Thermal resistance is the ability of a material to resist flow of heat. Thermal resistivity is the reciprocal of thermal conductivity and can be expressed as
r = 1 / k (1)
r = thermal resistivity (moC/W, hr ft2 oF/(Btu in))
k = thermal conductivity (W/(moC), Btu in/(hr ft2 oF))
Thermal conductivity - k - is the property of a material indicating its ability to conduct heat.
• Thermodynamics
Calcium Silicate Insulation
Thermal conductivity of calcium silicate insulation - temperature and k-values.
Carnot Cycle Efficiency
Conductive Heat Transfer
Fiberglass Insulation
Thermal conductivity of fiberglass insulation - temperature and k-values.
Typical heat exchanger materials and their thermal conductivities.
Mineral Wool Insulation
Perlite Insulation
Pipes and Cylinders - Conductive Heat Loss
Conductive heat losses through cylinder or pipe walls.
Piping - Recommended Insulation Thickness
Recommended insulation thickness for heating systems like hot water and low, medium or high pressure steam systems.
Thermal conductivity of plastics.
Polyurethane Insulation
Resistivity and Conductivity - Temperature Coefficients Common Materials
Resistivity, conductivity and temperature coefficients for common materials like silver, gold, platinum, iron and more..
Thermal Conductivity of Common Materials - Solids, Liquids and Gases
Thermal conductivity of various common materials, including metals, gases, and building materials. Essential data for engineers, architects, and designers working with heat transfer and insulation.
Thermal Conductivity Units Converter
