbon Dioxide at varying temperature and pressure: Density and specific weight, Dynamic and kinematic viscosity, Specific heat (Heat capacity) and Thermal conductivity, and Thermophysical properties at standard conditions,,
as well as Prandtl number of Air, Ammonia, Methane, Nitrogen, Propane and Water .
Carbon dioxide Prandtl number at gas-liquid equilibrium pressure, temperature given as °C or °F:
Carbon dioxide Prandtl number at atmospheric pressure, temperature given as °C and °F:
Carbon dioxide Prandtl number at varying temperatures at given constant pressures, SI and Imperial units:
Carbon dioxide Prandtl number at given temperatures and 1, 10, 50 and 100 bara presure:
Temperature Prandtl number at given pressures
(K) (°C) (°F) 1 bara 10 bara 50 bara 100 bara
220 -53.2 2.5 0.792 2.70
233.03 -40.1 9.7 0.977
240 -33.2 13.6 0.785 0.942 2.32
250 -23.2 19.1 0.781 0.902 2.23 2.16
260 -13.2 24.7 0.777 0.873 2.10
280 6.9 35.8 0.770 0.833 2.06
287.43 14.3 39.9 2.74 (liq)
287.43 14.3 39.9 1.92 (g)
300 26.9 46.9 0.763 0.807 2.39
320 46.9 58.0 0.756 0.788 4.08
340 66.9 69.1 0.750 0.774 1.53
360 86.9 80.3 0.745 0.764 1.17
400 127 102 0.738 0.749 0.938
450 177 130 0.732 0.739 0.776 0.840
500 227 158 0.728 0.732 0.792
600 327 214 0.725 0.727 0.754
650 377 241 0.725 0.726 0.734 0.745
850 577 352 0.723 0.724 0.726 0.730
1050 777 464 0.721 0.721 0.723 0.724
Carbon dioxide phase diagram
Fluid Mechanics
Material Properties
Thermodynamics
Carbon Dioxide (CO₂) Properties & Characteristics: Density, Thermal Data & More
Carbon Dioxide - CO2 - Liquid - Properties, Imperial Units
Properties of saturated liquid Carbon Dioxide - CO2 - density, specific heat, kinematic viscosity, thermal conductivity and Prandtl number.
Carbon Dioxide - Liquid Properties
Carbon Dioxide - Specific Heat of Gas vs. Temperature
Specific heat of Carbon Dioxide gas - CO2 - temperatures ranging 175 - 6000 K.
Online calculator, figures and table showing thermal conductivity of carbon dioxide, CO2, at temperatures ranging from -50 to 775 °C (-50 to 1400 °F) at atmospheric and higher pressure - Imperial and SI Units.
Carbon Dioxide Concentration - Comfort Levels
CO2 acceptance and comfort level.
Carbon Dioxide Concentration in Rooms Occupied with People
Carbon dioxide concentration in a room may indicate air quality and ventilation system efficiency.
Carbon Dioxide Emission from the Human Body vs. Activity
Carbon Dioxide emission from persons vs. activity.
Carbon Dioxide Gas - Ideal Properties
Enthalpy, Entropy and Internal Energy of Carbon Dioxide gas.
CO2 Calculator - Emissions from Trains
Calculator for CO2 emissions from trains, comparing with alternative forms of transportation (as plane, bus, conventional and electrical cars).
CO2 Calculator - Emissions from Airplanes
Calculator for CO2 emissions from planes, comparing with alternative forms of transportation (as train, bus, conventional and electrical cars).
CO2 Calculator - Emissions from Cars
Calculator for CO2 emissions from different kind of cars (gasoline, diesel, LPG, electrical), comparing with alternative forms of transportation (as airplane, bus and train).
Combustion Efficiency and Excess Air
Optimizing boilers efficiency is important to minimize fuel consumption and unwanted excess to the environment.
Combustion of Fuels - Carbon Dioxide Emission
Environmental emission of carbon dioxide CO2 when combustion fuels like coal, oil, natural gas, LPG and bio energy.
Gases - Dynamic Viscosities
Absolute (dynamic) viscosities of some common gases.
Gases - Specific Gravities
Specific gravities of air, ammonia, butadiene, carbon dioxide, carbon monoxide and some other common gases.
Gases - Speed of Sound
Speed of sound in some gases at zero degrees Celsius and atmospheric pressure.
Propane - Thermal Diffusivity vs. Temperature and Pressure
Thermal Conductivity of Common Materials - Solids, Liquids and Gases
Thermal conductivity of various common materials, including metals, gases, and building materials. Essential data for engineers, architects, and designers working with heat transfer and insulation.
