CO2 Calculator - Emissions from Cars
Online CO2calculator for travel by car
By filling in the required information, the calculator below can be used to estimate the CO2emissions from your travels by car.
Additionally, it compares with emissions from alternative ways of travel.
How far do you drive?
( For long distances, see distance table . Choose the nearest destinations for your trip)
What is the average fuel consumption of your car (not necessary for electrical cars)?
How many persons in your car?
Choose the actual kind of fuel in your car (definitions of the different electricities are given below):
Not sure how far you are going? See Driving distance between European cities and Flight distances between cities in and between different continents.
See also CO2calculator - emissions from airplanes and CO2calculator- emissions from trains for more details for aircraft and train emissions.
Unit converter for conversion to and from non-SI units.
A few words about the assumptions for the calculator:
- In comparison with alternative ways of travel, the efficiency regard to distance is set to be:
Car: 1 (reference)
Plane: 0.82 km/km with car
Bus: 1.03 km/km with car
Train: 1.09 km/km with car
(The difference is due to varying driving lines for the different ways of transportation)
- The CO2emissions are strongly dependent on the energy source of the electrical cars. We have used three different classes:
Low CO2el: Mainly non-emission electric power (hydroelectric, sun, wind etc)
Medium CO2el: An even blend of non-emission electric power and power from power plants fired with hydrocarbons (gass, oil or coal)
High CO2el: Mainly power from hydrocarbon fired power plants
- CO2 emissions from alternative travel are calculated assuming:
- Average filled up train, planes and buses.
- If running on electrical power, trains
have the same electricity source as the cars.
- Cars on liquid fuel are compared with electrical trains and cars using Medium CO2el.
Carbon Dioxide (CO₂) Properties & Characteristics: Density, Thermal Data & More
Carbon Dioxide - CO2 - Liquid - Properties, Imperial Units
Properties of saturated liquid Carbon Dioxide - CO2 - density, specific heat, kinematic viscosity, thermal conductivity and Prandtl number.
Carbon Dioxide - Specific Heat of Gas vs. Temperature
Specific heat of Carbon Dioxide gas - CO2 - temperatures ranging 175 - 6000 K.
Carbon Dioxide Emission from the Human Body vs. Activity
Carbon Dioxide emission from persons vs. activity.
CO2 Calculator - Emissions from Trains
Calculator for CO2 emissions from trains, comparing with alternative forms of transportation (as plane, bus, conventional and electrical cars).
CO2 Calculator - Emissions from Airplanes
Calculator for CO2 emissions from planes, comparing with alternative forms of transportation (as train, bus, conventional and electrical cars).
Combustion Efficiency and Excess Air
Optimizing boilers efficiency is important to minimize fuel consumption and unwanted excess to the environment.
Combustion of Fuels - Carbon Dioxide Emission
Environmental emission of carbon dioxide CO2 when combustion fuels like coal, oil, natural gas, LPG and bio energy.
Distance between Cities
Flight distances between selected cities in different countries and continents, to be used to calculate CO2 emissions from long distance flights.
Driving Distances between European Cities
Driving distance between some major European cities.
Fossil vs. Alternative Fuels - Energy Content
Net (low) and gross (high) energy content in fossil and alternative fuels.
New vs. Old Car Costs: A Comprehensive Cost Comparison
Compare the total cost of owning a new car versus an old car, including purchase price, maintenance, fuel efficiency, insurance, and depreciation. Use our detailed breakdown to make an informed financial decision before buying the next vehicle.
Piston Engines - Compression Ratios
Cylinder volume and compression ratios in piston engines.
Piston Engines - Displacement
Calculate piston engine displacement.
