Recommended Velocities in Steam Systems
The steam velocities or speeds below are commonly recommended as acceptable for steam distribution systems:
Steam SystemVelocity
(m/s)(ft/s)
Saturated Steam - high pressure 25 - 40 82 - 131
Saturated Steam - medium and low pressure 30-40 99 - 131
Saturated Steam at peak load < 50 < 164
Steam and Water mix < 25 < 82
Superheated Steam 35 - 100 100 - 300
  • Saturated steam - low pressure - is common for heating services and secondary process pipes.
  • Saturated steam - high pressure - is common in powerhouse, boiler and main process lines.
  • Superheated steam is common in power generation and turbine plants.
Pipe Sizing
Sizing of steam and condensate pipe lines - pressure loss, recommended velocity, capacity and more.
Boiling Fluids - Max Suction Flow Velocities
Recommended max suction flow velocity when pumping boiling fluids.
Boiling Liquids - Max Pumping Flow Velocities
Recommended max flow velocity on the delivery (pressure) side when pumping boiling liquids.
Condensate Pipes - Flash Steam Generated
Calculate flash steam generation in condensate pipe lines.
Feed Pumps in Steam Systems - Suction Lift Head vs. Temperature
Cavitation of impellers increases with water temperatures.
Pipe Line Velocities vs. Fluid
Typical fluid flow velocities for common liquids, gases and vapors.
Sizing Steam Pipes (kg/h)
Steam is a compressible gas where pipe line mass flow capacity depends on steam pressure.
Sizing Steam Pipes (lb/h)
Steam Flow Rate vs. Pressure Drop - Schedule 40 Pipe
Flow rate (lb/h) and pressure drop per 100 feet of pipe.
Steam Pipes - Max. Flow and Pressure Drop
Pressure drop and maximum allowable flow in steam pipes.
Steam Pipes - Online Pressure drop Calculator
Calculate pressure drops in steam distribution pipe lines.
Steam Pipes - Pressure Drop vs. Steam Flow
Steam pipes and pressure drop diagrams - imperial and metric units.
Steam Pipes - Sizing
Sizing of steam pipe lines - major and minor loss in steam distribution systems.
Velocity Units Converter
Convert between speed and velocity units like m/s, km/h, knots, mph and ft/s.
