Oil Pipes - Heat Loss
Heat loss from oil pipes are indicated below:
W/mK
(Btu/hr ft oF)
Nominal bore
mm
Oil Temperature
up to 10 oC
(up to 50 oF)
10 - 27 oC
(50 - 80 oF)
27 - 38 oC
(80 - 100 oF)
15 0.7
(0.4)
0.9
(0.5)
0.9
(0.5)
20 0.7
(0.4)
1.1
(0.6)
1.1
(0.6)
25 0.8
(1.4)
1.2
(0.7)
1.4
(0.8)
40 2.1
(1.6)
1.7
(1.0)
1.9
(1.1)
50 2.8
(1.6)
2.1
(1.2)
2.2
(1.3)
Combustion
Heat Loss from Oil Filled Tanks and Pipe Lines
Heat loss from insulated and non insulated sheltered and exposed oil tanks and pipes.
Oil Pipes - Head Loss
Head or pressure loss due to friction in oil pipes - various viscosity and laminar flow.
Oil Pipes - Recommended Flow Velocities
Oil pipes flow velocities should be kept within certain limits.
Oil Tanks - Heat Loss
Heat loss from lagged and unlagged, sheltered and exposed oil tanks.
Pipes and Cylinders - Conductive Heat Losses
Conductive heat losses through cylinder or pipe walls.
Steam Tracing Pipe Lines
Steam tracing of pipe lines can be done to maintain appropriate product temperatures.
