Sizing Steam Pipes (lb/h)
This table below can be used for fast calculation of steam pipes sch. 80.
- in general - 80 ft/sec is a recommended steam velocity
For full table with larger dimensions - rotate the screen!
| Capacity (lb/h) | |||||||||||||||
| Gauge Pressure (psi) | Steam Velocity (ft/s) | Pipe Size (in) | |||||||||||||
| 1/2" | 3/4" | 1" | 1 1/4" | 1 1/2" | 2" | 2 1/2" | 3" | 4" | 5" | 6" | 8" | 10" | 12" | ||
| Inside Diameter (in) | |||||||||||||||
| 0.55 | 0.74 | 0.96 | 1.28 | 1.5 | 1.94 | 2.32 | 2.9 | 3.83 | 4.81 | 5.76 | 7.63 | 9.56 | 11.38 | ||
| 5 | 50 | 15 | 27 | 45 | 80 | 110 | 184 | 263 | 411 | 716 | 1130 | 1620 | 2843 | 4464 | 6325 |
| 80 | 24 | 43 | 72 | 128 | 176 | 294 | 421 | 657 | 1146 | 1808 | 2593 | 4550 | 7142 | 10121 | |
| 120 | 35 | 64 | 108 | 192 | 264 | 441 | 631 | 986 | 1720 | 2712 | 3889 | 6824 | 10713 | 15181 | |
| 10 | 50 | 18 | 33 | 55 | 97 | 134 | 224 | 320 | 500 | 873 | 1377 | 1974 | 3464 | 5438 | 7705 |
| 80 | 29 | 52 | 88 | 156 | 214 | 358 | 512 | 801 | 1396 | 2203 | 3159 | 5542 | 8701 | 12329 | |
| 120 | 43 | 78 | 132 | 234 | 321 | 537 | 769 | 1201 | 2095 | 3304 | 4738 | 8313 | 13051 | 18493 | |
| 20 | 50 | 25 | 45 | 76 | 135 | 186 | 310 | 444 | 694 | 1210 | 1909 | 2737 | 4803 | 7540 | 10684 |
| 80 | 40 | 72 | 122 | 216 | 297 | 497 | 710 | 1110 | 1936 | 3054 | 4379 | 7685 | 12064 | 17095 | |
| 120 | 60 | 108 | 182 | 324 | 445 | 745 | 1066 | 1665 | 2904 | 4581 | 6569 | 11527 | 18096 | 25642 | |
| 30 | 50 | 31 | 57 | 96 | 170 | 234 | 391 | 559 | 873 | 1522 | 2401 | 3443 | 6042 | 9485 | 13440 |
| 80 | 50 | 91 | 153 | 272 | 374 | 625 | 894 | 1396 | 2436 | 3842 | 5509 | 9667 | 15176 | 21504 | |
| 120 | 75 | 136 | 230 | 408 | 560 | 937 | 1341 | 2095 | 3654 | 5762 | 8264 | 14500 | 22763 | 32256 | |
| 40 | 50 | 38 | 69 | 116 | 206 | 282 | 472 | 676 | 1056 | 1842 | 2905 | 4165 | 7309 | 11474 | 16258 |
| 80 | 61 | 110 | 185 | 329 | 452 | 756 | 1081 | 1689 | 2947 | 4647 | 6664 | 11694 | 18358 | 26013 | |
| 120 | 91 | 165 | 278 | 494 | 678 | 1134 | 1622 | 2534 | 4420 | 6971 | 9997 | 17541 | 27537 | 39020 | |
| 60 | 50 | 51 | 92 | 155 | 275 | 378 | 633 | 905 | 1414 | 2466 | 3889 | 5577 | 9787 | 15364 | 21771 |
| 80 | 81 | 147 | 248 | 441 | 605 | 1012 | 1448 | 2262 | 3946 | 6223 | 8924 | 15659 | 24582 | 34833 | |
| 120 | 122 | 221 | 372 | 661 | 908 | 1518 | 2172 | 3393 | 5918 | 9334 | 13386 | 23488 | 36873 | 52250 | |
| 80 | 50 | 64 | 115 | 194 | 344 | 473 | 791 | 1132 | 1768 | 3084 | 4864 | 6975 | 12239 | 19213 | 27225 |
| 80 | 102 | 184 | 310 | 551 | 757 | 1266 | 1810 | 2829 | 4934 | 7782 | 11160 | 19582 | 30741 | 43560 | |
| 120 | 153 | 276 | 465 | 827 | 1135 | 1899 | 2716 | 4243 | 7401 | 11673 | 16739 | 29373 | 46112 | 65340 | |
| 100 | 50 | 76 | 138 | 233 | 413 | 568 | 950 | 1358 | 2122 | 3702 | 5839 | 8373 | 14693 | 23066 | 32684 |
| 80 | 122 | 221 | 372 | 662 | 909 | 1520 | 2173 | 3396 | 5923 | 9342 | 13397 | 23508 | 36905 | 52294 | |
| 120 | 183 | 332 | 558 | 992 | 1363 | 2280 | 3260 | 5094 | 8885 | 14014 | 20096 | 35262 | 55358 | 78442 | |
| 120 | 50 | 89 | 161 | 271 | 482 | 661 | 1106 | 1582 | 2472 | 4312 | 6801 | 9752 | 17112 | 26864 | 38066 |
| 80 | 142 | 258 | 433 | 771 | 1058 | 1770 | 2531 | 3955 | 6899 | 10881 | 15603 | 27379 | 42982 | 60906 | |
