Gases - Dynamic Viscosities
Viscosities of gases at normal pressure:
Gases - Dynamic (Absolute) Viscosities
GasAbsolute Viscosity (10-5 Pa s)
Temperature (°C)
02050100200300400500600
Air 1.73 1.82 1.96 2.20 2.61 2.98 3.32 3.64 3.94
Ammonia 0.92 0.99 1.10 1.30 1.68 2.06 2.44 2.82 3.19
Argon 2.1 2.23 2.42 2.73 3.28 3.77 4.22 4.64 5.04
Benzene 0.7 0.75 0.81 0.94 1.20
Carbon dioxide 1.37 1.47 1.61 1.85 2.30 2.71 3.08 3.42 3.74
Carbon monoxide 1.66 1.74 1.88 2.10 2.52 2.90 3.25 3.56 3.86
Chlorine 1.23 1.32 1.45 1.69 2.10 2.50
Chloroform 0.94 1.01 1.11 1.28 1.62 1.95
Ethylene 0.97 1.03 1.12 1.28 1.54 1.79
Helium 1.87 1.96 2.10 2.32 2.73 3.12 3.48 3.84 4.18
Hydrogen 0.84 0.88 0.94 1.04 1.21 1.37 1.53 1.69 1.84
Methane 1.03 1.10 1.19 1.35 1.63 1.88 2.11 2.33 2.53
Neon 2.98 3.13 3.36 3.70 4.32 4.89 5.43 5.94 6.44
Nitrogen 1.66 1.76 1.89 2.12 2.51 2.86 3.19 3.49 3.78
Nitrous oxide 1.37 1.47 1.61 1.84 2.29 2.70 3.07 3.40 3.70
Oxygen 1.95 2.04 2.18 2.44 2.93 3.37 3.76 4.13 4.47
Steam 0.92 0.97 1.06 1.24 1.62 2.03 2.45 2.86 3.26
Sulphur dioxide 1.16 1.26 1.40 1.64 2.09 2.51 2.90 3.26 3.61
Xenon 2.12 2.28 2.51 2.88 3.57 4.20 4.79 5.34 5.86
  • 1 Pa s = 1 N s/m2 = 10 poise = 1,000 milliPa s
Material Properties
Viscosities
Carbon Dioxide (CO₂) Properties & Characteristics: Density, Thermal Data & More
Density of Gases
Gases - Specific Gravities
Specific gravities of air, ammonia, butadiene, carbon dioxide, carbon monoxide and some other common gases.
Gases - Specific Heat and Individual Gas Constants
Chemical, Physical and Thermal Properties of Hydrogen - H2.
Individual & Universal Gas Constants: Definitions, Values, and Applications
Methane (CH₄): Thermophysical Properties and Phase Diagram
Nitrogen (N₂) Density & Specific Weight: Temperature & Pressure Data and Calculator
Online calculator, figures and tables showing density and specific weight of nitrogen, N2, at temperatures ranging from -175 to 1325 °C (-280 to 2400 °F) at atmospheric and higher pressure - Imperial and SI Units.
Steam - Viscosity vs. Pressure
Absolute viscosity of steam at pressure ranging 1 - 10000 psia.
Sulfur Dioxide Liquid - Thermal Properties
Density, specific heat, thermal conductivity and more.
The Ideal Gas Law
Viscosity Converter: Convert Between Dynamic & Kinematic Viscosity
