Steam Tracing Pipe Lines
Number of steam tracers depends on the size of the pipe and the product temperature in the process line. The surrounding temperature and the insulation efficiency also have influence.
Since the heat moves up steam tracers must be stripped to the lower part of the process pipes. 1/2 inch (15 mm) tracing pipes is quite common.
For normal insulated pipes in normal surrounding conditions the table below can be used to appropriate the numbers of tracers.
Product Line Size
(inch)
Number of 1/2" (15 mm) Steam Tracers
Frost protection, the temperature in the process lines are below
75 oF (25 oC)
Keeping process media fluid, temperatures below
150 oF (65 oC)
300 oF (150 oC)
1 1 1 1
1 1/2 1 1 2
2 1 1 2
3 1 1 3
4 1 2 3
6 2 2 3
8 2 2 3
12 2 3 6
16 2 3 8
20 2 3 10
  • 1 inch = 25.4 mm
Example - Steam Tracing of a Process Line
In a 4 inch transport system for vegetable oil with solidification temperature at 40 oC (104 oF), two 1/2 inches steam tracing pipes should be appropriate.
Insulation and Heat Loss from Steam and Condesate Pipe Lines
Heat loss from uninsulated and insulated steam and condensate pipes and tanks. Calculate insulation thicknesses.
Steam and Condensate
Condensate Pipe Lines - Friction Resistance Imperial Units
Friction or major resistance in condensate pipe lines.
Heat Loss from Oil Filled Tanks and Pipe Lines
Heat loss from insulated and non insulated sheltered and exposed oil tanks and pipes.
Insulated Copper Tubes - Heat Loss
Heat loss to surrounding air from insulated copper tubes.
Oil Pipes - Heat Loss
Heat loss in W/mK and Btu/hr ft degF from oil tubes ranging temperatures 10 - 38 degC (50 - 100 degF).
Pipes - Bare Surface Heat Loss
Heat loss vs. surface temperature.
Pipes - Insulated Heat Loss Diagrams
Heat loss (W/m) from 1/2 to 6 inches insulated pipesĀ - ranging insulation thickness 10 to 80 mm and temperature differences 20 to 180 degC.
Heat loss (W/ft) diagrams for 1/2 to 6 inches insulated pipesĀ - ranging insulation thickness 0.5 to 4 inches and temperature differences 50 to 350 degF.
Steel Pipes - Heat Loss Diagram
Heat loss from steel pipes and tubes - dimensions 1/2 to 12 inches.
