Condensate Pipe Lines - Friction Resistance Imperial Units
The table below can be used for running load. A common rule of thumb, if the start up conditions are unknown, double the running load to size condensate pipe lines.
Avoid friction resistance above 10 inches Water gauge - H2O - per 100 ft of pipe.
Condensate Pipe Lines - Friction Resistance - Imperial Units
Pipe Size
(inch)
Mass Flow of Condensate (lb/h)
Frictional Resistance - Major loss (inches H2O per 100 ft of pipe)
15710141620
1/2 100 240 290 350 430 460 520
3/4 230 560 680 820 990 1000 1200
1 440 1070 1200 1550 1800 2000 2260
1 1/4 950 2300 2700 3300 4000 4300 4800
1 1/2 1400 3500 4200 5500 6100 6600 7100
2 2800 6800 8100 9900 11800 12700 14200
2 1/2 5700 13800 16500 20000 23900 25700 28900
3 9000 21500 25800 31000 37000 39800 44700
4 18600 44000 52000 63400 75500 81000 90900
  • 1 in = 25.4 mm
Example - Sizing Condensate Pipe
For a steam distribution system with a running load of 2000 lb/h - the startup condensate load is doubled to 4000 lb/h.
Using the 10 inch H2O column - a 1 1/2 inch pipe is acceptable.
Pipe Sizing
Sizing of steam and condensate pipe lines - pressure loss, recommended velocity, capacity and more.
Steam and Condensate
Condensate Generated in Cold Steam Pipes - SI Units
Huge amounts of condensate are generated when cold steam pipes are heated up must be drained from the pipes.
Condensate Generated in Cold Steam Pipes - Sizing of Steam Traps
When cold steam pipes are heated up they generate huge amounts of condensate that must be drained away from the pipe through steam traps - in Imperial Units.
Condensate Pipe Lines - Sizing
Flow and pressure loss in condensate return lines - SI Units.
Condensate Pipes - Flash Steam Generated
Calculate flash steam generation in condensate pipe lines.
Condensate Pumping
High temperatures and danger of impeller cavitation is the major challenge for condensate pumping in steam systems.
Insulated Steam Pipes - Condensate Generated
Heat loss from steam pipes generates condensate which must be drained from the system - imperial units.
Insulated Steam Pipes - Condensate Generated (kg/h per 100m)
Heat loss from steam pipes generates condensate which must be drained from the system.
Steam - Condensate Pipe Lines - Capacities (kW)
Maximum capacities for condensate pipe lines in kW steam consumption.
Steam - Gravity Return Condensate Pipes - Capacities
Max. capacities (lb/hour) in gravity condensate return lines.
Steam Pipes - Installation of Drip Legs
Properly draining steam pipes for condensate.
Steam Tracing Pipe Lines
Steam tracing of pipe lines can be done to maintain appropriate product temperatures.
