Steam Pipes - Installation of Drip Legs
The 3D model above is made with sketchup.engineeringtoolbox.com
Condensate is generated in the steam pipes due to heat loss and due to energy required during system heat up. For the steam system to work properly it is important that the condensate is removed.
Steam traps for draining should be located
  • on horizontal pipes - every 30 - 50 m (100 - 150 ft)
  • in front of pressure reducing valves to avoid damaging the equipment
  • in front of control valves to avoid damaging the equipment
  • in front of normally closed valves to avoid building up condensate that may damage the system when accelerated
  • at the bottom of vertical lines
  • at the end of the steam line
Recommended Drip Leg Dimensions
Steam Pipes - Drip Leg Dimensions
Main DiameterPocket DiameterPocket Depth
(mm)(in)(mm)(in)(mm)(in)
50 2 50 2 700 28
80 3 80 3 700 28
100 4 100 4 700 28
250 10 150 6 700 28
500 20 250 10 700 28
Example - Drip Leg Dimensions
The recommended drip leg dimension for a 80 mm (3 in) steam pipe is 80 mm (3 in). The pocket depth should be 700 mm (28 in).
Steam and Condensate
Condensate Generated in Cold Steam Pipes - SI Units
Huge amounts of condensate are generated when cold steam pipes are heated up must be drained from the pipes.
Condensate Generated in Cold Steam Pipes - Sizing of Steam Traps
When cold steam pipes are heated up they generate huge amounts of condensate that must be drained away from the pipe through steam traps - in Imperial Units.
Condensate Pipe Lines - Friction Resistance Imperial Units
Friction or major resistance in condensate pipe lines.
Condensate Pipe Lines - Sizing
Flow and pressure loss in condensate return lines - SI Units.
Condensate Pumping
High temperatures and danger of impeller cavitation is the major challenge for condensate pumping in steam systems.
Insulated Steam Pipes - Condensate Generated
Heat loss from steam pipes generates condensate which must be drained from the system - imperial units.
Insulated Steam Pipes - Condensate Generated (kg/h per 100m)
Heat loss from steam pipes generates condensate which must be drained from the system.
Sizing Steam Pipes (lb/h)
Steam - Gravity Return Condensate Pipes - Capacities
Max. capacities (lb/hour) in gravity condensate return lines.
Sizing of steam pipe lines - major and minor loss in steam distribution systems.
Steam Trap Selection Guide
Steam trap selection guide - Float & Thermostatic, Inverted Bucket, Bimetal Thermostatic, Impulse and Thermodynamic Disc steam traps.
Steam Traps - Safety Factors
Selection of steam traps and their safety factors.
