Steam Pipes - Pressure Drop vs. Steam Flow
Pressure drop in steam pipes can be estimated with the diagrams below.
Imperial Units
The diagram is made for steam with pressure 100 psi schedule 40 steel pipe. For other pressures - use correction factors:
Pressure (psi) | 0 | 5 | 10 | 30 | 60 | 90 | 100 | 110 | 150 | 200 | 250 | 300 |
Factor | 6.9 | 5.2 | 4.3 | 2.4 | 1.5 | 1.1 | 1.0 | 0.92 | 0.70 | 0.55 | 0.45 | 0.38 |
- 1 lbs/hr = 1.26x10-4 kg/s
- 1 psi (lb/in2) = 6,894.8 Pa (N/m2) = 6.895x10-3 N/mm2 = 6.895x10-2 bar = 27.71 in H2O at 62oF (16.7oC) = 703.1 mm H2O at 62oF (16.7oC) = 2.0416 in mercury at 62oF (16.7oC) = 51.8 mm mercury at 62oF (16.7oC) = 703.6 kg/m2 = 0.06895 atm = 2.307 Ft. H2O
Metric Units
The diagram is made for steam with pressure 7 bar. For other pressures - multiply the pressure drop with correction factors:
Pressure (bar) | 0 | 1 | 2 | 4 | 5 | 6 | 7 | 8.5 | 10 | 12 | 14 | 20 |
Factor | 6.9 | 3.67 | 2.51 | 1.55 | 1.31 | 1.13 | 1.0 | 0.85 | 0.74 | 0.63 | 0.55 | 0.39 |
- 1 kg/h = 2.778x10-4 kg/s = 3.67x10-2 lb/min
- 1 bar = 105 Pa (N/m2) = 0.1 N/mm2 = 10,197 kp/m2 = 10.20 m H2O = 0.9869 atm = 14.50 psi (lbf/in2) = 106 dyn/cm2 = 750 mmHg
• Pipe Sizing
Sizing of steam and condensate pipe lines - pressure loss, recommended velocity, capacity and more.
Recommended Velocities in Steam Systems
The steam velocity in a steam distribution system should be within certain limits to avoid excessive wear and tear
Saturated Steam - Properties - Imperial Units
Saturated Steam - Properties for Pressure in Bar
Saturated Steam Table with properties like boiling point, specific volume, density, specific enthalpy, specific heat and latent heat of vaporization.
Sizing Steam Pipes (kg/h)
Steam is a compressible gas where pipe line mass flow capacity depends on steam pressure.
Sizing Steam Pipes (lb/h)
Steam Flow Rate vs. Pressure Drop - Schedule 40 Pipe
Flow rate (lb/h) and pressure drop per 100 feet of pipe.
Steam Leaks through Orifices
Steam leaks through orifices for pressures ranging 250 - 600 psi
Steam Pipes - Max. Flow and Pressure Drop
Pressure drop and maximum allowable flow in steam pipes.
Steam Pipes - Online Pressure drop Calculator
Calculate pressure drops in steam distribution pipe lines.
Steam Pipes - Sizing
Sizing of steam pipe lines - major and minor loss in steam distribution systems.