| 120 | 213 | 386 | 650 | 1156 | 1587 | 2655 | 3797 | 5933 | 10348 | 16321 | 23405 | 41069 | 64473 | 91359 | |
| 150 | 50 | 108 | 196 | 330 | 587 | 806 | 1349 | 1929 | 3013 | 5256 | 8290 | 11888 | 20859 | 32747 | 46402 |
| 80 | 173 | 314 | 528 | 939 | 1290 | 2158 | 3086 | 4821 | 8409 | 13264 | 19020 | 33375 | 52394 | 74243 | |
| 120 | 260 | 471 | 793 | 1409 | 1935 | 3236 | 4628 | 7232 | 12614 | 19895 | 28530 | 50062 | 78592 | 111364 | |
| 200 | 50 | 139 | 251 | 423 | 752 | 1032 | 1727 | 2469 | 3858 | 6730 | 10614 | 15221 | 26708 | 41928 | 59412 |
| 80 | 222 | 402 | 676 | 1203 | 1652 | 2763 | 3951 | 6173 | 10767 | 16982 | 24353 | 42732 | 67084 | 95058 | |
| 120 | 333 | 603 | 1015 | 1804 | 2477 | 4144 | 5926 | 9260 | 16151 | 25473 | 36529 | 64098 | 100627 | 142588 | |
Example - Sizing Steam Pipe Lines
A 4 inch sch. 80 steel pipe with 100 psi steam pressure has a capacity of 5923 lb/h with steam velocity 80 ft/s.
• Sizing of Steam and Condensate Pipes
Dimensions of steam and condensate pipe lines. Calculate pressure losses, recommended velocities, capacities and more.
• Steam and Condensate
ANSI Steel Pipe Schedule 40 Chart: Dimensions, Weights & Specifications
Heating Systems - Steam and Condensate Loads
Pipes - Relative Capacity
Relative capacity between larger and smaller pipes.
Recommended Velocities in Steam Systems
The steam velocity in a steam distribution system should be within certain limits to avoid excessive wear and tear
Sizing Steam Pipes (kg/h)
Steam is a compressible gas where pipe line mass flow capacity depends on steam pressure.
Steam & Condensate Equations
Steam consumption and condensate generation when heating liquid or gas flows
Steam - Flow vs. kW Rating
Calculate steam flow rate vs. kW rating.
Steam Consumption for some Typical Steam Heated Consumers
Steam consumption rates for typical steam heated consumers in industries like bakeries, breweries, paper factories etc.
Steam Flow Rate vs. Pressure Drop - Schedule 40 Pipe
Flow rate (lb/h) and pressure drop per 100 feet of pipe.
Steam Pipes - Installation of Drip Legs
Properly draining steam pipes for condensate.
Steam Pipes - Max. Flow and Pressure Drop
Pressure drop and maximum allowable flow in steam pipes.
Steam Pipes - Online Pressure drop Calculator
Calculate pressure drops in steam distribution pipe lines.
Steam Pipes - Pressure Drop vs. Steam Flow
Steam pipes and pressure drop diagrams - imperial and metric units.
Steam Pipes - Sizing
Sizing of steam pipe lines - major and minor loss in steam distribution systems.
Steam Pipes - Thermal Expansion
Thermal expansion of steam pipes heated from room temperature to operation temperature (mm pr. 100 m pipe).
Steam Trap Selection Guide
Steam trap selection guide - Float & Thermostatic, Inverted Bucket, Bimetal Thermostatic, Impulse and Thermodynamic Disc steam traps.
Steel Pipes Expansion Loops - Design and Calculation
Steel pipe expansion loops and their importance in managing thermal expansion, and how to design and size them effectively. Key considerations, calculations, and installation tips to prevent stress and damage in piping systems.
Thermal Expansion of Steam Pipes - (inches)
Expansion of steam pipes heated from room temperature to operation temperature.
