Pipes and Cylinders - Conductive Heat Loss
Uninsulated Cylinder or Pipe
Conductive heat loss through the wall of a cylinder or pipe can be expressed as
Q = 2 π L (ti - to) / (ln(r/ ri) / k)                              (1)
Q = heat transfer from cylinder or pipe (W, Btu/hr)
k = thermal conductivity of piping material (W/mK or W/moC, Btu/(hr oF ft2/ft))
L = length of cylinder or pipe (m, ft)
π = pi = 3.14...
to = temperature outside pipe or cylinder (K or oC, oF)
ti = temperature inside pipe or cylinder (K or oC, oF)
ln = the natural logarithm
ro = cylinder or pipe outside radius (m, ft)
ri = cylinder or pipe inside radius (m, ft)
Insulated Cylinder or Pipe
Conductive heat loss through an insulated cylinder or pipe can be expressed as
Q = 2 π L (ti - to) / ((ln(r/ ri) / k) + (ln(rs / ro) / ks))                          (2)
rs = outside radius of insulation (m, ft)
ks = thermal conductivity of insulation material (W/mK or W/moC, Btu/(hr oF ft2/ft))
Equation 2 with inside convective heat resistance can be expressed as
Q = 2 π L (ti - to) / (1 / (hc ri) + (ln(r/ ri) / k) + (ln(rs / ro) / ks))                          (3)
hc = convective heat transfer coefficient (W/m2K)
Heat Loss and Insulation
Insulation
Thermodynamics
Conductive Heat Transfer
Copper Tubes - Heat Losses
Heat loss from uninsulated copper tubes vs. temperature differences between tube and air.
Copper Tubes - Uninsulated Heat Losses
Heat loss from uninsulated copper pipes - dimensions ranging 1/2 - 4 inches.
Insulated Copper Tubes - Heat Loss
Heat loss to surrounding air from insulated copper tubes.
Online calculator, figures and tables showing thermal conductivity of nitrogen, N2, at varying temperarure and pressure, SI and Imperial units.
Oil Filled Tanks - Heat Loss
Heat loss from insulated and uninsulated, sheltered and exposed heated oil tanks.
Oil Pipes - Heat Loss
Heat loss in W/mK and Btu/hr ft degF from oil tubes ranging temperatures 10 - 38 degC (50 - 100 degF).
Pipes - Bare Surface Heat Loss
Heat loss vs. surface temperature.
Pipes - Insulated Heat Loss Diagrams
Heat loss (W/m) from 1/2 to 6 inches insulated pipesĀ - ranging insulation thickness 10 to 80 mm and temperature differences 20 to 180 degC.
Heat loss (W/ft) diagrams for 1/2 to 6 inches insulated pipesĀ - ranging insulation thickness 0.5 to 4 inches and temperature differences 50 to 350 degF.
Pipes Submerged in Oil or Fat - Heat Emission
Heat emission from steam or water heating pipes submerged in oil or fat - forced and natural circulation.
Piping - Recommended Insulation Thickness
Recommended insulation thickness for heating systems like hot water and low, medium or high pressure steam systems.
Steam Pipes - Heat Losses
The amount of condensate generated in a steam pipe depends on the heat loss from the pipe to the surroundings.
Steam Pipes - Heat Losses (W/m)
Heat losses from un-insulated steam pipes.
Steel Pipes - Heat Loss Diagram
Heat loss from steel pipes and tubes - dimensions 1/2 to 12 inches.
Thermal Conductivity of Common Materials - Solids, Liquids and Gases
Thermal conductivity of various common materials, including metals, gases, and building materials. Essential data for engineers, architects, and designers working with heat transfer and insulation.
