Oil Pipes - Recommended Flow Velocities
The table below can be used when designing oil pipes:
Oil ApplicationOil Flow Velocity
m/sft/s
Suction lines for pumps < 0.5 < 1.6
Suction lines for pumps at low pressures 0.1 - 0.2 0.3 - 0.65
Discharge lines for booster pumps 1.0 - 2.0 3.3 - 6.5
Discharge lines for burner pumps < 1.0 < 3.3
Values depends on the viscosity of the oil - typical qualities like benzol, gas oil ..
Heavier oils with higher viscosities requires lower velocities - but can be compensated with heating and heat tracing.
Combustion
Fluid Flow and Pressure Loss
Heat Loss from Oil Filled Tanks and Pipe Lines
Heat loss from insulated and non insulated sheltered and exposed oil tanks and pipes.
Light Oil Pumping - Flow Velocities
Recommended max. flow velocities on the delivery side when pumping light oils.
Light Oil Suction - Flow Velocities
Recommended max. suction flow velocities when pumping light oils.
Oil Pipes - Head Loss
Head or pressure loss due to friction in oil pipes - various viscosity and laminar flow.
Oil Pipes - Heat Loss
Heat loss in W/mK and Btu/hr ft degF from oil tubes ranging temperatures 10 - 38 degC (50 - 100 degF).
Oil Pipes - Pressure Loss vs. Oil Flow
Pressure drop in oil pipes - viscosities ranging 100 - 600 Saybolt Universal Seconds.
