Steam Pipes - Max. Flow and Pressure Drop
MainsLaterals
Pressure(psi)
600 175 30 600 175 30
Pressure Drop
(psi per 100 ft pipe)
0.7 0.5 0.3 1 0.7 0.5
Nominal Pipe Size
(in)
Maximum Flow (103 lb/h)
3 6.2 2.7 0.9 7.5 3.6 1.2
4 12 5.7 2.5 15 7.5 3.2
6 33 16 6.6 40 21 8.5
8 63 32 14 76 42 18
10 108 58 25 130 76 32
12 158 87 39 190 115 50
14 217 117 54 260 155 70
16 300 166 78 360 220 100
18 227 101 300 130
20 132 170
  • 1 psi (lb/in2) = 6,894.8 Pa (N/m2)
  • 1 ft (foot) = 0.3048 m
Steam and Condensate
Recommended Velocities in Steam Systems
The steam velocity in a steam distribution system should be within certain limits to avoid excessive wear and tear
Sizing Steam Pipes (kg/h)
Steam is a compressible gas where pipe line mass flow capacity depends on steam pressure.
Sizing Steam Pipes (lb/h)
Steam Pipes - Online Pressure drop Calculator
Calculate pressure drops in steam distribution pipe lines.
Steam Pipes - Pressure Drop vs. Steam Flow
Steam pipes and pressure drop diagrams - imperial and metric units.
